Technical Car starts occasionally
Discussion in 'The Hokey Ass Message Board' started by Ima, Aug 13, 2023.
Tags:
  1. Ima
    Ima
    from New Englnd
    Last trip I start the car ('54 Mainline) drove 30 to 40 miles, re-started 2 times during the trip then it turned over but wouldn't start again. The battery is still fully charged, the alternator still charging, but won't start.
    After towing it home I charged the battery (only took 20 minutes so it was still fully charged.) and it started right up. Could it be wiring? Spark plugs? Points?
  2. 1971BB427
    1971BB427
    from Oregon
    If it cranked and didn't start later when it was completely warmed up, I'd suspect either carb issues. If it cranks slower, and wont start, then might be a starter issue once it's hot.
    Did you happen to check for spark at the end of a plug wire when it wouldn't start? If no spark or weak spark when hot, the coil could be failing.
  3. Ima
    Ima
    from New Englnd
    Haven't checked the plugs, hard to get to but plan that next.
  4. Kevin Ardinger
    Kevin Ardinger
    Won’t start is kind of vague. Crank no start, no crank? What exactly does it do?
    Tim likes this.
  5. Kevin Ardinger
    Kevin Ardinger
    Sorry, I see that you said it cranks, but didn’t start. Does it have points, electronic, ignition, what kind of carburetor?
  6. Ima
    Ima
    from New Englnd
    A mechanic went thru it about a year ago and said everything looked "good" except the wiring was old and missing a lot of the insulation. Could the wires be heating up enough to cause car to not start?
  7. BJR
    BJR
    If it doesn't have spark when it won't start, if original points ignition, change the condenser. If that doesn't fix it, change the coil.
    Kevin Ardinger likes this.
  8. Budget36
    Budget36
    Do you have a timing light? When it won’t start, put the light on the coil wire and see if it flashes when cranking it over.
  9. 302GMC
    302GMC
    from Idaho
    File the points ....
  10. Mr48chev
    You aren't giving us a lot go on and the wild *** guesses and favorite answers pop up without a lot of thought put into them.
    Will it crank over when it stalls? Yes____ No_____ real slow________
    Yes, = there is another problem.
    No = there is a problem in the cranking system
    Real slow = There is excess resistance somewhere. With a 6 volt that excess resistance is usually #4 battery cables rather than heavier cables required by 6 volt systems.
    Stalls out after a short drive and cranks good but won't fire but fires right up about an hour later and will drive about the same distance before stalling again. Check the gas cap especially if it is new. Non vented caps will create a vacuum in the tank when there is no vent for air to go in the tank to replace the gas going out. That's simple to check, when it stalls you open the cap and see if air rushes in the tank. That you could probably check by letting it run in the driveway for a few minutes.
    Trash in the tank that blocks the pickup tube and then moves away when there is no vacuum against it.
  11. bigdog
    bigdog
    Fuel, spark, compression. You're missing at least one. Without some testing and more information that's the best I can do.
    jaracer likes this.
  12. bobss396
    bobss396
    I had a '67 Impala that would pull that on me. It was a combo of a bad starter, too much timing and vapor lock. Once hot, I would get a 1/4 turn out of it... that was it. Once it cooled down, I was back in business.
  13. RRanchero Rick
    RRanchero Rick
    Check ground. Had a 302 Ford, didn't like it when grounded anywhere on engine or frame. (sometimes it would start great , then 5 minutes later, wouldn't crank at all or very slowly.) Finally I grounded battery to starter, problem solved.
  14. Ima
    Ima
    from New Englnd
    Got it! Looks like it's the fuel line or pump. It'll start right up each time I prime it.
    Thanks for all the advise.
    bobss396 likes this.
  15. bobss396
    bobss396
    I had a porous fuel hose way up high on the gas tank of my '65 Belair wagon... real fun to get to that.
