Hot Rods The ALTERED thread
Discussion in 'The Hokey Ass Message Board' started by loudbang, Mar 3, 2016.
  1. 40ragtopdown
    40ragtopdown
  2. 40ragtopdown
    40ragtopdown
  3. 40ragtopdown
    40ragtopdown
  4. 40ragtopdown
    40ragtopdown
  5. AmishMike
    AmishMike
    Wonder what happened to those old bodies. Ship me the Lakeside Dairy car
  6. 40ragtopdown
    40ragtopdown
  7. noboD
    noboD
    What difference would have been between an A or B altered?
  8. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    The weight-to cubic inch difference. The B/A car needs to carry more weight for every cubic inch of displacement than an A/A.
    Weight breaks changed over the years and by sanctioning body.
    40ragtopdown and loudbang like this.
  9. noboD
    noboD
    Thanks, so it was just cubic inches? Weight was brought in too.
  10. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    Indeed this made for an interesting concept:
    Is it better to build a small displacement engine and put it in a light car or build a larger engine and find a heavier car to use???
    Let's say you have a mnimum rule of 6 pounds per cubic inch.
    Should you build a 300 ci engine and put it in a 1800 pound car(car and driver > [6 x 300 = 1800#]) or build a 400 ci engine and put it in a 2400# [6 x 400 = 2400#] car?
    There are advantages and disadvantages to either path.
    The smaller engine has less internal motoring friction - GOOD! but a lighter car still has to push through about the same amount of air and spin similar drivetrain pieces making aero and drivetrain friction losses somewhat equal regardless of engine size - BAD! A smaller engine will require less fuel and hence make it easier to keep up with fuel demand - GOOD! but will likely be harder to handle or less consistent due to less weight on the slicks - BAD!
    The larger engine will make more power - GOOD! but motoring friction losses are higher (due to things like increased piston speed / drag and more oil pan windage losses, etc.) BAD! A heavier car also has the advantage of more weight on the tires - GOOD! but will probably be prone to breaking stuff - BAD!
    Arguments for either option have gone on for decades and successful cars utilizing each concept exist, somewhat dictated by evolutionary advancements in things like tires, clutches, engine components etc.
    I think the evolutionary trends in many cl***es tended to favor the smaller engine / lighter car school of thought.
    This aspect of the sport I find to be extremely interesting. I used to pore over the rules and rule updates when the rule books came out. More fun than reading Shakespear in Lit cl*** which I was supposed to be doing.
  11. noboD
    noboD
    Thanks for the explanation. The other day I saw a bogus streetrod, SBC with a blower, in a Model A coupe. He had AA/A painted on it, which I would think is wrong. Probably should have been a g***er, no setback, etc. It made me start to think just what were the rules. I read them but that was almost 60 years ago. Thanks for your help.
  12. Sky Six
    Sky Six
    from Arizona
  13. Sky Six
    Sky Six
    from Arizona
  14. Sky Six
    Sky Six
    from Arizona
  15. dearjose
    dearjose
    Screenshot_20230813_160654_Instagram.jpg I dig the body setback on this one. Not sure how successful it was but nice setup.
  16. dearjose
    dearjose
    Screenshot_20230813_160807_Instagram.jpg One of the lowest fiats I've seen.
  17. dearjose
    dearjose
  18. Sky Six
    Sky Six
    from Arizona
    It's Mike Sullivan's
  19. Sky Six
    Sky Six
    from Arizona
  20. Sky Six
    Sky Six
    from Arizona
  21. Stan Back
    Stan Back
    Mackey & Kitchen.jpg "Altered" (and all the other categories') rules often changed from year to year -- and sanctioning body. Sometimes weight to cubic inches, older rules for just displacement, supercharged cars bumped up a cl***, and more.
    In 1961 (or was it 62?) we ran a C/(Altered 25% and ***umed Gas) Roadster with just displacement rules at Fontana and Colton. I remember we wanted to run in the new WinterNationals, but they considered our car an A/Roadster. (Plus, they wanted an entry fee. We were "part of the show" at that time and didn't pay entry fees. Plus flat towing to Pomona would be a chore anyway.)
    And here's a fun story -- We became the first Gas Roadster to run in the eights (or was it the nines) at Fontana. We started from the south fence, almost to Valley Blvd. It's amazing how much E.T. is shortened by starting 100 to 150 feet back from the Starting Line. The speed was down as the motor had a front gas pump and had run a bunch of time pushing back there and running so long before making the run that it lost fuel pressure.
  22. 40ragtopdown
    40ragtopdown
  23. 40ragtopdown
    40ragtopdown
  24. swade41
    swade41
    from Buffalo,NY
  25. 40ragtopdown
    40ragtopdown
  26. Sky Six
    Sky Six
    from Arizona
  27. Mike VV
    Mike VV
    from SoCal
    From above -
    And another said, yes, Mike Sullivan...and Steve Height (from San Bernardino CA.), before any...paint.
    One of the best looking Fiats on the drag strip, no matter how it was painted.
    Mike
  28. 40ragtopdown
    40ragtopdown
  29. 40ragtopdown
    40ragtopdown
  30. 40ragtopdown
    40ragtopdown
