A friend has a 59 Chevy pick up with 6 cyl I believe it's a 235 cid and needs a fuel pump with the windshield wiper vacuum fitting we search Kanter & Egge without any luck, any other sources out there ? The truck is all original survivor and wants to keep it that way, it's in his family along time and was actually bought from a dealership that was in his home town and has the original paperwork. Any help would be appreciated, Thanks John
Try Napa or the Truck Shop In Orange,Ca (800) 243-8947. Truck shop shows them in their catalog Part #58-8414 pg 107. They have an online catalog.http://www.truckandcarshop.com/
the vacuum pump usually doesn't really do anything useful, you can get a single type pump pretty easily, eh? do that instead.
The vacuum part just helps the wipers work a little better on hills or when accelerating but that is all it does or is on the engine for. A regular single action pump is a direct bolt on with maybe a little line line up issue. I'd just go get the 23 buck one at O'Reilly's to be able to drive the truck and then decide if I want to order the 155 dollar one from Summit. Or hope that O'Reilly can scrounge up one of their 198 dollar ones. Searches show that Jim Carter, Parts Hawk and a couple of others are out of stock on the dual pumps. Personally for the 130 to 170 dollar difference I could put up with wipers that didn't work perfect all the time or add a belt driven or electric vac*** pump. His best bet if he wants to keep the wipers is to use an electric vacuum pump like this one Amazon.com: Auxiliary Electric Vacuum Pump ***embly Fits for Chevrolet Cadillac CTS CAMARO CAPRICE HHR SOLSTICE Saturn Volvo C30 C70 S40 V40 V50 2001-2016, Power Brake Booster 20804130 31317530 009428081 30793053 : Automotive I'm thinking that they are for supplying vacuum for power brakes on Turbo or supercharger cars. My daughter'sHHR isn't a turbo but I can look under the hood and see if it has one. Newport sells a direct bolt in 2 speed electric replacement wiper motor for the vaccuum motor if wiper action is the big issue. New Port Engineering | 1958-59 Chevy/GMC Truck Wiper Motor (newportwipers.com)
Sorry didn't read your post closely enough. I used the Newport Engineering electric replacement on my 1957 Chevy pickup (2 speed). Has worked fine for years. don
