Projects Blown 4 Banger (210 inch grenade)
Discussion in 'Traditional Hot Rods' started by nutrocker, Feb 7, 2021.
  1. Michael Ottavi
    Michael Ottavi
    If you could only put another seat in it and take Henry Ford for a ride!
    Stogy and redoxide like this.
  2. set me on fire
    set me on fire
  3. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    Methinks he'd love it.
    Stogy likes this.
  4. nutrocker
    nutrocker
    VHRA Pendine was as great as usual, so big thanks to Neil and the team for all their hard work.
    Now I’m back and caught up on a bit of sleep I can up date you.
    I flat towed the car to Pendine, the last thing I wanted was to break it before I got there.
    The car ran great, never missed a beat. First run on Saturday morning netted me a 102.06 mph. The sand was slippery and I was still fighting to keep it straight through the timed section.
    I have an old cell phone with a speedo App on the dash, which read 100mph as I got to the first of the timed section flag.
    The second run, for me the sand felt better and I was all settled in before the timed area. First flag I had 102 on the speedo but a rear end step out between the flags knock 3mph off instantly. I only just managed to miss the second flags on the way out.
    That was it for the first day.
    Over night I removed the headlights and fitted some washers under the dump valve spring to get a bit more boost.
    Sunday there was a strong head wind. No way would the car be able to run faster. So 102 mph will do for this year. Happy with that.
    I got there and ran a personal best with the car, got the car home in one piece, what more could be better.
    I’ll leave you with some photos that I’ve taken from various photographers on the internet. Credit is to them and if they let me know who took which I’ll credit with their names.
    D946177C-1979-4329-ABDC-5BA9CE027AB6.jpeg C4CAB576-5945-4B5D-BBCD-48954DF9B152.jpeg 96F35DCA-F529-468F-B88C-27DCB605D093.jpeg 0BDEEDFA-8754-4181-98AB-0391E4E57C76.jpeg DA61B749-CD72-41EF-BC27-10DF0162C665.jpeg BA08ECDF-D61F-43D3-87BD-EC80E29937AA.jpeg 371DBE7A-73D9-4FCD-AEF7-D246DBE7C55C.jpeg
    woodz, Tat2Neil, Deutscher and 16 others like this.
  5. GeeRam
    GeeRam
    Car sounded great Pete, and at least where we were staying it wasn't a long walk to the Springwell....
    Despite your engineering prowess, your alfresco dinner menu is still work in progress :D;)
    winduptoy, Stogy and Outback like this.
  6. nutrocker
    nutrocker
    who’s this?
  7. AmishMike
    AmishMike
    That last pic in post #154: tonneau cover around driver would look great & May help streamlining
    Stogy likes this.
  8. nutrocker
    nutrocker
    A tonneau is in the plan, just didn’t get the time before Pendine. Next year hopefully
    winduptoy, Stogy, redoxide and 4 others like this.
  9. Pete, absolutely love your work! I'm @bangersmodified on instagram.
    Do you mind shedding some light onto your dry sump setup? I'm planning on doing something similar on a Sprint Banger I'm building.
    Stogy likes this.
  10. nutrocker
    nutrocker
    On my engine, I used a ***an oil pump that’s belt driven off the crank. It has two scavenge and one feed. The idea is that the two scavenge pumps **** the oil out of the sump quicker than the one feed can pump it in.
    A0779DF0-AE2D-4F66-AE44-6D1F0E645BAB.jpeg 51D1B8B8-60F6-4F0C-B9F7-C26AC11E9BB8.jpeg 095BFC91-EC31-431A-9F34-2C5518BB0064.jpeg
    I have the feed from the oil tank to the pump, from there it goes straight to the oil filter. The oil filter is mounted on the side of the block which allows both internal and external oil lines.
    The internal line feeds the front and centre main, which in turn feeds rod end journals 1,2 and 3.
    The external lines feed the rear main, plus rod end 4 and 3. It also feeds a log manifold with small bore pipe feeding the four cam bearings and a line up to the head to feed the rocker shafts.
    I added a couple of extra lines to spray oil over the cam gears, en block valve chest and the over head valve area to give a mist of oil over these parts.
    1C81D85C-8050-4DC8-B077-DEE48538A11D.jpeg E2635A7F-B9DA-4CD7-8DB4-5BD757225D05.jpeg 44BFD4A7-C467-4EA8-BC06-65D6D1EA8A4E.jpeg FF26D703-31B1-48A2-B454-4DB90C1A4ABB.jpeg C024C003-C084-4E03-8458-D6C799B78929.jpeg 75E886D6-AD3B-4B41-9EF9-FED796EAE40E.jpeg 4BBD20C1-7732-4A13-B68E-91DFC0F2F88D.jpeg 6A8ADFC2-E952-495E-98C9-1997A2C381EF.jpeg
    Hope this helps with your project.
    Pete.
  11. AmishMike
    AmishMike
    This is such a great build, love it & follow closely. Maybe mentioned much earlier, but, what oil pressure do you get with this great setup?
    Stogy likes this.
  12. nutrocker
    nutrocker
    Thank you.
    The oil pump has an adjustable relief valve so I can set the pressure at what the engine wants.
    In this case I have around 40psi at idle going up to about 60psi.
    One thing about these pumps is the flow, they flow a lot of oil. It’s more set up for flow than pressure.
    Pete.
  13. Tim
    Tim
    from KCMO
    Another thread I need to catch up on. Saw it in marts videos and had to come hunt the thread down!
  14. Stogy
    Stogy
    Glad you're reaping the results you were vying for Pete...quite a feat in engineering and the Hotrod looks fantastic...congratulations...
    Outback likes this.
  15. Totally stunning. Work of art.
    woodz, Stogy, winduptoy and 2 others like this.
  16. nutrocker
    nutrocker
    Been a bit of time since the last update, so here goes.
    The time between last years Pendine and this year was spent making some changes to the car. The big one that took way longer than it should was to replace the old Model A steering box for a series 2 Land Rover box. This was made more complicated because I wanted to keep the model A drop arm and the extension that I made for it.
    The A box has a square shaft and the Land Rover has a spline.
    I had to strip the LR box, machine the spline into a square, which was smaller than the A, then machine a square sleeve to take up the slack.
    I also made the tonneau cover that I had made a start on last year, just didn’t have the time to finish.
    IMG_6006.jpeg IMG_6008.jpeg IMG_6009.jpeg IMG_6015.jpeg IMG_6017.jpeg IMG_6021.jpeg IMG_6025.jpeg IMG_6031.jpeg IMG_6032.jpeg IMG_6036.jpeg IMG_6039.jpeg IMG_6134.jpeg IMG_6271.jpeg
    That’s it for the car and engine combo. I’ve gone as far as I can go with it now with the time and money I have.
    To go faster the motor needs to be in streamliner or something similar. I thought about building one, but nowhere to store it means it’s not practical for me.
    So the engine is up for sale, including the ancillaries, ecu, electric water pump, oil pump and oil tank.
    I’ll finish with a few photos of this years VHRA Pendine Sands.
    credit to the photographers
    Thank you to all those that spent the time to read, and comment.
    Pete.
  17. continentaljohn
    continentaljohn
    Wicked cool build and great craftsmanship thanks for sharing
    Stogy and AmishMike like this.
  18. RodStRace
    RodStRace
    Amazing and bittersweet. I've got 2 acres (0.8 hectare, 8093.7 sq. meter or whatever you guys use for area these days) for storage, but it's not going to help you over there. Shame this is the end of this chapter, but looking forward to the next adventure. Sure hope whoever gets that engine has the skill to continue it's legacy.
    Stogy likes this.
  19. Stogy
    Stogy
    You have mad skills @nutrocker...thanks for front row seats to your journey in Hotrod...you might be moving the ticker on but you didn't mention the racer so as others have said we look forward to the next adventure...Vintage Hotrod is truly in your blood...
    winduptoy and Outback like this.
  20. 282doorUK
    282doorUK
    That tonneau cover is a very nice piece of work Pete.
    Looking forward the the next part of your journey with this car.
    Outback and Stogy like this.
  21. Outback
    Outback
    from NE Vic, Oz
    Yes, please keep us in the loop. Looking forward to the next thing!
    Stogy likes this.
  22. Ebbsspeed
    Ebbsspeed
    @nutrocker This just continues to get better! I noticed in the first iteration of the car at Pendine there was a lot of sand on the bonnet. Do the rear tires throw any sand into the carbs, or do you have some protection from that happening?
  23. nutrocker
    nutrocker
    The sand was from the return run back to the pits. That year the sand was very wet and an incoming wind. The rooster tails were blown over the car.
    I stripped and check both the carbs and the blower at home afterwards, no sand evident, which was good news.
    Outback likes this.
  24. hotrodA
    hotrodA
    That is a beautiful car! Thanks for sharing your amazing talents.
    Outback likes this.
  25. metalhead140
    metalhead140
    Too cool. Did you go any faster this year? And out of curiousity, what's the asking on the engine setup?
  26. nutrocker
    nutrocker
    I was 2 mph down on last year. The sand on Saturday wasn’t good, but the Sunday was very good. For some reason I just couldn’t beat last years speed.
    For the complete engine, blower, oil tank, electric water pump and controller, oil pump, ecu and sensors, everything from the clutch forward I’m asking 15000 uk pounds. About $18750.00 usd.
  27. Outback
    Outback
    from NE Vic, Oz
    @metalhead140 that would make your coop boogie!
  28. metalhead140
    metalhead140
    That it would! But while it's quite a reasonable ask for the work and parts in it, it's still a bit rich for me. Love it though, too cool!
    Outback likes this.
  29. Outback
    Outback
    from NE Vic, Oz
    Just wondering how much boost does that Wade make on your setup?
    metalhead140 likes this.
  30. nutrocker
    nutrocker
    on the digital gauge that is not longer fitted it was just shy of 10psi. The vintage aircraft gauge that’s now fitted reads 8psi.
    GuyW, metalhead140 and Outback like this.
