Projects T on A : Fjant the complete novice builds a hot rod
Discussion in 'Traditional Hot Rods' started by Fjant, Aug 2, 2020.
  1. Fjant
    Fjant
    from Sweden
    I had my first start up today and it was very succsessful! A small leak from the carburator, but I think I know whats up so I will try to find the right part and fix it. I’m very happy it went so smooth and fired up straight away and everyting seams like it works as it should.
  2. j hansen
    j hansen
  3. Anders W
    Anders W
    Om det kommer bensin i hålet för axpumpen så känns det som att flotörnivån är lite hög. Anders W
  4. Fjant
    Fjant
    from Sweden
    Okej! Ska kolla på det! Det sitter en packning av skinn nedanför som såg gammal ut, men då kanske det inte läcker uppåt. Jag justerar nivån och försöker igen. Tack så mycket för tipset.
  5. warhorseracing
    warhorseracing
    from cameron wv
    ^^^^^^Can you please translate @Fjant?
    Stogy and Fjant like this.
  6. Cool old fjord
    I’d drive ijt
  7. Two things to say here.
    One is that your English is just fine. You are totally understandable.
    Two is that a T on an A is an excellent starting place. And who does not love a tub. Good start my friend.
  8. Fjant
    Fjant
    from Sweden
    Were debating the fuel leak in the carburator. That its probably the floater level thats needing adjustment.
    Stogy and warhorseracing like this.
  9. Fjant
    Fjant
    from Sweden
    Thank you! Yeah I like a good T just as much as a -32 or so.
    Stogy likes this.
  10. trevorsworth
    trevorsworth
    On one of the 97s I was working on the needle stuck open and wouldn’t shut off flow even though the float was not stuck or sunk or set wrong. Make sure everything is clean and moves freely.
  11. Fjant
    Fjant
    from Sweden
    Thank you for the tip! I will check it out.
    Stogy likes this.
  12. warhorseracing
    warhorseracing
    from cameron wv
    Yes your English is excellent it is my Swedish that is not. I know enough to know that it is was fuel related but wasn't clear as to what the problem was you were discussing.
  13. Atwater Mike
    Atwater Mike
    Check fuel pressure at carburetor! 97s like 3.5 p.s.i. (2 kp) is max. A needle/seat situation.
    Nice progress on the tub. (I just bought another '27 T tub body for some panels, and have a third rear section from the 'B' pillar onto the back)
    I sold my one '27 fuel tank, darn it! Thought I'd use something larger... Wish I'd kept it, as yours tucks away nicely.
    I learned to solder while building Control Line model airplanes: fuel tanks, landing gear, modified bellcranks... I laugh now, because the biggest part was cleaning and tinning. I said then "Wish I could just weld this!"
    The guys all laughed. Your soldering is like welding: PRACTICING! That was all it took. Good job!
  14. Fjant
    Fjant
    from Sweden
    Yeah. practicing like everyting, and don't be afraid to try! And yeah much cleaning to get it to work, but cute fun when you get it to work and learn a new thing.
    I have a 2 psi fuel pump so I hope thats not the problem. I was a bit cheap and only baught a set of new gaskets for the carburator, I hope I don't have to tear it down and change the other parts, but if I have to it won't be a problem.
    Sounds like you have a nice bulid coming up then! hope to see it here on the hamb!
    Stogy likes this.
  15. Stogy
    Stogy
    Go @Fjant Go!!...awesome project...you're must be pretty excited now that it's breathing 4 banger fireballs of power...
    Pretty smooth running mill that is...
    Fjant and Outback like this.
  16. Fjant
    Fjant
    from Sweden
    Haha yeah! Very happy indeed!!
    Stogy likes this.
  17. Fjant
    Fjant
    from Sweden
    Well this put a very big smile on my face!!!!
    Unfourtumaly the carburator started to leak realy bad everywhere. So no more drives until that is properly sorted out.
    don colaps, Stogy, alchemy and 8 others like this.
  18. Outback
    Outback
    from NE Vic
    Looking good! Those first drives are always fun, in some form or another! & if they go well a real boost to enthusiasm :D
    Stogy, Fjant and warhorseracing like this.
  19. trevorsworth
    trevorsworth
    Yeah!!! That's a tough lookin tub there!
  20. Fjant
    Fjant
    from Sweden
    I think I sorted out the fuel leak. Put in a new fuelpump with even lower preasure (about 1,5psi) and redid one of the fittings at the carb. I have some back-fiering when I release the throttle and the radiator is leaking somewhat. But other than that it works good. I’m going to put a temp-meter in it as next thing because I really what to know if the temperature it going off.
    But I am very happy right now! here is a short video of the trip around the village.
    don colaps, 69fury, Outback and 7 others like this.
  21. Stogy
    Stogy
    Congrats fgant...I was wondering fuel pressure as well...nothing worse than fuel spraying everywhere...gets one scurrying for shutdown and mopping up...:eek:
    Been there done that...do you have a pressure gauge to reflect what's being pumped even though the pump is rated?
    Fjant likes this.
  22. Fjant
    Fjant
    from Sweden
    yeah. Not fun at all. But I’m glad I sorted it out. No gauge but I think I will but one in in the future.
    Dick Stevens and Stogy like this.
  23. Martinbuilt
    Martinbuilt
    Fun video, although your kid was making me nervous.
    My doors never stay shut...
  24. Fjant
    Fjant
    from Sweden
    Did not think of that. I might do some sort of extra lock for the p***enger door . They do seem to sitt very tight, and I have rebuilt the locks with quite strong springs. But I havent driven it so much yet so I don’t really know how the doors will handle the body flexing.
    brEad and warhorseracing like this.
  25. Fjant
    Fjant
    from Sweden
    Hi!
    The have not been any big progress on the car this winter. A lot of other stuff that had to be done, less energy than usual and a hard case of phneumonia. but I have done the wiering done. I had to redo some stuff that did not work with the old parts. Still hav not succed in getting all the gauges to work but thats secondary. Got most of the interiot done and have sorted the fuel leaks (renovated the carburator and mounted a fuel preasure regulator).
    Got the car out running two times now. Most of it works as it should. But it seems like fumes from is leaking in to the cooling water. So I have to renovera the top and get it shaved (or get another one that is staight). Hoping to get that done next week.
  26. patsurf
    patsurf
  27. Outback
    Outback
    from NE Vic
    How cool! Well done with persisting!
    Fjant and nunattax like this.
  28. Bigcheese327
    Bigcheese327
    Wow, this thing is jaunty. Very inspiring.
    brEad and Kelly Burns like this.
  29. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    What a neat tub. Looks like a blast!
  30. Martinbuilt
    Martinbuilt
    I love it.
    You've made a bunch of good choices. It all looks great together.
    Fjant likes this.
