Technical Rebel Wiring Harness / Ballast Resistor
Discussion in 'The Hokey Ass Message Board' started by 1961Sweptline, Sep 3, 2023.
  1. 1961Sweptline
    1961Sweptline
    I'm searching for help with a re-wiring of my '61 D100.
    To install the ballast resistor into my new Rebel harness, do I simply cut the wire marked "coil", and install the ballast in between?
    I've been learning lots on this project, though there always seems to be more to know.
  2. pprather
    pprather
    Since you are using a ballast resistor, I ***ume you are using a points ignition?
    Find a good place to mount the ballast resistor, before cutting the (pink?) coil wire.
  3. pprather
    pprather
    1961Sweptline likes this.
  4. 1961Sweptline
    1961Sweptline
    I am, yes. Taking your answer as confirmation the ballast gets inserted into the pink wire labeled "coil".
    Thank you,
  5. studebaker46
    studebaker46
    if you have a question call rebel very knowledgable and really helpful
  6. larry k
    larry k
    You will also need a full 12 volts to coil side of the resistor . But only to help it start , it then drops to 8 volts to run the engine ….
  7. 1961Sweptline
    1961Sweptline
    Rebel is very helpful. As are you all, thank you everyone.
  8. We need pictures, I love that body style of Dodge Truck.
