Projects 1939 Ford convertible mild custom.
Discussion in 'Traditional Customs' started by John 79, Sep 13, 2023.
  1. John 79
    John 79
    from Sweden
    The reason for starting this thread is that i like the old build threads, the ones on forums like this where you can follow a build easy without missing updates because of weird media flows like Facebook and others.
    Also i want to support the HAMB and hopfully inspire someone.
    So, this April i bought a 39 ford convertible.
    Ive had alot of old cars but not a real convertible so i made a deal on this one.
    The car was all "original" besides a dropped front axle, disc brakes in front and super slide leafsprings.
    Original 85hp flathead and stock trans/rear axle was all there.
    The car looks great in pics and were ready to drive but was a 70s "restoaration" with rivited floor/trunk and alot of bondo.
    39transport.jpg 39hemma bak.jpg 39hemma fram.jpg 39 motor.jpg 39 instrument.jpg 39 soffa.jpg
  2. John 79
    John 79
    from Sweden
    At first i just wanted to drive the car, it ran great and smooth, got the spidercaps off and mounted some Oldsmobile caps.
    It had a mild hot-rod stance with 8,20 in the rear an 5,60 in front.
  3. John 79
    John 79
    from Sweden
    I know there is alot of Flathead guys out there but im NOT one of them, i want some more power and better highway speed.
    So the plan is a 283 with th350 and a 8 inch rear axle.
    I got a 283 and 8 rear with the car when i bought it but the 283 was sadly locked up an needed a total rebuild so i got another 283 instead.
    Also, a big must have for this one was some skirts.
    Found a nice pair in Norway and started to make plans for the look of the car.
    First i mounted some 6,70-15 instead of the 8,20/5,60 then i took the rear spring out and laid the original rear axle against the rubbers just to see what kind of stance it would get.
    Of course i wanted the taildragger look. 375203964_1091547335150556_6446360698070875623_n.jpg 372302644_1245893209311786_7431106220765230277_n.jpg 371859221_262184416653084_96341667243527014_n.jpg
  4. guthriesmith
    guthriesmith
    Loving this already and will be following along. :cool:
    Outback, Tow Truck Tom and John 79 like this.
  5. custom_lettering
    custom_lettering
    from Wall, NJ
    Hard to beat a 39 Vert. Good luck with it.
    Stogy, Tow Truck Tom and John 79 like this.
  6. brady1929
    brady1929
    Congratulations. Looks awesome.
    chryslerfan55, Stogy and John 79 like this.
  7. John 79
    John 79
    from Sweden
    Thank you, i think this is the only car ive had who is good looking from every angle in stock appearance.
    Stogy, Outback and Okie Pete like this.
  8. John 79
    John 79
    from Sweden
    As i said earlier there is alot of body work on this one.
    Removed the rear fenders an started on the inner fenders.
    The hole for the filler neck isent cut out yet. 375661986_689630933085900_2951969044436067379_n.jpg 372330860_2044138449272987_9151378561371799277_n.jpg 371487064_653900240034077_7108315574103815870_n.jpg 371536592_264129059863121_721039465388427974_n.jpg 375214114_1462936421107303_7432105833652452205_n.jpg 371513988_146483445172548_6591414336304052071_n.jpg 375484070_844284230695163_974153527745707963_n.jpg
  9. I too will be watching...nice car, I like your plan.
    Stogy, 63fdsnr and John 79 like this.
  10. ronzmtrwrx
    ronzmtrwrx
    Nice! I will be watching too !!
  11. Good colour, improving stance, this is going to be fun.
  12. John 79
    John 79
    from Sweden
    Took the old rear axle out and everything that had to do with the original rear suspension.
    Bought a paralell leaf spring kit fron Posies, i think this is the only one with the front mounts on the inside of the frame witch makes it lower.
    I also mounted 2 inch lowering blocks i had layin around, these will probably be swapped for 4 inch blocks.
    The ford 8 that i got with the car was a litte to narrow so i might go for another wider one to get the wheels a bit further out.
    As you can se i also cut all of the trunk floor out, it was just rust and rivited plates.
    375754260_838376700995694_8358513053383705441_n.jpg 373459248_1337114546922187_3044456183482443448_n.jpg 373469757_322098020231512_3583608388114566466_n.jpg 375214762_7340914645925715_6079035822607841982_n.jpg 375207127_267872626141787_7104636155331029617_n.jpg
  13. ModelAMitch
    ModelAMitch
    Nice ride! Will be following along for more updates
  14. str8 6 str8 edge
    str8 6 str8 edge
    from Tampa
    Outstanding.
  15. John 79
    John 79
    from Sweden
    The old trunk floor was still there under a big rivited plate (see pic) but it was totally rusted out and nothing could be saved.
    The original reinforcement that sits under the trunk floor and bolted to the frame was shot and the ends was cracked and the hole rear body was saggin about 1/2 inch.
    Made a new reinforcement in thicker material than original and bolted it in place.
    You can se the angle in the bottom of the reinforcement that follows the angle of the frame.
    Raised the rear body to the right location and welded the reinforcement to the inner fenders so the body got some support and strength. 377109018_327248586363950_3551586148503286271_n.jpg 377105123_1000289597946201_9099782932365055489_n.jpg 377107571_3530904997149573_8596596011993802459_n.jpg 377100738_700463145258382_4755980068643165467_n.jpg 377100817_3608641516085457_3895401829273517540_n.jpg
  16. 40FORDPU
    40FORDPU
    Cool project.
  17. sideswipe
    sideswipe
    Fantastic project. Not to many old school 39's around. PXL_20210310_190339777.jpg
  18. John 79
    John 79
    from Sweden
    Tail pan was mostly rust, bondo and dents so it had to go.
    Found a EMS tailpan for 39-40 coupe, some cutting and it fitted good enough.
    378218598_1277707006248643_2132493825418277160_n.jpg 378220991_1394662234417257_1261639738395029690_n.jpg 378183552_1339490463315719_2023171058297089303_n.jpg 378212989_691432679110317_74402931003256840_n.jpg 378190865_687333843273553_8130839616684408579_n.jpg
  19. Tow Truck Tom
    Tow Truck Tom
    from Clayton DE
    Rehabilitation, great effort.
    Thank You for showing your build skills.
  20. Okie Pete
    Okie Pete
    Beautiful car . It is in good hands now and Your making it a solid car once again. Thank you for sharing
  21. Jacksmith
    Jacksmith
    from Aridzona
    Oh yeah, I'm diggin' the direction this is heading toward. I'm on it like a bonnet!
  22. John 79
    John 79
    from Sweden
    Yesterday i pulled the engine and trans, actually i was in no hurry to get it out before the trunk was done but i sold the original drivetrain a couple weeks ago and the guy who bought it is coming by in 1,5 weeks to pick it up.
    Dident have to take the hood off but had to take the trans off to get the engine out.
    380702350_1310245849609535_514873742824939615_n.jpg 380710791_6684740844939624_2732152316112529476_n.jpg 380714803_2047196608964063_4873515341531440606_n.jpg
  23. Tim
    Tim
    from KCMO
    This is looking fantastic!
  24. general gow
    general gow
    MODERATOR
    this makes me want to yell encouraging swear words across the atlantic. amazing project.
    chryslerfan55, Stogy, NoSurf and 3 others like this.
  25. Outback
    Outback
    from NE Vic, Oz
    @John 79 so glad you started a build thread here, I can see why you bought this car & am loving the direction you are headed in,
    & thanks to @Ryan for featuring your thread in the Blog to get us here. :D
  26. Long shakles skirts dual pipes out the back and 48 Ford bumpers will make it look great. I've cut the rear bumper slots in the rear pan, it's not hard go up the middle and across like a "T" then fold the bottoms back , the top use 2 more cuts and form the half circle using a socket wrench thats the right radius. Go Man the car is very cool. I have a 39 convertible sedan chopped with a carson top so I recommend chop and Carson too. JW
    Here's mine.
    Re: 1939 ford
    Aol/Sent
  27. hotrodA
    hotrodA
    Great car! Ford’s best effort with a convertible, imho. Definitely following you!
    John 79, chryslerfan55 and Stogy like this.
  28. 51box
    51box
    from MA
    A 39 Convertible is my favorite early Ford by far, look forward to see this come together!
  29. 34 5W Paul
    34 5W Paul
    from Fresno CA
    My Dad died back in '98 but I'm sure he'd approve 100%.
    This shot was in the early 1940s of him and his ragtop.
  30. Whoamel
    Whoamel
    from So Cal
    Really nice car. I'm be following along, as well.
    Kelly Burns, Stogy and John 79 like this.
