Technical 30-31 rear fender width
Discussion in 'Traditional Hot Rods' started by hurlbird, Aug 24, 2023.
  1. hurlbird
    hurlbird
    wonder how wide the factory fenders are. I have a banjo rear end on my 30 and my tires are 12" outer measurement from the body. I ask because I am considering rear fenders. Thanks!
    -Brent- likes this.
  2. A 2 B
    A 2 B
    from SW Ontario
    Measuring from the mounting flange to the inner edge of the wheel lip is 11 7/8". Keep in mind that you will need to source the best originals you can find or ask this same question from whoever is reproducing these fenders. Beautiful car.
    I agree with enjoying the car as is for the time being and keep your ear to the ground for a nice set of fenders to come along. Good luck!
  3. hurlbird
    hurlbird
    Thanks!! Yes ill search. Bob them...Thinking about a hood top too...
  4. 05snopro440
    05snopro440
    I just measured my repro steel 28-29 coupe/roadster/pickup rear fenders for curiousity sake. I got 11-1/4" from back of the mounting flange to inner edge of the wheel lip on both fenders. I'm not sure how different they are from 30 fenders, but in the same ballpark. That measurement was unmounted.
  5. hurlbird
    hurlbird
    thank you!!! I know there are differences ......
    05snopro440 likes this.
  6. Glenn Thoreson
    Glenn Thoreson
    from SW Wyoming
    Some of the vendors for early Ford parts have several widths of rear fenders for this situation. Speedway Motors may have them, too.
    dirt t and hurlbird like this.
  7. hurlbird
    hurlbird
    how far below the rear of the body of the 30/31 does the factory fender go? looks like 7" from pictures?? thanks
  8. A 2 B
    A 2 B
    from SW Ontario
    I could only guess but I have a good pic that may help. I have two sets of original stock fenders, unfortunately not mounted on a car and a set of modified fenders on my 30 coupe that mount differently, are tubbed and raised. A 6.jpg
    You are contemplating bobbing the rear fenders. There are numerous example pics on the HAMB to compare.
  9. hurlbird
    hurlbird
    wow those look very long . thank you for posting.. ideally id want them a few inches after the body but of course want the factory edge. Hmmm
  10. A 2 B
    A 2 B
    from SW Ontario
    That is the original factory built look with the spare tire mount removed. The car sits on 19 inch wires and being raised up on wheel dollies, it accents the length somewhat. I still have that set of fenders and could determine how low they go by measuring from the duo-lite mounting holes.
    Once you have a set in hand you will easily determine where to cut them based on the look you are after.
    hurlbird likes this.
  11. j ripper
    j ripper
    from napa ca.
    A push/intrusion bar on some modified bumper brackets helps out a bit with the long fender look.
    05snopro440 and hurlbird like this.
  12. Phil Brown
    Phil Brown
    3" shortened fender with 32-style rear spreader bar
    12"wide inside at the top of the fender
  13. trevorsworth
    trevorsworth
    I honestly love to see long fenders framing a banjo on a full-fendered trad rod. To each his own but I would never bob fenders.
  14. hurlbird
    hurlbird
    those are gl***? buy them that size? thanks
  15. Phil Brown
    Phil Brown
    No there original steel, I just cut the 3" section just below the fender brace. The two pieces fit back together fairly close when cut there
  16. 05snopro440
    05snopro440
    Any more photos of that bar?
  17. j ripper
    j ripper
    from napa ca.
  18. hurlbird
    hurlbird
    nice i really like that
