Technical SBC 3x2 intake question
Discussion in 'The Hokey Ass Message Board' started by Wizard1926, Aug 13, 2023.
  1. Wizard1926
    Wizard1926
    I think I know the answer, so dont roast me to bad...
    Is there any 3x2 intakes for pre 85 SBC that you can still run an HEI dist ?
    Thanks
    Bill
  2. alchemy
    alchemy
    You are wondering about a big round GM HEI?
  3. Wizard1926
    Wizard1926
    Yes Sir. Just installed a new one on my single 4 setup, but want to go 3x2 and didnt want to purchase another dist
  4. RICH B
    RICH B
    Can't imagine it fitting. Tight between the rear carb and the window on a normal dist.
    Deuces, Wizard1926 and big duece like this.
  5. PackardV8
    PackardV8
    None we've ever seen. Life is tradeoffs.
    jack vines
  6. Wizard1926
    Wizard1926
    Thanks guys. I knew you was bust my bubble :(
    But that's okay.
    Last 3x2 setup I ran was 37 years ago in a 62 Falcon Pickup g***er with a 327.
    Tow Truck Tom and Deuces like this.
  7. hepme
    hepme
    None that I know of for a sbc. I've had 2, large base type and small base-neither would clear. Best bet is **** it up and buy a ready to run msd small head type-fits perfect and looks the part.
    Deuces and Wizard1926 like this.
  8. Koz
    Koz
    Not sure how stuck on trips you are but you can run 2x2, large base Rochesters and use one. You need to make the manifold like a Sam-O-Ram. I've made a bunch now. They don't run bad at all and the coolness factor is pretty high. I'm making one now with small base Rochesters for a 355. Will be a tad easier on the mild motor. Nicson made one in the '50's but extremely rare now. Samiyam may want to jump in here. This pic is one I use for a muse. Not sure who made it.
    Deuces, swade41, Motorwrxs and 2 others like this.
  9. Wizard1926
    Wizard1926
    You are 100% right. Thanks
  10. Wizard1926
    Wizard1926
    Now that would be perfect.
    And you are right about the cool factor. Wonder why no one still offers something like that
    Tow Truck Tom likes this.
  11. Wizard1926
    Wizard1926
    You could just send one of those my way and I can test it for ya ;)
    Koz likes this.
  12. davxsmith
    davxsmith
    What valve covers are these? They don't look like the Mooneyes that are available these days
  13. Illustrious Hector
    Illustrious Hector
    Get an original, rebuild it and run it. If you don't like/want points, change it to Pertronix. The big GM
    HEI is a good unit, but is best on cars with a closed hood
  14. el Scotto
    el Scotto
    from Tracy, CA
    They look like modified Edelbrock finned jobs...
    RICH B and davxsmith like this.
  15. RICH B
    RICH B
    They started out as Edelbrock covers that someone drilled a breather hole right in the center of the script. Welded the holes, "milled" the center flat with a router, and added the breathers. I actually bought two sets of covers with butchered holes in one cover for cheap on eBay and used the unmolested covers on my '35.
  16. davxsmith
    davxsmith
    Regardless of them being butchered, they certainly look cool from above. Thanks for the info
  17. RICH B
    RICH B
    I still wonder at not one; but two guys that thought it was a good idea to put a PCV valve/breather hole right in the middle of the script; same goes for the ones that make holes in Corvette rocker covers.
  18. HEATHEN
    HEATHEN
    from SIDNEY, NY
    Years ago, stock car guys seemed to take a perverse pleasure in destroying Corvette valve covers that way.
  19. swade41
    swade41
    from Buffalo,NY
    These covers someone put breathers on both sides, not sure the reasoning on that one either.
  20. Cali4niaCruiser
    Cali4niaCruiser
    Deuces likes this.
