Technical Suggestions for 40 ford mirrors
Discussion in 'The Hokey Ass Message Board' started by VANDENPLAS, Sep 16, 2023.
  1. Hey guys I got clip on the top of the door “ peep mirrors “ on my 40 merc .
    they completely **** !! Can’t see a dang thing outta them .
    What can I get for a side view mirror that actually works ?
    Tow Truck Tom likes this.
  2. 19Fordy
    19Fordy
    On my 40 Ford I use the BOB DRAKE 40 Ford driver side door mirror that fastens to the cowl.
    If adjusted properly it works but you gotta be careful and look twice as the viewing mirror is small. Don't know if it will fit a 40 Merc.
    P***. side mirror is useless.
    Here's more info:
    The Ford Barn - Search Results
    warbird1 and VANDENPLAS like this.
  3. X38
    X38
    The original SoCal swan neck seems popular choice. I've had hinge mounted ones before on a coupe and the driver side was okay, but p***enger useless for changing lanes. I fixed that by extending the mirror head back about 2 inches with a piece of pushrod. I bought the swan necks for the current build.
  4. flamedabone
    flamedabone
    Make sure whatever you use, the wing window will open all the way without crashing into them.
    -Abone.
    lothiandon1940 and Algoma56 like this.
    At this point I’m contemplating these ******s :p:D
    I took the car on a 4 hour drive today and it was a mix of highway and country roads .
    you can barely see anything out of the rear view and the clip on peep mirrors are utterly useless .
    I was reading up on the swannecks and heard different lengths are better than others but no one specified what length is best .
    such a pain trying to navigate traffic , with it being a 4 door and the doors are short even turning your head only gets you a bit better view
  6. flamedabone
    flamedabone
    How dare you….
    -Abone
    Stogy and VANDENPLAS like this.
  7. The cowl mount mirrors ****. Like Fordy said, you can't even see the p***enger side and the drivers side is barely usable. I had a set on my avatar when I got it, couldn't wait to get rid of 'em. Pretty much useless. Buy a set of these...
    Amazon.com: Hot Rod 4" Polished Stainless Steel Swan Neck Mirror Set : Automotive
    Yeah, you'll have to bite the bullet and drill a couple of holes in the doors but these you can actually see in them on both sides. You won't regret it....
  8. 40Standard
    40Standard
    from Indy
    hinge mirror
    rattlecanrods likes this.
  9. Even those leave a lot to be desired, and the p***enger side will still be useless. The closer you can get the mirror to you ,the better they work.
    VANDENPLAS likes this.
  10. Jack E/NJ
    Jack E/NJ
    from NJ
    This clamp-on style has been around a long time and works well. No holes but hold the door lip very well. Still have 2 pairs in use on my 38 ford & 300K. Originally got them from Warshawsky's for a lot less money a long time ago.
  11. Bandit Billy
    Bandit Billy
    Hagan Mirrors. Look em up.
  12. JD Miller
    JD Miller
    Tow Truck Tom and VANDENPLAS like this.
  13. VI Lonewolf
    VI Lonewolf
    Not cheap but they work amazingly well.
  14. That's an understatement!
  15. Bandit Billy
    Bandit Billy
    What's that old expression? "cheap aint good and good don't come cheap"?
    I run em inside
    and out
    they are graceful, the finish is beautiful and the gl*** is convex so you get a good view from a small mirror. They do require drilling through the door to mount but that was the only downside other than the expense.
    Tow Truck Tom and okiedokie like this.
  16. dang !!!!!
    this look great , expensive . Kinda
    had to buy a new mirror for my 2018 ford and it was $1100
    so in the big picture those mirrors are a good deal
    Tow Truck Tom and Bandit Billy like this.
  17. krylon32
    krylon32
    from Nebraska
    My 40 came with So-Cal swan neck mirrors, clears the vent wings and are acceptable to see the back of the car.
  18. gimpyshotrods
    gimpyshotrods
    P***ing eye mirror. Mounts to the door frame.
  19. HOTRODPRIMER
    HOTRODPRIMER
    This is what I used on my sedan, I got them from Bob Drake. HRP
    Tow Truck Tom and rattlecanrods like this.
  20. Jack E/NJ
    Jack E/NJ
    from NJ
    Before & after shots of P***ingEyes on two similarly equipped vehicles p***ing each other in opposite directions on the narrow 2-lane BelvidereNJ free bridge.
    '28phonebooth and Bandit Billy like this.
  21. Does these just clip to the door ?
    how’s the view ?
  22. Airborne34
    Airborne34
    from Texas
    As mentioned, the cowl mirrors are terrible, the right one is totally unusable. The hinge pin model is decent, but getting the pins out on a finished is extremely difficult. The stock rear view mirror is also very limiting.
  23. rattlecanrods
    rattlecanrods
    I have hinge mirrors on the '39 with a domed/wide-angle mirror added onto the p***enger side. Works like a dream! I've contemplated added the wide view to the driver's as well.
    '28phonebooth likes this.
  24. Slopok
    Slopok
    No, those are hinge mounted.
  25. okiedokie
    okiedokie
    from Ok
    My 40coupe with swan neck mirrors with Hagan Fatties lens offers excellent rear vision.
  26. I feel I should mention that these are virtually the same mirrors being sold by Drake, Speedway, etc, just at a better price. When I bought mine off eBay, Drake wanted 3X the money for the exact same set. So don't be scared by the low price, these are quality items. The mirror head is polished stainless, the swan neck arm is chromed die cast with an excellent finish.
    I had more trouble tracking down the '47-specific cowl trim to fill the gap left by the removal of the cowl mounted mirrors than anything else. The Hagens look nice, but I don't see them as 5X nicer and that square mounting base looks a bit too industrial for my taste...
  27. "Honey, does this domed mirror make my *** look big?"
  28. Boy VP you know how to stir things up. I feel I need to point out you don’t live anywhere near the west coast. Before you do that maybe some sort of fender mount, not traditional, not beautiful, but not west coast style ugly, a new sort of ugly. These were not as bad as the tripod mounted ones. 584CAF96-B414-4BD9-A71D-9B9340B318C4.jpeg
  29. Flamed a bone and Dan Hay have some suggestions in the other thread about this.
  30. FishFry
    FishFry
    I got me some of those little convex thingies - not pretty but it helps a lot.
    Also a lot of motorcycle/bike mirrors that are a bit convex have the same size as the cl***ic SoCal mirrors, so you can swap the glas.
