Projects a long time coming
Discussion in 'Traditional Hot Rods' started by Austin kays, Jul 23, 2023.
  1. Tim
    Tim
    from KCMO
    @drdave you guys are gonna have to trade each other rides at the roc! Talk about extreme ends of the spectrum lol
    winduptoy, Sancho, Stogy and 3 others like this.
  2. Tim
    Tim
    from KCMO
    Found just what ya need! IMG_9146.jpeg im sure you could print this out and send it in lol IMG_9147.jpeg
    WC145, winduptoy, Okie Pete and 6 others like this.
  3. drdave
    drdave
    Grandma car vs. real hot rod. LOL
    winduptoy, Okie Pete, Sancho and 4 others like this.
  4. Stogy
    Stogy
    Might have to reposition the fuel pump it's a hand job...:D
    winduptoy and Sancho like this.
  5. Outback
    Outback
    from NE Vic, Oz
    We took an old car for a lap around a remote community where I lived, 6 jammed inside & one on the bonnet clutching onto one of those fuel tanks, the wiper blades & pumping the fuel with a hand pump at the same time, the faster we drove the harder the task became! Hahaha no brakes or clutch added to the difficulty level! Was very entertaining :D
    jet996, Stogy, 41 GMC K-18 and 2 others like this.
  6. Crusty Chevy
    Crusty Chevy
    At only 6 gallons you are going to need to stop for fuel often, pack a Jerry Can. FYI, pre-'57 boat tanks were usually pressurized and had a second line running back to them using crankcase pressure to push gas up to the motors, no fuel pumps on the early motors, hand pump to prime and then off you go. Enjoying the build, several guys from here in Atlanta are heading to the ROC.
    Toms Dogs, winduptoy and Stogy like this.
  7. guthriesmith
    guthriesmith
    So...I remember when this thread started and followed along a bit but never posted to get updates. And, WOW, just caught up today and what an amazing transformation already! Not going to miss updates anymore...missing too much excitement. :D
    winduptoy, Thor1, Outback and 3 others like this.
  8. Tim
    Tim
    from KCMO
    @Crusty Chevy its a temp tank to get it moving around on its own and there is a fuel pump on the car.
    @guthriesmith come find us in Oklahoma ;)
    winduptoy, Outback and Stogy like this.
  9. guthriesmith
    guthriesmith
    Oklahoma is a long ways away... :rolleyes: I did get a hotel reservation the other day thanks to a buddy that can't go so have that piece and registration covered so far. :D I might just show up after all.
    winduptoy, Okie Pete, Outback and 2 others like this.
  10. Tim
    Tim
    from KCMO
    Be there or be square ;)
  11. Tim
    Tim
    from KCMO
    Just adding these back full size IMG_9169.jpeg working under the shade tree and working a billion hours at work. **** tons of sweat equity in this hot rod IMG_9168.jpeg and this, I mean geeze. Thats some car guy jewelry right there!
  12. Austin kays
    Austin kays
    Well nothing but bad news today fellas, Joey and I went to wire it up and after the monsoon subsided we quicky found out my little flathead is Locked up tight
    WC145, Stogy, Okie Pete and 2 others like this.
  13. Dick Stevens
    Dick Stevens
    That ****s
    Okie Pete, Outback and Stogy like this.
  14. Tim
    Tim
    from KCMO
    Nothing a little atf mystery sauce soak won’t fix.
    2FE388DF-ACDA-41A5-84EA-1AE078A357E1.jpeg Damnit that thing looks good!
    WC145, 13clicks, hfh and 8 others like this.
  15. Did it spin before?
    Stogy and winduptoy like this.
  16. Austin kays
    Austin kays
    Yeah and put it back together with a 9 inch clutch/pressure plate combo
  17. Tim
    Tim
    from KCMO
    @cactus1 yeah it’s a stumper he drove the truck to his place and pulled the motor out of it. So pretty weird that it’s not spinning now
    Stogy, winduptoy and Outback like this.
  18. Ah. Sounds like a mismatch of parts then huh? Bolts too long? Bolt heads too fat?
    Stogy, winduptoy, Okie Pete and 4 others like this.
  19. Outback
    Outback
    from NE Vic, Oz
    That looks wild! Hopefully it's a similar problem @J.Ukrop had with his jigger
  20. Tim
    Tim
    from KCMO
    It’s not the clutch like Joeys issue but no doubt it has to be something simple
  21. Primered Forever
    Primered Forever
    from Joplin,MO
    The starter drive isn’t stuck in the flywheel teeth is it?
    Stogy, winduptoy and drdave like this.
  22. Tim
    Tim
    from KCMO
    @Primered Forever thats what my first thought was. I had a flathead that had like one bad tooth on the flywheel and if I rolled the dice and landed on it when I parked that ****er wasn’t doing a damn thing. I’d pull it off, roll the motor and stick the starter back on and be off to the races.
    he doesn’t think it’s that but I don’t think he’s pulled the starter all the way off to try it with out it on yet
    Stogy, winduptoy, Okie Pete and 3 others like this.
  23. Primered Forever
    Primered Forever
    from Joplin,MO
    Rock it back and forth in high gear a few times and it will pop loose in most cases if that’s the problem.
  24. Tim
    Tim
    from KCMO
    He’s tried that with no luck. Mine wouldn’t ever budge either. He’s got the cylinders soaking thinking a ring decide to stick but as of now I haven’t heard any progress on that front
  25. i feel like ive accomplished absolutely nothing for mine, you've completely built your car from scratch in three months and mines barely roadworthy in two years.
    Unkl Ian, Stogy, winduptoy and 2 others like this.
  26. The fix for that I've been told is, Ya gotta put the Beer down, get your *** out of the chair and go "WORK" on it.
    Spooky, Toms Dogs, Budget36 and 7 others like this.
  27. Outback, Stogy and Primered Forever like this.
  28. Austin kays
    Austin kays
    ive kinda been over the car for the moment I wont be making it to the roc and that really took all the wind outta my sails
  29. winduptoy
    winduptoy
    are you sure....come on....I'm trying to process this.....
    guthriesmith likes this.
  30. I was afraid of that. Bummer. But, you guys accomplished a lot in a very short time and that is something of which to be proud. You have your dream car and that’s pretty awesome!
    drdave, brEad, Outback and 2 others like this.
