Projects Project 52 Chevy 3100
Discussion in 'The Hokey Ass Message Board' started by Francisco., Sep 7, 2023.
  1. Francisco.
    Francisco.
    Little bit lighter weight than the th400 that maybe a better option for sure.
  2. You still need to get the 400 though, not like they're getting easier to come by :D
  3. 4 pedals
    4 pedals
    from Nor Cal
    First thing, before you spend another dime, is to get a ***le. The state of CA has made it incredibly difficult and expensive when I have had vehicles with ***le issues before. To the point that I absolutely will not buy and un***led vehicle. I wish you luck.
    Mr.48Chev may be on to something, I've never tried that approach.
    The state does issue 500 (I think) Custom built ***les a year. In any case, it's not many. I would suspect that they are gone by January 3rd.
    Devin
  4. Budget36
    Budget36
    Talk to @gimpyshotrods , he can set you straight. He was a VIN verifier for several years.
    If everything is on the up and up, it’s not a bad deal. Time is definitely involved though.
  5. gimpyshotrods
    gimpyshotrods
    Do not do a single thing with it until you have a ***le for the vehicle in-hand.
    Make sure that the tag on the driver's side door hinge post is present, and has visible numbers.
    Make sure that you have an actual DMV bill-of-sale form filled out by the seller.
    Go to the CA DMV website and find form REG31. Print out a copy.
    Find a local law enforcement officer and ask politely if they will verify the numbers on the truck.
    Cross your fingers that the DMV accepts the form when you go to register it. If they do not, you will need to trailer it there for them to do it. Cross your fingers that they accept what they see. If they don't, you will be referred to CHP, and they will verify it.
    None of this, contrary to popular unfounded belief is hard to do. You just need to follow the proper procedures, which include being cheerful, polite, open to suggestion, and treating the DMV workers with the utmost dignity and respect.
  6. gimpyshotrods
    gimpyshotrods
    No. Absolutely not.
    This is 1000x more difficult than just registering and ***ling this as what it actually is.
    I still cannot fathom why I can roll into a CA DMV with my forms already filled out, even with no appointment, and roll back out in an hour, with reg, plates, and a ***le coming in 5-days, even with the most difficult paperwork situation, while others cannot.
    It is NOT THE CA DMV! If I can do this, then anyone can!
    I have lived in several states, and registered cars in all of them. From my experience, the CA DMV is actually the most efficient and easiest do deal with.
  7. gimpyshotrods
    gimpyshotrods
    Everything on the rear needs to be done over, but you can keep the axle.
    The design of that suspension is seriously and dangerously flawed.
    Truckdoctor Andy and Francisco. like this.
  8. gimpyshotrods
    gimpyshotrods
    This is what the tag on the driver's door hinge post should look like. It is in this orientation, on its side, with the serial number line closer to the door.
    It has unique rivets that at NOT pop rivets or screws.
    If it goes to the DMV or CHP they know exactly what they are looking at, and if it is wrong, including the typeface and positions.
    Open your door and make sure that this tag is there. If it is not, then you don't own a truck. You own truck parts.
  9. Francisco.
    Francisco.
    Gimpyshotrods, would I need both the bill of sale completed by seller & the reg31 form? I made sure the tag is there. It’s weathered with most of the black paint having wore off but the thing is stamped in the same fashion as the one posted(Oakland,1952,3100,October & sequence numbers)& the two rivets one on corners opposite of each other. I Hope to God I don’t need to trailer it there cause I don’t have a trailer. I’ll be finding out this coming week.
  10. Francisco.
    Francisco.
    im hoping it goes well.
  11. Francisco.
    Francisco.
    I agree & ***uming I don’t run into trouble with dmv then I plan to return most if not all of that rear suspension to original well minus lowering a bit. I’m trying to figure out if all the attaching points are still there for the leafs. I believe the fronts are not sure what I’m looking at in the back.
    I’ll post a few pics in a while.
  12. Francisco.
    Francisco.
    56205DA8-7185-4A13-964A-EA82579EAA79.jpeg EB0117FF-A409-4F32-8463-D22C6C69922B.jpeg 9C24D63E-18B7-4340-A8E7-B269892DAFA4.jpeg Here’s what I think is for attaching the leafs but I may be wrong.
  13. squirrel
    Francisco. likes this.
  14. gimpyshotrods
    gimpyshotrods
    REG31 gets filled out by a law enforcement officer, DMV employee, or CHP VIN inspector. Since there is no supporting do***ents for this (state issued, that is), it cannot be inspected by a private verifier.
    See if you can figure out where the local PD likes to hang out, and ask nicely if they will look at the serial number plate, sign the form for you. Only the stampings matter. The rest of what is/was on the tag is the same on all of them.
  15. gimpyshotrods
    gimpyshotrods
    You lucked out in that the spring hangers were not removed.
    You can put lowered springs back on there, with stock hardware (or stock replacements and some blocks. Just know that the leaf spring perches will need to have the hole for the spring pack bolt forward 1-1/2". Since this originally had a torque tube, and pivoting spring mounts. If you miss this, your tires will be 1-1/2" forward in the wheel openings, and that looks funny.
    You can make these out of rectangle tubing for pretty cheap.
    If you are clever, you can by wider rectangle tubing and build in your lowering without blocks!*
    As for frame repair.you can carefully remove the rectangle tubing, and replace the cut-outs with like thickness steel.
    On these, I the desire is to go fairly low, I will put in a mini-notch, and box in the top of the factory frame arches.
    If you are not going low enough to need that, I would still box the peak of the arches. These frames are a bit twisty.
    *For the front, you can have the front beam dropped.
    https://droppedaxles.com/chevy-dropped-axles-0
    Sid's can drop your steering arms, too! Posies makes aftermarket springs.
    Like year Chevy p***enger car hubs and drums, I believe, get you to 5-lug on the front. I'm not sure because most of my customers move to discs. Someone will chime in. Dual bolt pattern Chevy/Ford aftermarket wheels (common) will make for a set that fits all 4-corners.
    You only have a couple of choices on lowering the front, so it is best to get that end set before going after the rear.
    Otherwise you can end up with awkward squat or rake.
    A good example:
  16. gimpyshotrods
    gimpyshotrods
    There is nothing whatsoever wrong with a 250 for cruising. A whole mess of my lowrider customers run them.
    They are rock solid. With the right rear end gear they are fine on the freeway, too.
    I am finishing up a 1940 Chevy truck with one backed by a T5 now.
  17. Francisco.
    Francisco.
    Thanks everyone for chiming in, you’ve all supplied a wealth of information. you’re all a very big help & very much appreciated. I’ll post back with more info on the ***ling process & hopefully some better pics once I’m able to get her into the back yard.
    chryslerfan55, 40FORDPU and loudbang like this.
  18. Do yourself a BIG favor and get the Service and ***embly manuals for '49-'53 Chevrolet pickups available from most of the aftermarket suppliers (The Filling Station, LMC Trucks, etc.). The info they contain will help you tremendously, even though you are not doing a 'restoration.
    Good luck!
  19. Francisco.
    Francisco.
    I just went into the dmv to inquire on a reg31 form & the person who I talked to told me they don’t do vin verification. That I could call chp & they would schedule an appointment to come out & check it out.
    after talking with the Chp I was told to email them & they’d get back to me with an appointment. I’m going to email them & see when they’ll come out.
    chryslerfan55 and gimpyshotrods like this.
  20. Francisco.
    Francisco.
    Thanks, I ordered a 47-54 ***embly manual from cl***ic parts online the other day. I figure it’ll help quite a bit especially with all the bs that’s been done to it.
    chryslerfan55 and '28phonebooth like this.
  21. AD trucks were either ***led by ENGINE NUMBER OR Body Number depending on State. They did not have frame serial numbers. 20KP-L 7713 is the body code only. 20= Los Angeles plant, K=1952 body code P- 1/2 ton, L= December built and the 7713 is just the number of the body off the ***embly line.
  22. Budget36
    Budget36
    Measure center to center on the rear leaf spring hangers. I may have a set of rear springs I’ll never use. You’d be welcome to them.
  23. Stock 1/2 ton AD springs are only 1 3/4" wide
    gimpyshotrods and Budget36 like this.
  24. gimpyshotrods
    gimpyshotrods
    California uses the number on the door post.
  25. Francisco.
    Francisco.
    Thanks, I’ll check that out soon.
  26. That is good for the OP to know. It varies, I am on the largest AD group on the planet run by a HAMBer and see every option happening depending on location
  27. Francisco.
    Francisco.
    I reached out to chp & a dmv registration service place to see if either can come out and do a vin verification. The guy I bought the truck from came by yesterday & dropped off a bunch of parts that came with the purchase including the inline 250, rear leafs, radiator, brake parts, extra rear diff, & some miscellaneous parts for the 216.
    anyway, I’m making a list of stuff I need to get after I get this truck registered& im looking at the rear suspension. The ***embly manual shows the rear differential had rounded U bolts but all the U bolts in catalogs & online show squared ones for the 47-54 1/2 ton trucks. I’ve seen some of these trucks have an extra set of springs up top which is kind of weird looking but I’m guessing the squared u bolts would be for those?
    also does anyone know who sells the bottom plate that goes at the bottom of the differential that the u bolts feed through? No one seems to cary that piece that I’ve seen.
  28. Francisco.
    Francisco.
    Here’s a photo of the ***embly manual showing the “rounded” U bolts instead of the squared. 10FC251A-5F6A-4B16-BD1D-18D54B6902DF.jpeg
  29. Francisco.
    Francisco.
  30. Budget36
    Budget36
    So the Ubolts he brought you are probably for the rearend that’s in the truck. Not an original rear end. So check them out, my guess is they will be okay.
    You’ll need to find a plate based off the rear you have, not an original rear.
