Hot Rods Losing battle with Hydramatic
Discussion in 'The Hokey Ass Message Board' started by skooch, Aug 11, 2023.
  1. skooch
    skooch
    I bought a 1949 olds 303 and Hydramatic that had been sitting for 15 plus years, I freshened the engine up and it runs great but the transmission is giving me fits. It stays engaged while in neutral and it will not shift from low to reverse. Reverse works and the reverse park lock works.
    I have replaced the front and rear seals, dis***embled and cleaned the valve ***embly twice just to satisfy myself that I ***embled it correctly and adjusted the bands and tested that they engaged and disengaged.
    transmission linkage is uninstalled, engine rpm 450 and the transmission has 70 pounds of pressure at idle.
    is there something that I could have installed wrong while ***embling the torus ***embly?
    Any other ideas?
    warbird1 and chryslerfan55 like this.
  2. warbird1
    warbird1
    All my Hydro manuals are out at the shop, and I won't be going out there until Tuesday, but will take a look then.
    skooch and 41 GMC K-18 like this.
  3. vtwhead
    vtwhead
    @PhilA might be able to help you out as he has had his apart many times.
    bchctybob and skooch like this.
  4. skooch
    skooch
    Yes, Phil helped me with the band adjustments. I thought I’d throw a wide net and see what I get.
  5. d2_willys
    d2_willys
    from Kansas
    I have a 1950 Olds 98, and have almost the same transmission as you do. Perhaps I can shed some light on this.
    Until 1951, the reverse gear was mechanically applied, meaning that it was sort of like a non-synchro mesh transmission. I have to stop at Lo for a few seconds, then move to reverse to avoid grinding.
    With this in mind, does your transmission grind while trying to get to reverse? If so, I believe the front band may be out of adjustment, which would not stop the inside shafts from turning while stopped.
    bchctybob, 427 sleeper and skooch like this.
  6. skooch
    skooch
    D2, that’s helpful, I’ll try waiting longer in low before shifting into reverse.
  7. dan c
    dan c
    i've never worked on one, but i understand that there aren't a lot of technicians left that know how to adjust them. as a teen, that's one reason we drove stick shift cars...
    427 sleeper likes this.
  8. skooch
    skooch
    I’m stubborn enough to keep trying till I get it. I just tried adjusting the front band again. According to the fatsco website you engage the band at 700 rpm and back it off when the engine rises to 900 rpm if there is no change the band is slipping. I got no rpm change, time to pull the pan again and see if I can find what’s wrong.
    warbird1 likes this.
  9. willys36
    willys36
    As you know Hydramatics prior to 1954 were not Dual Range and had the mechanical reverse engagement using the co**** 'parking' paul. Dual Range units had clutch applied reverse which of course is infinitely smoother. Low gear has both front and rear bands applied, no clutches applied. Shifting to reverse releases the rear band, keeps the front band applied and engages the parking/reverse paul with the shift lever. The rear band is involved in neutral also. It is applied with the engine off but released with the engine running. Sounds like your rear band is not adjusted properly?
    skooch likes this.
  10. skooch
    skooch
    When I first dis***embled the valve body that reverse parking valve was frozen up and not working but both it and reverse works now when started in the reverse position. I’m more concerned with not having neutral working which like you said may also be attributed to the rear band. Something definitely not right with the front band though.
    Btw, I spent a lot of time studying your Rube Goldberg throttle linkage when working on mine, pretty ingenious.
    bchctybob likes this.
  11. willys36
    willys36
    Thanx! I was surprised that it works!!!!
    skooch likes this.
  12. d2_willys
    d2_willys
    from Kansas
    Dual Range hydramatics first appeared in 1952 models. 1951 was the first year to have hydraulic applied reverse. 1950 being the last year for mechanical reverse.
  13. d2_willys
    d2_willys
    from Kansas
    Another thing is that Lo range can be set up for 1st or 2nd gear start. In the case of the 2nd gear start the front band is released, only the rear band is applied. As mentioned, you need to check the rear band adjustment.
  14. d2_willys
    d2_willys
    from Kansas
    A few years ago I had mentioned that the reverse cone clutch would periodically stick. I have only had that happen to me on my 54 Lincoln. The symptoms were that when in a forward drive range the car would not move. Reverse worked, but even neutral felt like the car was stuck in a gear.
    In the Paul Marsh hydramatic manual there's a procedure to get the reverse clutch freed up.
    It lists that you shift to Lo then to Reverse, then repeat 4 more times. Of course you will need to keep the brakes on during the procedure.
  15. willys36
    willys36
    You are right. Got my years mixed up. The first gear hold valve is the patent that put B&M on the map. In actuality, it was only really useful to mud boggers who rocked the car to get unstuck! As a racing ******, the 1-2 shift needed to happen so quickly, most racers just started out in 2nd. In the fluid coupling the low gear was the equivalent of a torque converter.
  16. willys36
    willys36
    But his doesn't have the cone clutch?
  17. Glenn Thoreson
    Glenn Thoreson
    from SW Wyoming
    Have you checked your linkage adjustment? Seems to be pretty critical on these things. That and bad motor mounts can cause a lot of problems.
  18. d2_willys
    d2_willys
    from Kansas
    Probably true, but his symptoms sound a lot like the reverse unit sticking problems.
  19. skooch
    skooch
    Thanks for those who gave their input, I found the reason why it wouldn’t go into neutral. I took apart the valve body ***embly (again!) and found a burr that was holding a valve in place which caused the torus ***embly to spin. Some 400 grit wrapped around a chopstick fixed it.
    shifting from low to reverse is now possible with waiting 10 seconds and holding the brake but it ain’t pretty.
    Crusty Chevy and warbird1 like this.
  20. warbird1
    warbird1
    Sorry I just flat spaced-out and forgot to do some research when I was out at the shop Tuesday! But, at least it sounds like you're getting somewhere...
    skooch likes this.
