Projects Poly begets a Hemi begets a Model A
Discussion in 'Traditional Hot Rods' started by wstory, May 21, 2020.
  1. warhorseracing
    warhorseracing
    from cameron wv
    Just looking at pictures is easy. Exit the mufflers 90 degree bend up and over the axle. slight run over the axle then another 90 degree bend down with a slight 12 degree bend sideways and exit out the back:confused:. Yes Sir sitting and looking at it is easy. Doing it is the challenging part. We have faith in you and your patience to make it work and look great.
    HemiDeuce likes this.
  2. Bert Kollar
    Bert Kollar
    Who modified the cam
  3. Bert Kollar
    Bert Kollar
    A friend of mine who has a machine shop taught me that oversize tick. He drills most holes next drill oversize b4 tapping
  4. wstory
    wstory
    Gary Stauffer at QEC in Bend OR. He has been very helpful and generous with info on both of my Dodge Hemi builds.
    www.qualityengineeredcomponents.com
  5. George
    George
    Gary is a great guy!
  6. 73RR
    73RR
    ...you guys are making me blush. Much appreciated.
  7. wstory
    wstory
    Coupla things since my last post :eek:
    After numerous "tacks" with the header still bolted to the engine, things moved just enough to prevent removal of the header. However, epiphany !!!! :rolleyes: pull the starter, easy,...two nuts,,....what was I thinking? Hopefully movement from final welding will not preclude reinstallation. Fingers crossed. The pic below is upside down and b*** ackward and looking at the inside, the engine side.
    Onward to the routing and muffler mounting. Although it looked pretty straight forward in the earlier posted pics, I'm just not comfortable with the clearance at the center crossmember. At best it's 5/16" top and bottom and with flex and rubber isolators I think that's cutting it too close. And, getting the pipes up and over and around the coilovers, and the panhard bar, and exiting where I want is equally difficult which ever way that area is approached. Sooo,.today I'll look at sneaking the headpipe over to the inside of the ladder bars.
    Tim, anothercarguy, brEad and 8 others like this.
  8. wstory
    wstory
    Finally after a lotta head scratching and more "little pieces outta big pieces",....I'm feeling some success.
    Got the final merge figured out and recalling my High School geometry made this fixture to get proper cuts for matching various curves of tubing.
    The result that you see below took a whole lotta fussin to thread the headpipe thru the maze of crossmember tubes in order to to get the mufflers where they needed to be.
    Next challenge is exhaust hangers that still allow for pulling the pipes.
  9. Tim
    Tim
    from KCMO
    Man those are wild! Good progress :)
    winduptoy likes this.
  10. Those headers and exhaust...wow...just wow! Where there is a will (and shear determination and dogged stubbornness) there is a way!
    73RR and winduptoy like this.
  11. warhorseracing
    warhorseracing
    from cameron wv
    Just like I said earlier. Easy Peasy for you.:) What did that take, all of ten 12 hour days?:D You have such an imaginative mind and foresight to be able to see then create it is amazing.:cool:
    Outback and 73RR like this.
  12. wstory
    wstory
    Thanks boys,...but I think it's more about getting all the bad **** done before the good stuff shows up.
    And there's always someone who can top your story! Flashed on the image below, an ARP ad in the Rodding USA mag I was scanning in the "library" this morning :eek: IMG_6597.JPG
    Outback, brEad, slayer and 2 others like this.
  13. pprather
    pprather
    I'll bet that cost Wes Rydel a bundle having it built by Troy.
    I like watching your project progress.
    Outback, HemiDeuce and winduptoy like this.
  14. 40ply
    40ply
    Awesome job Bill!!! Really inspiring work.
    Outback likes this.
  15. Gene T Stark
    Gene T Stark
    I love what you are doing
  16. wstory
    wstory
    I'm coming outta the "funk"! Update in a couple days.
  17. wstory
    wstory
    Ya know,.....ya think yuv got something special and lay awake nights figger'n how to pull it off and then some 20 something "techy" fabricator with the latest tools (and a steady hand I have to admit)... steels your fleeting spot in the lime light. It aint fair! :(
  18. Bill...you've got something special...f@#%in' cool as a matter of fact. I've come to the realization that there will always be someone that is a better fabricator, has more money, a bigger shop, better tools, is better looking etc...but none of that takes away from your f@#%in' cool stuff! :cool:
    neilswheels, brEad, Dean Lowe and 2 others like this.
  19. rockable
    rockable
    Wow! What a bundle of snakes!
  20. 73RR
    73RR
    Yeah, I saw that same pic just yesterday on the 'ol www......pretty wild stuff.
  21. 40ply
    40ply
    Meh. The fabrication looks good but it's in a late model something, I'm more interested in what you're doing with an old Hemi in a model eh. Keep at it. :cool:
    brEad and j hansen like this.
  22. wstory
    wstory
    Seems like this is taking forever! Finally got all the weld joints completed and feeling fairly confident I've not missed any chance for leaks in the hard to see and reach sections that are obscured by adjacent tubes. Cleaned up and ***embled everything on the bench and couldn't resist taking a few shots to show a lot of the ***embly not be visible when the whole package is installed on the car.
    One issue that has reared it's ugly head is that sections have moved during final welding and some adjustment of the four tubes that traverse beneath the oil pan will be required. IMG_6606.JPG IMG_6608.JPG IMG_6615.JPG IMG_6621.JPG
  23. 73RR
    73RR
    Way to go Bill!
  24. Tim
    Tim
    from KCMO
    Holy cow! Go man go!
  25. 40ply
    40ply
    That's awesome Bill!!!!!!! Another hurdle overcome.
  26. X38
    X38
    Man that's a lot of welding. You need a vacation!
  27. slayer
    slayer
    NOOOOOooo! Don't stop him, he's on a roll!:rolleyes:
    Your Hemi is going to sound great with those headers and the blower.
    neilswheels and X38 like this.
  28. Great work Bill, I got lost trying to find my way out of that snakes nest.
  29. wstory
    wstory
    Initially I thunk to attack the p***enger side ***uming it would be more the more difficult fabrication. However,....now the challenge is to achieve some semblance of symmetry driver to p***enger side.
  30. pprather
    pprather
    Just remember, those viewing your work can only see one side at a time.
