Technical Ford FE 352 ID help
Discussion in 'The Hokey Ass Message Board' started by theHIGHLANDER, Aug 28, 2023.
  1. theHIGHLANDER
    theHIGHLANDER
    I could wade thru several results of Google word salad but I prefer to ask the brain trust that is the HAMB. I only know that lots of FE blocks say 352 on the front, but where, how, etc, can you tell what you have beyond the door tag? All I can see is an FE with an iron 4bbl intake (adapted to a 2bbl). Casting numbers, stampings, anything that I can see in the car would be helpful. This is a 1960 with a Y code, and thank you for your help.
    dana barlow and Deuces like this.
  2. squirrel
    Casting numbers help, the Engineering number (C0AE-....) is a good start, and you'll likely find a casting date code also, format number letter number, on block, heads, intake
    From what I can tell, you can positively identify an FE by measuring bore and stroke....good luck...
  3. theHIGHLANDER
    theHIGHLANDER
    I doubt a lot has been done if ever, she's 14,000 original miles. Trust but verify, right?
    Deuces likes this.
  4. squirrel
    I'd start by looking for casting dates, and compare to the production date of the car on the body tag.
    Deuces likes this.
  5. FrozenMerc
    FrozenMerc
    1960 Y code should be a 4 bbl 352, 300 Hp. That said, any FE after 60+ years should be measured to verify. Even with only 14,000 miles, some one dinked around with it by swapping a 2 bbl on, so who knows what else was changed. Pull a spark plug and measure stroke with a straw.
    3.5" = 352 or 360. 3.75" = 390, 406, or 427. 4" = 410 or 428.
    The 352 cast into the block means absolutely nothing. My 1962 Mercury 352 doesn't have that particular casting mark, where as my 1976 390 did. Go figure.
    Deuces likes this.
  6. In that year range it ain’t a 360:)
    Crank numbers might help
    If it still has a tag from the factory near the coil.
    My 352 did.
    But bore x stroke is how we normally figure em out
    Truckdoctor Andy and Deuces like this.
  7. FrozenMerc
    FrozenMerc
    Why Not? Edsels came with 360's starting in 1958.
    Spooky likes this.
  8. squirrel
    wasn't that a 361? (at least that's what they called it, I know Ford liked to play with the numbers on FE engines depending on what they were installed in)
    RICH B, Spooky, deathrowdave and 3 others like this.
  9. lostone
    lostone
    from kansas
    When I picked up an old ford truck it had either a 352 or 390, they couldn't remember which motor it had at this time, several motors in and out of it I guess....
    Anyway I was told by many that the only way to be surr was pull a spark plug, put cylinder on bdc, drop a long plastic straw in the hole and mark it. Then carefully turn motor over by hand and bring it to TDC and mark it. Then again go back to bottom dead center and double check mark on straw, if it still lined up pull straw and measure between marks, this would be the stroke and tell me either 352 or 390. Any other way was futile without dropping oil pan...
  10. Day 2
    Day 2
    from ga
    Head numbers are easy, they are in between the two center ports.*
    Spooky and Deuces like this.
  11. 62rebel
    62rebel
    I'd bet that it's a 352 because 390's weren't common fare for fullsize Fords in '60. Most V8's were either 292 Y-blocks or 352's. Still nothing to sneeze at if you put the work into it. Not as easy to find as they once were (I had about ten of them at one time, all over the place; 352's, 360's, 390's... gave 'em all away)
    Spooky, dana barlow and Deuces like this.
  12. squirrel
    The date code in day2's picture, 0E6, is May 6th, 1960, eh?
  13. sunbeam
    sunbeam
    390 wasn't an option until 1961
    Spooky and finn like this.
  14. RmK57
    RmK57
    the 361 E-400 Edsel was a .040 overbore on a Ford 352.
    Spooky likes this.
  15. Nope. Referring to the 360 truck engines.
  16. theHIGHLANDER
    theHIGHLANDER
    For what I can muster so far it's a 352 4bbl, likely yes, the original. I recall those OEM 4bbls being problematic for some folks, and fuel mileage wasn't great with these land yachts. I can't see a lot of changed out fasteners or such, exhaust still intact, etc. We hope for special but a low miles 4bbl Starliner is special enuff...;)
    bchctybob and Deuces like this.
  17. BLACKNRED
    BLACKNRED
    FE - 352 is the engine series, 332,352 390
    351 Cleveland - 335 series, 302, 351
    429-460 - 385 series
    please correct if I am wrong
  18. Casting numbers on the block will sometimes only get you into the ballpark, although in this case the 352 was the only FE motor available that year, so a C0AE number will pin it down.
    FE engine availability by year...
    '58-59 332, 352, 361
    '60 352
    '61 352, 390
    '62 352, 390, 406
    '63 352, 390, 406, 427
    '64-65 352, 390, 427
    '66-67 352, 390, 410, 427, 428
    '68 360, 390, 427, 428
    '69-70 360, 390, 428
    '71-76 360, 390
    The 360, 390 and 410 all used the same block (except for the '61-62 390 HiPo motors, those were solids lifters only). The 406 and 428 share bore size, but the 406 is solid lifters only.
    There are some bits of weirdness on the early FEs. A late block can be installed in place of any early block but not vice-versa as Ford added motor mount bolt bosses over the years. There's an indexing pin for the intake manifold to the right of the distributor on the block that got deleted later, that has to go away if using a newer intake manifold. And the biggie, the early ('58 to '61, maybe '62) motors didn't use a thrust plate for the camshaft but rather used a '****on' similar to what SBCs used. This part is long obsolete (along with the matching timing set), I believe if you need to change the timing chain you have to replace the cam also, as well as drilling/tapping the block for the plate. Look for a steel timing cover, that's usually the giveaway. Ford switched to an aluminum cover when they added the thrust plate.
    One good thing about the early blocks is they aren't thinwall castings (up through about '61?). There are credible reports of boring these .130" over for 428 conversions, although sonic checking is recommended. Ford bored them .050" over for the '361' Edsels...
  19. sunbeam
    sunbeam
    If I had the ending letter off the distributor it might narrow it down unless the last number is an A
  20. s55mercury66
    s55mercury66
    from SW Wyoming
    The 332-428 fe engine forum can probably help you more than any other place on the net, but to be sure, the bore and stroke will need to be measured, a borescope through the oil pan drain plug might get crankshaft numbers. My 1966 428 also has that "352" cast into it.
  21. Deuces
    Deuces
  22. mgtstumpy
    mgtstumpy
    Is it a 2 or 4 bolt engine mount block, as that narrows it somewhat. 427s are easier as they're cross bolted. 428 information attached.
    The best way to identify an FE is to measure bore and stroke. Block castings 352 was used in a few engines. www.mustangtek.com
    There is a pad on the right rear of the block on the vertical surface below cylinder head. If there is a stamped serial number and 4 engine mount bolts, it would be circa/post 1968.
    Check casting date on underside of oil filter adaptor
    Look for casting number on block
    Spooky, loudbang and Deuces like this.
  23. theHIGHLANDER
    theHIGHLANDER
    I looked for that casting #, someplace say it's in one spot, some in others, I do have a latent fondness for some Ford stuff but thier numbers can make you feel like Wiyle E Coyote sometimes. Still, I'd raise a rt hand about 90% up at the moment that it's the OG. Frankly the rest of the car really helps too.
    Maybe not the place to shift into another gear, but at some point somebody was going to pull all the window moldings and replace them with chrome vs painted red. I'm seeing Starliners in my head when I lay down I've looked at so many. Not a 1 with interior chrome but they're OEM parts, not somebody's haul to the plater. Lots of cases to solve here.
    Deuces likes this.
  24. sidevalve8ba
    sidevalve8ba
    One of my all time favorite Fords. I hope something similar to this is what you are looking at, Highlander.
  25. theHIGHLANDER
    theHIGHLANDER
    Ok, **** it...
    FE, auto, 14k orig miles. Original paint (yes it's as good as it looks there). Gotta cut, polish, re***emble the interior (weird) and get those old man Tom Terrific wheel covers swapped to smalls and blackwalls.
    GordonC, Spooky, warbird1 and 10 others like this.
  26. 56don
    56don
    That hood ornament is kinda rare I think. Nice looking car. My dad had a 60 Ford. I hated it, the doors were 2 feet thick. But after all these years, I like 'em now.
  27. Budget36
    Budget36
    Re: the 352 casting on the side of the block.
    Years back a guy pulled a 390 out and stored it at my dads place. Was under the bench covered in a tarp.
    Fast forward 20 or so years and I have a buddy over that “was all Ford”. He asked what was under the tarp, told him a 390. He wanted a look at it.
    So he spots the “352” and tells me “not a 390, see that “?
    I’m like damn, I don’t want a 352, let him haul it home.
    Years later found out that yes, was a 390.
    Not that I had any use for it, but dang it pissed me off.
  28. Jeff Norwell
    Jeff Norwell
    MODERATOR
    As said..ALL FE's had "352" cast upon the block.
    Do a bore and stroke measurement for certain.
    I was fascinated with Brent Lykin's adventure on his Junk yard 352 build.He took a lowly 352 from Zero to Hero....
    Anyhow.. they are a great engine.. but 95% were just simple garden variety transport... and then used in trucks with the 360 as well.
    The early ones (58-61 were the best blocks(thick))... Not the friendliest on fuel.. but who cares.
    Brent did a series of vids from the beginning to the end result.
    https://www.enginelabs.com/engine-t...power-naturally-aspirated-352-ford-fe-engine/
    Spooky, warbird1, Deuces and 2 others like this.
  29. Jeff Norwell
    Jeff Norwell
    MODERATOR
    and yea.. Starliners are super dreamy........
    Spooky, Deuces and theHIGHLANDER like this.
