Edelbrock carbs
Discussion in 'The Hokey Ass Message Board' started by pokey, Jan 22, 2010.
  1. mikeco
    mikeco
    from virginia
    I have no idea what the hell the holy donut is,I don't know you or your cars & apparently from the last post I'm not the only one confused by your posts. Nuff said.
  2. Mike_B
    Mike_B
    Somewhere on the Internet a while back, a Holley engineer said if you can hear the secondaries open, what you're actually hearing in a lean bog. And that a gradual opening is much better for performance. But yes, on some carbs with some engines the vacuum secondaries could open a little sooner, and many are adjustable for that very reason.
    Great info here on tuning with jets, metering rods, and springs.
    https://www.edelbrock.com/media/wysiwyg/do***ents/carb-owners-manual.pdf
  3. sunbeam
    sunbeam
    Loosen the screw the covering the metering rod piston and swing it enough it see the piston but still hold the piston down lightly tighten the screw start the engine and see if the piston is pulled down If not go with a lighter spring
  4. X38
    X38
    13 years.
    jimmy six and Deuces like this.
  5. 2OLD2FAST
    2OLD2FAST
    from illinois
    Opened the dist vacuum diaphragm ???? How is that ?
  6. zman
    zman
    from Garner, NC
    I think after 13 years or so they either fixed it or moved on. lol
    swade41 and Deuces like this.
  7. Deuces
    Deuces
    I love my Holley carbs....:rolleyes:
  8. Mike_B
    Mike_B
    Oh ****! I just now saw the date.
  9. Illustrious Hector
    Illustrious Hector
    Back in my teens, We used to flip the air cleaner lid to make them sound tough. Even kinda worked on 2bbl carbs, Rochesters only though.
    Deuces likes this.
