Technical New to customs
Discussion in 'Traditional Customs' started by dsiddons, Sep 1, 2023.
  1. dsiddons
    dsiddons
    from Indiana
    I recent bought a 54’ Mercury and have a dumb question. I’ve been looking at fender skirts on ebay and some are flush and some are outside mount. The ones that came with the car are fibergl*** and looks like a real ***** to mount and appears to be flush. IDK but if I counts get a few recommendations I’d appreciate it. Thanks
  2. Well fender skirts don't make an otherwise Stock car a Custom being they were factory options at the time. That said I like the flush mounts being they cause no damage to the painted surface like outside mount skirts do.
    chryslerfan55, X38 and dsiddons like this.
  3. Get whatever style ya dig
    Then drop the car in the dirt
    chryslerfan55 and Pist-n-Broke like this.
  4. Moriarity
    Moriarity
    SUPER MODERATOR
    Yup, in order to be a REAL custom there needs to be body modifications, at the very least nosed and decked and lowered....
  5. I don't know Anthony, camera angles can be a little deceiving but looking at the tire to wheel opening it looks to be sitting pretty good.
    Bandit Billy, chryslerfan55 and Tman like this.
  6. When you think about the m***ive amount of work it takes to make Flush Mounts where the stock outside mounts were I think the Flush mounts look far more Custom than the other. To bad the Factory did it first.
  7. P.S. That lower quarter panel has had Major surgery!
  8. Lone Star Mopar
    Lone Star Mopar
    Stock Merc skirts would look great on your car.
    dsiddons likes this.
  9. dsiddons
    dsiddons
    from Indiana
    It’s just gonna be a cheap cruiser. Most likely strip all the trim and put a budget paint and interior in it.
  10. Squablow
    Squablow
    https://www.ebay.com/itm/3140872742...u9/8ChDLdqPkgQUpxMAry7Lg==|tkp:Bk9SR9y5obLKYg
    In my opinion, this is the style you want. The overlay ones tend to rub against the paint and eventually wear through it. The factory flush fit skirts aren't nearly as tall as these, they only fill in the quarter down to the "bump", where as these go past that, but are still flush fitting and are steel. Keep in mind, it's already tough to get a wider tire under these cars, and skirts aren't going to help your clearance. But if you're running wheel covers and 6.70-15 bias tires you won't have any issues.
  11. dsiddons
    dsiddons
    from Indiana
    I would really like to see some pictures of the flush and outside mount. Thanks for all the input. I kinda tried to put these fibergl*** ones in and they fit pretty snug actually. I’d imagine with paint they will need some kinda weather strip which may need some love then. I’ll have more questions when I shave the door handles and trunk junk thanks
  12. Squablow
    Squablow
    Also worth mentioning if you're new to 52-54 Fords and Mercurys as well, is go and oil every pivot point on your hood hinges, and be real careful as you raise and lower your hood. The hood hinges on these cars are really expensive and a pain in the **** to replace, and they're also known to bind up and break. If you've got a good set, you'll want to keep it that way. Remember that the bolts that go into the hood are all pivot points as well as the rivets on the hinges themselves.
    texasred and Moriarity like this.
