Projects Project 52 Chevy 3100
Discussion in 'The Hokey Ass Message Board' started by Francisco., Sep 7, 2023.
  1. Francisco.
    Francisco.
    Hey guys, I’m looking at a 52 Chevy 3100 truck for sale & can’t quite tell beside the cab corners being rotted what all is wrong with it.
    are there other common areas on these that tend to rust/other problems etc..
    Any advice is greatly appreciated.
  2. DDDenny
    P
    Could you use that in a sentence?
    chryslerfan55 and tractorguy like this.
  3. HSF
    HSF
    from Lodi CA
    Don't P against the wind or P in the pool.
    tractorguy and nochop like this.
  4. 05snopro440
    05snopro440
    The lower front corners of the cab/firewall are bad spots on some as well. It's a truck that most everything is reproduced for so a little bit of rust isn't a big deal if you're capable of the sheet metal work or have a good shop that is.
  5. Francisco.
    Francisco.
    Haha just noticed my goof up. I was in the middle of eating when I posted this & hadn’t noticed the ***le, P
    the thing is pretty solid with the exceptions of the cab corners but it has only a bill of sale. I’ve never dealt with this kind of thing. How hard & expensive is it to get a ***le with only a bill of sale?
  6. Francisco.
    Francisco.
  7. AngleDrive
    AngleDrive
    from Florida
    Before a moderator locks this thread just go to your local DMV and find out.
    chryslerfan55 and Francisco. like this.
  8. Bob Lowry
    Bob Lowry
    P, as in psychology is silent, just like the pee in swimming...
    '34 Ratrod and Just Gary like this.
  9. BJR
    BJR
  10. jetnow1
    jetnow1
    from CT
    As stated, lower cab corners, lower cowl, also floors are often bad. All parts are reproduced and fairly easy to replace
    if you can weld sheet metal. As for ***le, ask your local DMV, or check with a ***le service to see what they would charge. In any event do not put $$ into it till you have that ***le.
  11. Francisco.
    Francisco.
    Ok. Would a 3100 truck have 6 lug wheels or 5 from the factory? The guy said it’s a 3100 but has 6 lugs in front. Rear is 5 as he said it’s a Ford 9”
  12. Francisco. likes this.
  13. Francisco.
    Francisco.
    Anyone got an idea on how many lugs on the stocks for a 52 chev 3100?
    (I was wrong earlier, it’s a 52 not a 50)
  14. Francisco.
    Francisco.
    5CBB2CE1-9EAC-4236-BE7B-4F9B09CBF30D.jpeg D602B995-62FD-4BF7-8113-4FE2BDFBEB46.jpeg 7839042D-AC6F-4D87-A410-903942DF9F48.jpeg 998CF15C-7B77-4B1E-B28B-7D5BEECCA517.jpeg 5CBB2CE1-9EAC-4236-BE7B-4F9B09CBF30D.jpeg 7839042D-AC6F-4D87-A410-903942DF9F48.jpeg 998CF15C-7B77-4B1E-B28B-7D5BEECCA517.jpeg
  15. Budget36
    Budget36
    6 lug. You mentioned Ford rear, so that’s why it 5 lug in the rear.
  16. Budget36
    Budget36
    Hey, I’ve been driving by that truck twice a day, M-F on the way to and from work.
    The bed must have been recently sat on there. Didn’t have it before just the big C Notch.
  17. Budget36
    Budget36
    When I drove home this morning it wasn’t there, I’m sure I’ve seen it on the way home before.
    Did you buy it? Or maybe the seller is not leaving it out anymore?
    To be honest this morning was the only time I actually looked for it on the way home though.
  18. ronzmtrwrx
    ronzmtrwrx
    Aside from the cab issues and no ***le, take a look at the rear frame. That tall c notch looks like it could be removed and the frame repaired as they haven’t cut out all of the original frame yet. Those rear bars running from their home made crossmember back to the rear end tells me that whoever was working on it didn’t know what they were doing. Can’t tell if they’ve removed the original spring hangers or not.
  19. Moriarity
    Moriarity
    SUPER MODERATOR
    I enlarged the pics for you, Always select "full image" when posting pics
    Toms Dogs and Francisco. like this.
  20. Francisco.
    Francisco.
    Thanks I just wanted to make sure I wasn’t ending up with a 3600. I’m getting it in a little while.
  21. Francisco.
    Francisco.
    Going to check that out, thank you for that info.
  22. squirrel
    if it was easy to get a ***le, the seller would have done so already, eh?
    think about it
  23. 05snopro440
    05snopro440
    That C-notch and rear suspension don't look like the person understood suspensions.
  24. Budget36
    Budget36
    Seems ya got it before 3pm!
  25. Francisco.
    Francisco.
    Yeah I got her. It was a real ordeal getting it off the trailer onto the side of my house. The running board bolts kept catching on the trailer & a real tight squeeze to top it off. Now just to decide where to start.
    the rear suspension is pretty messed up but being that it came with a good running 250 I think I’ll start by trying to get it running then work on the rear suspension.
    I’m wondering if a th400 would work with that 250?
  26. Are you asking, because you have one? It will work, but it does use up a bit of the HP the 250 will produce.
  27. Francisco.
    Francisco.
    A friend has one he’s selling so I was thinking about getting it from him. What would be a better choice for the 250 in Automatic?
  28. Lloyd's paint & glass
  29. squirrel
    400 trans will work fine...it only uses extra power if you put a lot of power through it. It's a percentage deal. Don't sweat it.
  30. Mr48chev
    Well that is a slammed AD truck starter kit.
    You would have to check but ***le wise you may be better off saying that you built/***embled it with/from parts you bought.
    Get a 3 ring binder, Get some of those page savers that go in the binder.
    Put the bill of sale in one of the page savers and print out a couple of the photos that you took when you first looked at it. The idea being that you didn't buy a complete truck you bought parts of a truck.
    Then you add the bills of sale and receipts for the major parts that you buy for it, Engine, Transmission and what not. That just shows that you legally bought all the major parts when you go to have it inspected. Somewhere in the California DMV ***le your rig they have the list of what you need and what you have to do but they will always want to have you show proof that you legally bought and own all of the major parts.
    Go thought every nook, crannie and hiding spot in the truck though. The pink slip could be hidden away in it somewhere if the interior hasn't been totally cleaned out.
