Projects 1920's era underslung Special build
Discussion in 'Traditional Hot Rods' started by chrisp, Aug 30, 2023.
  1. chrisp
    chrisp
    So since I started my A RPU I decided that it was time to really start on the special also because why not?
    Some of you have seen pictures of a quick mock up for it before. Now it's taking space in the shop and I need the frame table for something else so instead of shoving it back under the work bench I decided against my best judgement to actualy build it, this build might be faster than the A.
    The plan is to build a race inspired car based on a '23 Zedel CI6 upside down ch***is for that underslung look, 50's Chevy front springs, late 20's Citroën C4 I-beam, '33 Ford spindles, F1 steering box, 2.4L Jaguar engine maybe blown via a Constantin blower, LT77 5 speed from a Morgan I believe, a Matford banjo rear or something ***embled from a E-83 Ford banjo, friction shocks, most likely '42/'48 juice brakes and a '28 Renault hood with probably a hand made body.
    First order is to modify that Citroën I-beam, I cut the boss and pivot for the mechanical brakes. On the first pictures I had round back spindles on there, they kinda fit, the steering arms clear the beam but I don't want a cross steer set up and don't want something too hot rod inspired, so I'm using some '33 ford spindles.
    The I-beam requiered some modification to fit those spindles with later type Ford bearings. I still need to machine a sleeve for the kingpins, because the Citroën ones were m***ive. I will need to bend the steering arms though.
    A quick mock up of the Citroën C2 friction shock, originally on the Citroën C4 the friction shocks were parallel to the frame had one arm only and bolted to the I-beam on that big fat bolt next to the kingpin. It looks too bulky so I place my shocks parallel to the frame with a C2 rear mount as my front lower mount and on top of the spring what I believe is a Peugeot 203 pick up rear end spring hanger as my upper mount. I'm thinking it could double as a headlight mount also.
    I need to fabricate the mount for the Jaguar spring shackles, then the front springs will be done. For the front I made a spreader bar threaded on the inside to act as the blower support and for the front of the spring bolt to bolt into.
  2. Dave G in Gansevoort
    from Upstate NY
    Interesting nose. Like the concept...
    Stogy likes this.
  3. Max Gearhead
    Max Gearhead
    from Wisconsin
  4. Outback
    Outback
    from NE Vic, Oz
    I love underslungs! Will follow along :D
    Stogy and chryslerfan55 like this.
  5. Commodoreswab
    Commodoreswab
    from West TN
    I have a goal to build one and started the long slow search for parts. So far I have a radiator and m***ive 5 spoke steering wheel. The goal is to use a comet as inspiration. Circa 08-10 double chain drive ect 5832e6c29d277_1910CometHallScottracer1.jpg.d7c9fa79b5946d35cb97c47707d549a7.jpg
    gnichols, V8-m, Unkl Ian and 17 others like this.
  6. Nobey
    Nobey
    You'll have to run really big wheels and tires. What are you planning???
    Stogy likes this.
  7. chrisp
    chrisp
    That thing looks cool
    650-19 up front minimum should do the trick. I'd like steel disc wheel, I actually have a set but I don't think I'll be able to use them because the disc is not centered. I wanted to change the almost 19" hoops but they are ***ymetrical so it's not feasible. I have a nice truck metric disc wheel but it's about 32" so that's way too much, finding 3 identical others is almost impossible plus tires will be a problem.
    I'm keeping my eyes open for Panhard, delage or delahaye artillery wheels 19" or 20". I don't want rudge wire wheels even though it would make things easier.
    Stock Model A could work also.
    41 GMC K-18, Stogy, Okie Pete and 4 others like this.
  8. Mr48chev
    The American Underslung Automobile was built from 1905 to 1914. I've got to agree that it takes a big diameter wheel to carry it off.
    The Ch***is shot shows that they had what amounted to an upside down C notch in a pretty straight frame to carry itoff.
    Both the white and black cars are/were 1908 50 HP cars.
    08-American-Underslung-50HP_DV-15-BHA_04.jpg 08 Underslung 50 Roadster.jpg 14-American-Underslung-644-DV-14-AI_01-800.jpg
    Stogy, Rolleiflex, Okie Pete and 6 others like this.
  9. Interesting project ya got there. Needs a banger though. He he.
  10. chrisp
    chrisp
    It's not a V8 at least.
    If only I could afford a Miller or Bugatti 4.
    I love the look of the Jag 6, especially with the smooth valve covers it ages the engine a bit, to age it even more I have an XK120 oil flter, MK X intake manifold and a 4.2L E-type aluminum oil pan that will be modified to age it further. I'd like to stick the distributor to a camshaft through the firewall à la Bugatti, but that might be way out of my league.
    I draw my inspiration from the Millers, Indy Peugeots and the Panhard Razor Blade, race cars from the 20's and 30's in general.
    I love the American Underslung, they look elegant and racy at the same time, they should have been European :D.
    41 GMC K-18, Stogy, Ned Ludd and 4 others like this.
  11. Bandit Billy
    Bandit Billy
    I like it! Not as much as the 2nd guy from the left in the photo, but I would love to build one.
    Stogy and 41 GMC K-18 like this.
  12. 41 GMC K-18
    41 GMC K-18
    Underslung race cars are unique.
  13. Dave G in Gansevoort
    from Upstate NY
    What's really neat about the ch***is, is look at the rear springs rear mounting "irons". Were they forged with big machinery, or by a blacksmith by hand?
  14. Outback
    Outback
    from NE Vic, Oz
    I started building an Underslung Chev years ago. But life changed & the project stalled.
    Stogy and Bandit Billy like this.
  15. Bandit Billy
    Bandit Billy
    Still have it?
    Stogy likes this.
  16. F-head
    F-head
    This thing is gonna be cool
    Can’t wait to see progress
    Stogy likes this.
  17. Outback
    Outback
    from NE Vic, Oz
    Mostly, I had a very hot lil Aussie GM 6cyl built for it, that is gone the rest is here.
    Stogy likes this.
  18. Commodoreswab
    Commodoreswab
    from West TN
    If I'm not mistaken that is a Frontenac and regular i.e. not underslung.
    Fyi the motor on the comet circa 08 was a V8 so it doesn't have to be a banger but a period v8 is very difficult to find. An early Cadillac would be an option for 20's. Regarding wheels my $.02 is a good set of discs would be killer but $$$$$ with the other option tall wires. Trying to get a handle on the size of the car but I'm guessing something larger than a T or A and you will need larger wheels to pull it off. Have you thought about wood spoke, maybe off something like a Buick? I have a 29 Buick (new acquisition) and have been looking at the ch***is a bit. The wheels dwarf a 21 inch T/A. The brakes/diff/frame ect all look like they would fit the period you are looking to build with modifications of course. The old Buicks can often be found cheap due to mostly wood bodies that are too much work to restore. Just a thought.
    Unkl Ian, Stogy, Okie Pete and 3 others like this.
  19. 41 GMC K-18
    41 GMC K-18
    The original picture was a poster, from a 1921 Race, at the Tacoma Speedway.
    So it may very well be artistic license from the artist or it may very well be a "Frontenac" as you have indicated.
    I really don't know.
    To my eye, the front springs and their position "appears" to curve upwards, which made me think it was an underslung suspension.
    Stogy likes this.
  20. chrisp
    chrisp
    The size is about a '32 Ford, I'm in Europe so 20's American car parts are not really a viable solution. I did looked at early spoked wheels precisely steel wheels that mimic wooden spoke wheels, I have my eyes on a set from a Delage, they are 20" but they are of the knock off type unlike the Panhard that where 5 lug nuts. On the other hand Panhard wheels are harder to come by.
    My problem with rudge type hubs is that it would requier an adaptor piece to mount on the drums and I'm guessing it's gonna screw up my scrub radius.
    Stogy, 41 GMC K-18 and Outback like this.
  21. RMR&C
    RMR&C
    from NW Montana
    Following! I love this kind of build!
    Stogy likes this.
  22. noboD
    noboD
    OK, I'll watch. I like different.
    Stogy likes this.
  23. caprockfabshop
    caprockfabshop
    I knew I'd seen that nose before:
    Indiana Jones and the Last Crusade
    gnichols, Stogy, Jeff34 and 3 others like this.
  24. chrisp
    chrisp
    Yep '24 through '29 Renault NN round emblem till '26, diamond shapped after. Radiator behind the engine until '29, when the radiator moved in front they put a grille in the hood.
    I narrowed my hood by 10cm to get it more streamlined.
    You should look up the Renault 4O CV race cars, those things were wild.
    hfh, Stogy, 41 GMC K-18 and 3 others like this.
  25. 35chevmn
    35chevmn
    from mn
    Nice photo!
    Cgrgrspt10 and Stogy like this.
  26. chrisp
    chrisp
    Finally I'm done with the front crossmember, for now it's bolted in, will be riveted when the frame is done.
    It's a really tight fit but I wanted to be able to place the engine as much forward as possible which isn't that easy with that suspension and hood.
    Here's how it looks like with the hood
    And I found some 23" wheels. Not disc wheels but the next best thing.
    They're 5 lugs and I will need to redrill my drums for them to fit.
    hfh, Unkl Ian, Okie Pete and 12 others like this.
  27. Coming along nicely!
    Stogy likes this.
  28. moparboy440
    moparboy440
    from Finland
    Looking good!
    What are those 23" wheels from?
    Stogy likes this.
  29. chrisp
    chrisp
    I believe they are British accessory wheel. I don't remember the brand, but it's stamped on them.
    The older gentlemen I bought them from used to have a Vermorel but he never got to mount them on luckily for me.
    He didn't know exactly how to measure them but I took a gamble and bought them without seing them in person. Let's just say it was an excelent deal worth the risk compared to what they go for in the UK.
    Okie Pete, Outback and moparboy440 like this.
  30. ronzmtrwrx
    ronzmtrwrx
    Very cool project. Not sure how I missed it. I'll be following along.
    Unkl Ian likes this.
