Used reproduction running boards. A couple of the holes have been ovaled and a hole in one of the brackets is tore as seen in the pics. The rubber between the board and frame on the left one has been removed but it would be easy enough to cut a piece of rubber to replace. The last guy did these modifications but you don't see any of it when mounted on the car. These are very good looking running boards.. I was going to use these myself but I ended up with a perfect pair in another deal so I plan to use them. Will be at Frog Follies Friday and Saturday. Can bring with me.
