Technical Inglese Quad DCNF Weber Manifold And Distributor Drive
Discussion in 'The Hokey Ass Message Board' started by Joseph G Smith, Mar 18, 2023.
  1. Joseph G Smith
    Joseph G Smith
    335657344_3446145022308620_157342242148481506_n.jpg 335614754_614046630641795_5354553918306985877_n.jpg 335657344_3446145022308620_157342242148481506_n.jpg Hello,
    I have just bought an angled distributor drive for the Inglese Quad DCNF Weber manifold I have a question relating to the oil requirements for the distributor drive. Does anyone have or know anyone who has a copy of the original Inglese installation instructions.
    A Distributor drive was just sold on Bring a Trailer by Dogleg to Badhorse with a copy of the instructions so i was wondering if any were around.
    Regards
    Joe.
    Deuces and Duntov1967 like this.
  2. Duntov1967
    Duntov1967
    You could call Jim Inglese directly. He may have a copy.
    2OLD2FAST and Deuces like this.
  3. Magfiend
    Magfiend
    I NEED that!!!
    Deuces likes this.
  4. Fordors
    Fordors
    While I don’t remember ever seeing one of these I found info online that Jim Inglese may have only made 25 or so of the distributor angle drives.
    The first photo shows one installed on an inline manifold and based on the two holes noted in the second photo there must have been bosses cast on the manifold to bolt it down using those two holes. Also, the set screw in the casting was probably for adjusting the flow of oil to the distributor gears. The 90* fitting at the top is rotated a bit too far clockwise and over the years the tube got bent. If that fitting was further back the aluminum tubing could line up with a 90* fitting screwed into the 1/8” NPT hole behind the manifold to lube the distributor gears in the drive.
  5. Duntov1967
    Duntov1967
    Yep.
    Deuces likes this.
  6. Deuces
    Deuces
    From another thread.... s-l1600 (49).jpg dcnf1.jpg dcnf 8.jpg dcnf 7.jpg dcnf 6.jpg dcnf 5.jpg dcnf 4.jpg dcnf 3.jpg dcnf 2.jpg
    Tman likes this.
  7. rob-redm
    rob-redm
    never seen that set up before.. crazy... and the drive for the distr. is nuts.. Hope you find the instructions you need..
    seb fontana and Deuces like this.
  8. I have one of those on my Cobra replica and it goes very well; the DCNF is what you might call a 'sophisticated' carb. The oil pipe you tee-off just behind the distributor on the block, where the oil pressure take-off often goes.
    BUT this arrangement supplies way too much oil considering the drive has no real drain back to the block. Mine leaked oil all around the distributor itself. You need to EITHER create a proper drain into the block OR don't use the oil feed but top up the drive with oil from time to time (I did the latter).
    I also tried restricting the oil feed using a carb jet but that did not help.
    Hope this helps.
    Myles
    sdluck and seb fontana like this.
  9. Joseph G Smith
    Joseph G Smith
    Thank you all for the information.
