Technical Extended wheelbase 32
Discussion in 'Traditional Hot Rods' started by 3w Hank, Sep 15, 2023.
  1. 3w Hank
    3w Hank
    In my case I build a 32 5W in a more traditional way, but get into the chop of the body I has been into moderate to radical chop and angle pillar or not.
    I will be at what my roof is now ( a old chop at 3" ) but if I angle pillar is not decided.
    I like now more this 'moderatate' chop than 4-5" actually as I like the flow better.
    Cool is 5-6" but that is more full racing/Bonneville.
    To angle the angle pillar give the car some at***ude, but it might been a more new idea do that ( as I got it.
    In a discussion on chop the word 'rake' came up and extended wheelbase.
    That give also a at***ude ( car look fast standing still )
    But did they do that early 50's vs get the car more stabile, or a 'faster' look ?
    I'm not plan to use a hood, but I'm not shore.
    If did they extend frame or move the front cross ?
    I has a std 32 cross in but I has a nice std A-Ford cross.
    -So how does it work and the history ?
  2. krylon32
    krylon32
    from Nebraska
    I've built countless 32's with the front cross member moved ahead 1 inch. On most of them I had Rootlieb make a stretched hood. I also used a flush mount front spreader bar that the tube followed the contour of the front edge of the horns, I used both straight and V'd bars. Doing a spreader bar like that over the stock one took away the stubby horn look.
    bschwoeble and Tman like this.
  3. alchemy
    alchemy
    No, it was not common to scoot the crossmember forward back in the day. Only done on race cars.
    X38 likes this.
  4. 31Apickup
    31Apickup
    And on more recent builds only
  5. Andy
    Andy
    I moved my spring forward about 5/8". This was done because the dropped axle plus caster moved the wheel back that much. Think it looks better and gets the wheel as Henry placed it.
    theHIGHLANDER likes this.
  6. DDDenny
    My roadster is far from a "traditional" build and yes, many things are more of a 70's/up flavor, I felt a couple mods would address some things I always thought a deuce needed.
    My ch***is front crossmember was moved forward one inch giving it a 107" wb, in my opinion, I really think it relieves some of the stubbiness in the front frame section of a deuce, also had the frame pinched 3/4"/side.
    I ordered the Rootlieb hood and sides one inch longer than original, really like how it fills in that gap where the side panels meet the grille shell over the frame rails.
    Toms Dogs and GordonC like this.
  7. 3w Hank
    3w Hank
    Intresting so a cl***ic hot rod dropped axle move it back some ( shorter than Henrys wheelbase )
    I guess few back then moved the cross but longer wheel base might got some attention ?
    Tony T’s 5W coupe does look to me the front wheels might be moved, or ?
    I saw one 5W ( se picture ) and a extended hood can be cool but maybe not into my style of car. But std frame and wheels moved away some..
    scoob_daddy likes this.
  8. PackardV8
    PackardV8
    Then, there's the extended deuce bodies, cause some of us got old and fat and don't fit well in a chopped/channeled Henry body.
    jack vines
    47chevycoupe and Andy like this.
  9. krylon32
    krylon32
    from Nebraska
    Denny is right a 1 inch stretch in the hood vastly improves the balance of a highboy 32. IMHO
    dirt t and Just Gary like this.
  10. X38
    X38
    That car has been part channeled at an angle over the frame.
  11. alchemy
    alchemy
    Personal opinion.
    Fogger, X38, Fordors and 2 others like this.
  12. Andy
    Andy
    Stock hood length, front wheels slightly forward
    bschwoeble, Toms Dogs and alchemy like this.
  13. Rickybop
    Rickybop
    So that's what I've been seeing all these years but didn't know it. Some of you guys moving your front axles just enough for me to know that there's been a change in the overall look but not enough for me to realize for sure what that change might be.
    Sneaky scallywags.
    I've always been amazed and entertained by the fact that the smallest changes can make such a big difference on these minimalist old hot rods.
    Toms Dogs, Stogy, VANDENPLAS and 4 others like this.
  14. KevKo
    KevKo
    from Motown
    Years ago at a car show my wife asks me if I am going to look at every 32 Ford. I said yes I am. She says but they’re all the same. So I started pointing out the subtle (or not) differences. And she says Oh now I understand.
  15. scoob_daddy
    scoob_daddy
    from Georgia
    the Rolling Bones setups are becoming more common, 3" forward stretch if done conservatively, and the front crossmember stays in place.
  16. scoob_daddy
    scoob_daddy
    from Georgia
    Oh my, any more info on this car?
    I personally love an aggressive stretch.
  17. dirt car
    dirt car
    from nebraska
    I can relate to some thinking all 32's etc. look alike until a closer look beyond the surface, a similar but somewhat off topic situation derailed my attending the national Nomad conventions of which I've been an owner since 1964. Several years of a disabled teardown contributed heavily, but too was the fact that only (3) years of the body style limited the uniqueness one could achieve without deviating too greatly from the outward appearance of the original. Seems it became a situation of discussing what bolts & nuts were correct & if they were painted or not etc. I'll always respect an original unrestored or restored car but must admit that modifications done without going overboard have enhanced the uniqueness, comfort & general drivability of the vehicles we've come to embrace of which I believe applies to whatever we might have in our possession.
  18. 3w Hank
    3w Hank
    In my way see this, some cars has it, some dont.
    I also struggle some at the ’era’ correct direction what was done before.
    Yes it can be camera angle on some cars to.
    To agressive move as a hood + 4” ( extended frame but cross at std position ) or move just the front wheels several inch but std hood or both this ideas is maybe not my way.
    Maybe move the front wheels so it has the Henry std wheelbase or maybe max 1” more.
    All this is just details but to get a car great it must start with rearwheels correct and correct ’rake’.
    I struggle before on cut the frame at rear and no gastank but I think a 5W look odd that way and my final way was keep the tank and std rear cross and no QC.
    pprather likes this.
  19. clem
    clem
    possibly, you will need to define ‘traditional’ in your own mind.
    If you are going for a’40’s type traditional - probably nothing in your first post will fit in.
    later, I don’t know when, some used a model A front cross member to get a inch or so drop.
    ( my model A front cross member was installed in the ‘70’s so perhaps in the States it was a ‘60’s thing )
    Beautiful car………
    even with the 28 louvre hood that seems to put the front end in the next County………..
    Donut Dave, aussie57wag and lilCowboy like this.
  20. Yes they did angle the windshield back
    Yes they did add ch***is rake
    Yes they moved wheels and crossmembers altering the Wheel base.
    Yes they lowered vehicles , axles, flater crossmembers, channel, springs
    Build it to make you happy, if a 50’s replica is exactly what you want then that’s what you’re going to do. If it varies a little bit that’s cool too.
    Lots and lots of cars built in the 50s got changed little by little as time went and are a mix of the decades now.
    theHIGHLANDER, craig b blue and Stogy like this.
  21. 3w Hank
    3w Hank
    Yes I can do what I like, its my car but I has a foot in old era and bought almost all parts late 40’s stuff for hot-rod/race.
    I even leaved the Adurns for finned race heads that actually did feel more right.
    I has not regrett that ( yet..
    Adurns and supercharges just feelt ’to much’ on this car.
    Heads/water tubes are so cool so I try stay out of a hood, but maybe it will be a hood.
    So I’m investigare what they boyz did or not back then. But I’m not a slave under that idea.
    Flow of the car is very importent, more imporst than the era.
    In mock-up I will check what wheelbase will be at std 32 cross/this axle and then move the A-Ford cross.
    Guys back then if they chanched the cross ( old trick - right ) must has been into that. I can’t see thats not possible, and if a cooler look and with the rake, roof - I do what I like ofcourse.
    Now I’m totally sold on Tony T’s 5W.
    Amazing flow there !
    This one ?
    That axle is definitely moved forward.
    and setting as low as it is I’m going to guess it’s crossmember is raised up quite a bit too. Maybe suicide mount? any more pics of it?
    Any time you see the line created by the bottom of the frame below the center of the wheels it’s got some kind of work done to suspension and frame modifications. When frame is that much below the center there’s some sort of drastic change
    One thing to keep in mind with that drastic stance, and probably why it has a hood is the engine angle and firewall angle create a very awkward look. Hide it with a hood
    bschwoeble likes this.
  23. This one had the wheel base extended.
    crossmember moved forward and then moved up above the frame
    Doane Spencer’s roadster
    1237B31C-8222-4F60-A247-1C2EDB52556F.jpeg 193E9842-9742-4A8B-BB74-209B304D2D86.jpeg
  24. 3w Hank
    3w Hank
    The frame seems not be modify on that car.
    Tony is here on Hamb, but car was in rodders journal, so maybe some has that number and can take pictures ?
    Edit.
    But I found more.
    It look line a std 4” drop axle but bones is later style, but that not set that car that low and its super low ?
    Horns in front can’t be more than 6” up from ground.
  25. 3w Hank
    3w Hank
  26. alchemy
    alchemy
    Steadfast uses rather flat crossmembers and 5” drop axles.
  27. from your pics there’s -
    Flat cross member
    Frame notch for spring clearance
    Extra deep drop axle
    Crossmember moved forward.
    Can’t tell if that spring is reversed eye or not.
  28. 3w Hank
    3w Hank
    Yes it loock like frame has a noth and spring has a reverse eye. I saw a frame picture and drop must be a 5”, and I think it must be this axle, se pic.
    I guess he has a flat cross, and I read a flat cross lower 1.5-2” from a A-cross and maybe from a std 32 maybe 3”.
    If axle is 5” thats also 1-2” more than a std hot-rod axle ( as most are at 3-4” )
    Thats a total 4” more.than I plan to
    has. A-cross and a std 32 spring and a 4” drop.
    -But this gets the cool rake.
    https://welderseries.com/store/Flat-front-crossmember-kit-p51247632
  29. 3w Hank
    3w Hank
    Ok ;
    The front crossmember is completely flat with a mono leaf spring and 5 “ drop axel. It’s moved forward 3/4” the hood is 3/4” longer.
  30. Ned Ludd
    Ned Ludd
