Projects My Model A Coupe (banger heavy content)
Discussion in 'Traditional Hot Rods' started by metalhead140, Sep 3, 2023.
  1. BJR
    BJR
    I know you are hurting and hitting anything on a Harley is not funny. But I gotta say this if the first time I have ever heard of someone hitting a Kangaroo on a motorcycle. But I live in Minnesota in the USA so no Kangaroo's.
    SS327, Bugguts, drdave and 5 others like this.
  2. panhead_pete
    panhead_pete
    Having done the same its surprising its not as uncommon as you would think ......
    Mate having broken ribs then tried to do too much too early and breaking them again after they had started to meld a few weeks out, which was NO FUN, would suggest taking it easy and if you really want to get the car to the show get some mayes to help load it on a tralier and take it that way. A slghtly bitter pill no doubt... Good luc with it
    Stogy, metalhead140 and Outback like this.
  3. metalhead140
    metalhead140
    I actually tried that, and it didn't help... Even tried starting it. As I say, it was properly stuck!
    winduptoy and Stogy like this.
  4. metalhead140
    metalhead140
    I did more or less this. I had a clamp pushing from the ch***is rail on a 1/4" extension through that hole pressing against the oil pump to hold it in place. Was pretty secure.
    Yeh. I haven't actually touched it over the past few days, the likelihood of having it running by next weekend is fast slipping away. Just so hard to get anything done beyond the basics of doctors appointments etc, with the pain and rest requirements.
    winduptoy, Outback and Stogy like this.
  5. Add a Windfield head and 2 carb intake and it'll be a screamer, the counterbalanced crank is really good too.
    Outback and metalhead140 like this.
  6. metalhead140
    metalhead140
    How much advantage (besides cool factor) does the Winfield head have over the 6:1 Snyder? Not saying it doesn't, genuine question!
    Dannerr likes this.
  7. Stovebolt
    Stovebolt
    @metalhead140 Winfields are reported to be about the best head for a banger - after-all one was recorded at Muroc at 138mph in 1938
    Dannerr, Outback and metalhead140 like this.
  8. metalhead140
    metalhead140
    Didn't get the car together. My recovery has been slower and harder than I had (unrealistically) hoped. But I did get out to Gulgong for a look.
    Dannerr, Toms Dogs, mvee33 and 8 others like this.
  9. Jeff34
    Jeff34
    That tub in pic 2 is PERFECT in my mind. Makes me drool
  10. Any idea of a part number for that? Is it a diaphragm?
    winduptoy likes this.
  11. metalhead140
    metalhead140
    Yeh sure, I bought a Luk clutch kit, part number 07-038. Yes it's a diaphragm type. Keep in mind that I haven't had it in the car to drive it yet. It all looks to work properly when bench testing it though. The Model A driven plate is a little thicker than the Mustang one, I thought I might need to shim the pressure plate, but it appears that it should work ok without any shimming.
    Dannerr, winduptoy and hotrodfil like this.
  12. Cool if it works with the stock thrust bearing.
  13. Tumblin' Dice
    Tumblin' Dice
    from Las Vegas
    What exactly has been done to the suspension of this car? The stance looks perfect with the chop and with the 19" wheels.
  14. 1946caddy
    1946caddy
    from washington
    Pictures remind me of the "Twilight Zone". Couple of people in the background and the rest of the town, deserted.:confused:
  15. Tim
    Tim
    from KCMO
    Just found this thread what a cool
    Hotrod
  16. alchemy
    alchemy
    Are you healed up and the coupe is back together?
    Outback likes this.
  17. That is quite a journey, thanks for sharing it with us.
  18. Thats a *****in little coupe. Kinda makes me want a hard chop on mine. How much do you reckon its chopped?
  19. Outback
    Outback
    from NE Vic
    Dannerr likes this.
  20. Dago 88
    Dago 88
    . No Glen, haven’t heard any more.
    Dannerr and Outback like this.
