Technical Trying to get 283 Running
Discussion in 'The Hokey Ass Message Board' started by guthriesmith, Aug 26, 2023.
  1. Budget36
    Budget36
    So happy that you get to keep your card;)
    guthriesmith likes this.
  2. guthriesmith
    guthriesmith
    LOL! I was just tagging you asking if I could keep my card. :D
    And...it even just sits there and idles like a champ.
    We seem to have one less messed up 283 on the HAMB now. :cool:
  3. guthriesmith
    guthriesmith
    Even found a use for the custom valve covers I modified in high school while I watch all the rockers get oil. Picture was to hide the ugly distributor so my pic wouldn’t get pulled by our buddy @Moriarity. :D
    loudbang, winduptoy, Budget36 and 7 others like this.
  4. poco
    poco
    from oklahoma
    We knew you would get it fixed
  5. bobss396
    bobss396
    My brother made a set years ago, with holes only, just enough to get a socket on the nut. It cut down on the mess quite a bit.
  6. guthriesmith
    guthriesmith
    Yea, if I were to make another set, that would be a much better solution. I honestly don't hardly ever use them anymore since I have rarely had issue with being able to set all the valves before ever starting an engine. These were back when I thought I needed to adjust valves with an engine running. I was reminded of the mess last night when the exhaust valve on #2 cylinder was squirting oil all the way to the inner fender. I just stuffed a paper towel on top of it to keep the mess inside the valve cover. :rolleyes:
    427 sleeper and winduptoy like this.
  7. winduptoy
    winduptoy
    it was excited to be running again.......
  8. RodStRace
    RodStRace
    Unh, Unh, Unh
    427 sleeper and guthriesmith like this.
  9. bobss396
    bobss396
    I had a set of those Lisle clips that plugged the oil holes, but they would go PING... try finding one of those, more miss than hit. I just use an old towel to catch most of it.
  10. Hot Rods Ta Hell
    Hot Rods Ta Hell
  11. DDDenny
    I borrowed a set of those from a friend years ago, don't know what I did wrong but a couple of them broke, he said don't worry about it but I knew what it meant was, don't ask again to borrow tools.
    Cut the center out of an old 283 valve cover and finished the job.
    bobss396 and guthriesmith like this.
