Ford Frame difference?
Discussion in 'The Hokey Ass Message Board' started by sacred_piston, Sep 27, 2006.
  1. sacred_piston
    sacred_piston
    I have been looking for a 35-40 ford frame for my 40 ford truck rod project and came across what I am told is a 41 sedan ford frame, I am not sure from pics but looks similar but don't know what difference between the frames are beside maybe size. Anyone know what year this is and major differences between a 35-40 and 41 frame?
  2. SUHRsc
    SUHRsc
    looks like 41-48 to me....i could be wrong...but the torque tube going through the frame is the newer ones
    i had a 37 and a 46 side by side and that was a noticible difference
    Zach
  3. Mike
    Mike
    The '41-'48 p***enger car frames look similar to the '35-'40 frames, but they are built to carry a completely different body. All the dimesions are different, mostly bigger.
  4. That frame is the 41-48 style. Big difference in frames. Wheelbase for starts and general configuration. You need a 35-40 car or truck. You may also be able to build a 40 pickup on a 42-48 ford pickup frame as they used the same cab. I don't know that for sure. Pat.
  5. sacred_piston
    sacred_piston
    Body mounts and stuff like that can be relocated I just wanted to make sure they were atleast pretty close. Seems like they are. It is good price and good shape so it might have to do.
    Thanks guys
  6. sacred_piston
    sacred_piston
    I guess my biggest concern is that I will be able to channel the 40 cab over the 41 p***enger car frame and that the frame isn't too wide, everything esle can be made to work.
  7. Mike
    Mike
    The big issues will be track width and wheel base diferences. After all the h***le of mounting everything, it might end up looking like a '40 truck equivalent of the Street Beast '34.
  8. sacred_piston
    sacred_piston
    Well I am hoping a street beast is what it will be. I am only running a cab and bed no fenders open engine.
  9. krylon32
    krylon32
    from Nebraska
    Stick with a 35-40 car or pickup frame or a 41 pickup frame and run from the 41-48 p***enger car frames and the 42-48 pickup frames. Just to many differences.
  10. see! you have a cab and you have a frame! sounds like you need a tape measure!
  11. manicmechanic
    manicmechanic
    I have a 40 and 41 frame side by side in my shop. The only thing that is the same is both have flathead motors.
  12. Mike
    Mike
    It'll probably be ok then.
  13. K3nny
    K3nny
    I actually had that fear, but after some pie cuts and pinching i made it fit under a 39 chevy cab. you have to cut the xmember out tho. ill update with a current picture as soon as i can but heres one when i picked it up.[​IMG]
  14. sacred_piston
    sacred_piston
    K3nny if you got some pics I would enjoy seeing them. I figured if I got to piecut or pinch some it will be fine, small budget and work with what ya got I say. As long as i can channel the cab over frame and get an engine and ****** in it I am golden.
  15. K3nny
    K3nny
    ive got a ton of pictures i can get for you, unfortunatly im not finnished because of lack of a table. i'll Pm You tonight.
    -kenny
