Tech Info: Cadillac OHV V8's 1949-1962
Discussion in 'The Hokey Ass Message Board' started by Cadillacin Marcus, Jan 19, 2004.
  1. cretin
    cretin
    I know somebody around here knows.
    @Moriarity @Roothawg Do either of you have any insight on that?
  2. Jet96
    Jet96
    from WY
    6736E2FA-36C6-4B2A-9FBF-F5ADA2813F53.jpeg 0879CF18-6B46-4F23-9AED-416ACE9EC37B.jpeg This is my early '49. I hope it helps
    kadillackid likes this.
  3. cretin
    cretin
    That is helpful. Thank you. I have that snout on the front of my ‘49 cam too, so that’s making me think it’s a spring loaded cam as well. Hopefully someone can confirm this.
    These are photos of what I have.
    The first two are the ‘49 cam.
    The second two are what I believe is the ‘55 cam.
    However, I know the ‘55 was different than the rest of the 331’s with the flat back block, but I’m not sure of what other differences there may be.
    70DC7E85-1DC0-43A8-81E3-437D16791A5B.jpeg DB7120AB-E6D7-4D4F-8320-A33F17D06748.jpeg 955E45DC-6FE2-4915-B427-B90FEAE5A52C.jpeg 77E067DB-EF8D-4080-ADB6-E0CEB1606D02.jpeg
    kadillackid and Six Ball like this.
  4. Going by memory, the early 49 has about a 1/2” hole in the snout that carries the spring and plunger that runs against the timing cover. If you need it, I’ll pull the front ***embly off the 49 I have and get a pic for you?
  5. Roothawg
    Roothawg
    Sorry ******, I am Of no value on this one. I have only messed with the later versions.
  6. Here ya go, only took a couple of minutes, early 49 (12 or 14 week production I think)cam snout, 3/4” bore for the plunger and a pic of the plunger ,spring and the thrust area on the timing cover.
    Hopefully this helps. 821780B7-39E3-4A5F-99B9-8B332B3401F6.jpeg BAE269E5-CEB7-42CF-B3E2-87F8CD6561AE.jpeg 1BB1EC01-E25A-4CDF-B8E6-A0C5E302385A.jpeg AF6D8E9E-506A-4937-ADB5-D46DC6B8557B.jpeg 217EA4C8-C196-41B9-B725-EC4349F03585.jpeg
    Dogberg, warbird1, Jessie J. and 6 others like this.
  7. kadillackid
    kadillackid
    Awesome pics Barrelnose, can never learn enough about these....:rolleyes:
    Barrelnose pickup and Roothawg like this.
  8. cretin
    cretin
    Barrelnose pickup likes this.
  9. A pleasure to be able to help.
    cretin and Jessie J. like this.
  10. Jet96
    Jet96
    from WY
    Ok now I'm not sure what the deal is. My cam and the first one in @****** photos have a 7/16" hole in the center. Mine had no spring at all, just ran against the cover. It appeared to never have been opened up. I wonder if that was an early(early) thing and then they switched to the spring/ plunger setup or vice-versa? E8E036AF-AFA5-40AF-8CB0-97033B541477.jpeg
  11. Jet96
    Jet96
    from WY
    My engine serial # is 13,233 in '49 -pretty early in prod. run, but I'm not sure how early. (Two-bolt vc's)
  12. rdtreur
    rdtreur
    Hi guys, need some info on the ‘58 365 I got in my ‘52 coupe.
    I got the heads and pistons out and ready to do a quick hone job and put the stock pistons back in with new ring.
    I got the bores checked by a local mechanic and he said that the lip on the top of the cilinders is not from wear but it’s a lip that makes the head gasket seat properly… it sounded weird to my but can someone tell me if he is correct?
  13. 42merc
    42merc
    Ridge is from ring wear, not designed into the block.
    Automotive Stud and Moriarity like this.
  14. Moriarity
    Moriarity
    SUPER MODERATOR
    Yup, get a ridge reamer and remove the ridge. If you don't there is a good chance of damaging the rings or the ring lands on the pistons....
    Speed Gems likes this.
  15. Roothawg
    Roothawg
    Find a new machinist.
  16. c322348
    c322348
    If you can catch it with your fingernail it needs to be removed. Your new rings will have sharp edges and can get damaged hitting that ridge. Clean it first and check it!
  17. Speed Gems
    Speed Gems
    Talk to a machinist Not A mechanic about rebuilding your engine.:rolleyes:
    Jet96 likes this.
  18. rdtreur
    rdtreur
    thanks for al the info guys:)
    i do feel the ridge with my finger but the old pistons came out with a slight tap with a rubber hammer.
    What do you mean by damaging? Is that during installation or while the engine is running?
  19. Roothawg
    Roothawg
    59E39677-EE0B-44BD-A802-29843A1E9A3C.jpeg Question: Do all Cadillac script valve covers have the big honking harness bracket in the middle? Mine do. Just wondering if I should look for an earlier set? I think it disrupts the whole vibe. They look to be fairly well attached also, spot welded in several places.
  20. Moriarity
    Moriarity
    SUPER MODERATOR
    damage while the engine is running, the ridge needs to be removed
  21. Moriarity
    Moriarity
    SUPER MODERATOR
    here is a youtube video on ridge reaming
  22. Automotive Stud
    Automotive Stud
    If you are careful with a die grinder you can remove the head of the spotweld and remove them, I did it on my '55 set. That said, the 50-53 valve cover doesn't have them. Some even have neat wire looms along the back and bottom built in, try to find a set of those.
  23. Roothawg
    Roothawg
    That’s what I was thinking. Thanks
  24. Adrenaline
    Adrenaline
    Are these pins on the heads removable? Most aftermarket intakes dont appear to be cut for them including 2 of the 3 i have on hand. 20230823_202549.jpg
  25. Roothawg
    Roothawg
    Yes, they are just dowels.
  26. Bird man
    Bird man
    from Milwaukee
    Photo 229 give me the shivers. If that valley pan was gl*** beaded or sand blasted, it should be dis***embled or tossed
    to keep unmentionables out of that new engine.
  27. Roothawg
    Roothawg
    Nah, it will be blown out dipped and then chromed. Besides, you should have seen the **** that was living in there when I tore it down. Carbon the size of your fist. Plus, it's for breather air only.
  28. Adrenaline
    Adrenaline
    Im ***uming i just need a good grip on them then and theyll wiggle out. Thanks!
  29. Adrenaline
    Adrenaline
    Last question for a bit (i cant get the pins out...). Im removing a hilborn mechanical fuel injection system with a cam driven fuel pump. Whats the piece called that connects the pump to the camshaft? If i remove the one shown is there one without the snout that replaces it or do the bolts just go through the gear? Thanks! 20230824_182029.jpg
  30. Roothawg
    Roothawg
    That’s a “spud”. The bolts are just like a sbc, they hold the spud on and go through to the gear. Easy Peasy. You got this.
    Does it have a roller cam by chance?
