Hot Rods 2x4 stands
Discussion in 'The Hokey Ass Message Board' started by terry k, Aug 15, 2023.
  1. terry k
    terry k
    from toledo oh
    I see a lot of cars sitting up on stacks of 2x4 crisscrossed. What is the suggested length. Thanks
    Chief 64, chevy57dude and Tman like this.
  2. caprockfabshop
    caprockfabshop
  3. gnichols
    gnichols
    from Tampa, FL
    Put two s**** 2x4s ahead and behind your largest tire. Measure between the insides of both s**** studs. You’re done. Be sure to build your stands so the wheel stops will prevent the car from rolling off! You’ll also have to consider how high your jack goes. If the stands are too high for your jack then you’ll have to get creative with blocks or get a longer jack that raises higher.
  4. kabinenroller
    kabinenroller
    I tend to over build stuff. I used 4x4’s glued and screwed together, with a double deck plywood top and built in wheel chocks. Raises the car about 12” which is perfect for working under and still accessing the interior.
  5. swade41
    swade41
    from Buffalo,NY
    I don't remember the numbers but you can calculate the most efficient size from the given length of 2x4, say individual boards at 10 inches and some at 14 using a 10 ft long piece.
    I used a bunch of left over lumber from renovating a one bedroom apartment into more garage space, I have big n littles on my cars so I made two of them wider than the other two.
    If you Google "automotive wooden cribbing" I'm sure some plans will show up to take using your brain out of the equation.
    Tman, Hnstray, Just Gary and 6 others like this.
  6. Anderson
    Anderson
    Given the lengths of the s****s I had after building a shed, I made mine 16” square.
    Tman, caprockfabshop and Deuces like this.
  7. rusty1
    rusty1
    that first pic you showed should have the boxes turned 90 degrees so the car can't roll off the boxes....that's scary.
    Chief 64, Cosmo49, Chili Phil and 2 others like this.
  8. Actually it is the same, only it would be 1.5" higher.
  9. Blues4U
    Blues4U
    from So Cal
    Using soft wood like pine scares me, we always used hard wood when using cribbing to block equipment up in the air. I guess on an early Ford that only weighs about 2400# or less it's OK. I still don't like it.
    41 GMC K-18 and Desoto291Hemi like this.
  10. 51504bat
    51504bat
    Not wood but I bit the bullet and bought 4 of these. Worth it for the peace of mind, IMO ramps.jpg
  11. 62rebel
    62rebel
    Well... shipyards support many thousands of tons of steel ship hull on wood cribbing..... seldom see any of it fail.
    I would add some rope grips to maneuver them around. I use a LOT of wood blocks like this.
    rod1, Hnstray, ffr1222k and 3 others like this.
  12. twenty8
    twenty8
    Would work the same either way.....
  13. Yes,,,,,Ship yards and many construction people use wood .
    But,,,like Blues4U stated,,,,,,,always use hardwood .
    The shipyard groups use hardwood,,,,,,just like the railroad,,,,,,cross ties are very tough .
    Pine is okay for a light weight vehicle,,,,,but,,,they need to be perfect with no blemishes or knotholes .
    Never use fir,,,,,very soft and an accident waiting to happen !
    Tommy
    62rebel, 41 GMC K-18 and Blues4U like this.
  14. Fortunateson
    Fortunateson
    I believe Douglas Fir is a very dense/strong softwood, way stronger than pine.
    hidez57, clem and Hnstray like this.
  15. rustydusty
    rustydusty
    I built mine out of solid 2x8’s. Guess I tend to overdo it… A1BD8410-0B20-489C-AE9E-BE11EE6AB358.jpeg
  16. alanp561
    alanp561
    Doesn't look like it could roll off. The tires are sitting between the front and rear inside edges, not on top.
    caprockfabshop and Motorwrxs like this.
  17. 19Eddy30
    19Eddy30
    from VA
    Unless your wood , screws / nails Free Race blocks like pictured above ,
    Lighter , can carry all 4 @ 1 time,
    Can set on wheel dolly's move vehicle around in shop
    & work nice with pit Pro jacks
    Just Gary and 51504bat like this.
  18. nochop
    nochop
    from norcal
    Houses too
  19. chevy57dude
    chevy57dude
    8" tall, had enough s**** 2x6 to make 'em.
    vtx1800, brEad, X-cpe and 3 others like this.
  20. theHIGHLANDER
    theHIGHLANDER
    I made mine out of Hein Werner.:p
    C'mon, y'all know I'm a ****. Somebody had to so...
    scotty t, Blues4U and Hnstray like this.
  21. dirt car
    dirt car
    from nebraska
    Just a thought, but as much as I've fretted over an uncooperative caster on my car dollies, why none of the examples were built on casters to provide mobility as well.
    Budget36 and clem like this.
  22. caprockfabshop
    caprockfabshop
    Yeah, the tires sit down inside the opening of the frame, so literally no way they could roll off. Especially with the 16" lengths. Sure if you made them with 12" lengths, then the tires would be sitting "on" the blocks vs "in" them like I have, then it would be an issue.
    rattlecanrods, 2OLD2FAST and alanp561 like this.
  23. caprockfabshop
    caprockfabshop
    Considering that the tires aren't strapped or secured to the framework at all, you've raised the center of gravity and adding in casters would only amplify the risk of catching on a seam in the concrete and the whole thing tipping.
    I keep a set of car skates handy for moving cars around, then once they're where I want them, I jack them up onto the 2x4 stands.
  24. dirt car
    dirt car
    from nebraska
    Considered the condition of my floor while working over a set of car dollies with anchored stands to move a body shell around, with some thought out revisions may try them supporting off a frame as opposed to the wheels. With a bit of caution the stands such as caprockfabshop has fabricated with added end stops, look to be adaptable to casters.
  25. rusty1
    rusty1
    I stand corrected,...thanks.
  26. goldmountain
    goldmountain
    This is what I came up with. Depends on what s**** is available. IMG_1500.JPG
  27. chickenridgerods
    chickenridgerods
    from DSM, IA
    I typically build cribbing from 4x4s simply because it takes fewer pieces to reach the same height. They'll also have a greater bending strength.
    nochop and Desoto291Hemi like this.
  28. Jeff Norwell
    Jeff Norwell
    MODERATOR
    Very Handy.I built mine(4) a few years back and keep them stored for my projects.
    18x18-2x4's
  29. 57 Fargo
    57 Fargo
    How do you trip over stuff when it’s stored neatly Jeff?
  30. Awesome question! I have asked several times on here and ALWAYS forgot to write down the replies! Have some leftover 2x from some Menards packing to use up.
