Technical 1951 Cadillac fuel tank internals
Discussion in 'The Hokey Ass Message Board' started by Codizzle, Aug 29, 2023.
  1. Codizzle
    Codizzle
    Trying to revive my original fuel tank. Tank has been cleaned and recoated/sealed. However, the fuel supply outlet is clogged. My question:
    Is there a internal fuel line? If so, does anyone have a picture or diagram? Maybe some ideas on unclogging? I tried blowing air but it's not getting thru.
    Thanks,
    Cody
  2. 302GMC
    302GMC
    from Idaho
    Isn't it in the sending unit ? Drop tank, unplug ...
  3. Codizzle
    Codizzle
    No sending unit is on front of tank. Fuel supply is lower left (driver side) front corner
  4. 49Olds
    49Olds
    Plug the original line. Remove the sending unit to drill and run a line through the sending unit housing. Easier to service. Not the best to have the fitting at the lowest part of the tank anyway.
    Codizzle likes this.
  5. BJR
    BJR
    I believe it has a tube that goes from that fitting to the low spot in the tank. You may be able to open it up with a wire. But if you have a big cubic inch engine you may not get enough fuel through it.
  6. Codizzle
    Codizzle
    The sending unit is high on front face. Z shaped line to get lower in tank? You mention drilling thru sending unit housing. Do you mean the flange? How do you seal it?
  7. BJR
    BJR
    I have drilled the flange of a sending unit and soldered a copper tube into it for a fuel pickup.
  8. 49Olds
    49Olds
    You can use a br*** union/coupler (or an AN fitting) in the drilled hole in the sending unit. With an inverted flare on each side of the union you can connect a Z shaped line into the tank with a standard fuel tank sock on the end. Or, you can braze or solder the line to the sending unit.
