Technical Custom tail light stands from 34 headlight stands?!?
Discussion in 'Traditional Hot Rods' started by Fordgasser1, Aug 14, 2023.
  1. Fordgasser1
    Fordgasser1
    from Jersey
    I was looking around for some cool way to mount 37 ford truck tail lights on my highboy 34 Ford. Looking through my parts I thought that a pair of 34 headlight stands would look cool modified for this purpose. I’ve never seen it done before so I figured what the heck! Let’s try it! It’s easy and doesn’t cost much except some time and two headlight stands. 1D1551B4-3FBB-4F19-9AE2-2364E5D18553.jpeg 2A1E84A0-E051-4408-9B0D-4960CA79AC0E.jpeg A69D9E93-8039-4776-8671-2A211AAAAB2E.jpeg CB63D4B9-7B93-43BC-AFC6-39FBEBD932EA.jpeg
    Toms Dogs, hfh, Okie Pete and 14 others like this.
  2. Fordgasser1
    Fordgasser1
    from Jersey
    Here’s a stock headlight stand on left. Center has been cut down on a chop saw and ground to better accommodate the bullet shape of the tail light. 82A530E5-6B84-4522-8054-5BF6D0011D17.jpeg
    hfh, Okie Pete, dwollam and 8 others like this.
  3. Fordgasser1
    Fordgasser1
    from Jersey
    I found two large flat washers and ground them to fit the opening. Measured and marked them for two mounting screws to bolt the taillights to the stands.tack welded the washer to the inside of stand. I could’ve just welded the tail light bucket directly to the stand but opted to make it bolt on in case I didn’t like the end result.I had to use an Allen screw for easier access to tight area. 4372CE76-4C9A-4049-8A9D-695D76C3B4EF.jpeg E688B1EF-FA78-4516-B256-5D5D1FC83402.jpeg
  4. Fordgasser1
    Fordgasser1
    from Jersey
    Added a second hidden tab with stud to secure the stand to my rear body gussets. Tight squeeze but you can still remove screws to dis***emble tail light. 43CC38B2-1A62-4EE1-A0CD-7357F2221B1C.jpeg 021EE89C-01A7-4E9E-BF9F-FC0B88293E1A.jpeg 7AE1E6E1-024F-4D19-96F9-4D6BFAA2E58A.jpeg 87D4336A-1964-46E4-B973-F7467925C942.jpeg
    hfh, Okie Pete, dwollam and 6 others like this.
  5. Fordgasser1
    Fordgasser1
    from Jersey
    End results. I hope this illustrates how I made a cool and unique pair of stands . EA7DAF2F-3598-48C9-A8E6-E9AD201BE8A9.jpeg D1CBB765-5018-42C4-A540-B99A1634AB94.jpeg 95F82B17-CDDF-42B2-A9D0-FBDF73EF672D.jpeg 900C7CBE-098A-4450-8B55-97127085B300.jpeg
    Bandit Billy, hfh, Okie Pete and 14 others like this.
  6. I like!
    Fordgasser1 likes this.
  7. pprather
    pprather
    Thanks. Very nice tech article.
  8. BJR
    BJR
    Nice write up, and looks great.
  9. 57 Fargo
    57 Fargo
    Looks great.
  10. dirt t
    dirt t
    Well done. Great tech.
  11. Fordgasser1
    Fordgasser1
    from Jersey
    Thanks guys! I’m not much on writing long worded posts,I think the pictures show pretty much how to replicate what I’ve done.
  12. Dan Hay
    Dan Hay
    That’s a kind of recycling I can get behind! Nice!
  13. rdscotty
    rdscotty
    from red deer
    Nice! Thanks for showing us.
  14. vtx1800
    vtx1800
    They look perfect...you have a good eye to see what it could look like:)
    clem and Fordgasser1 like this.
  15. Mission accomplished!
  16. They look good, and are less prone to breakage than the stock Ford tail light brackets.
  17. Anderson
    Anderson
    I love this. Way better than the spindly tubular mounts you usually see. Nice work!!
    Tman and Fordgasser1 like this.
  18. Fordgasser1
    Fordgasser1
    from Jersey
    Thanks..Also,in my opinion,I hate those store bought mounts they sell..They look fine for a model a or even a 32 but a 34 has such cool, flowing body lines that those type of mounts look kinda cheesy on it..Plus, I am cheap! ha ha
  19. Okie Pete
    Okie Pete
    Very nice
  20. 38Chevy454
    38Chevy454
    Great job on the repurposing of the stands. End result looks nice and flows nice with the taillight bucket.
