Projects Project 52 Chevy 3100
Discussion in 'The Hokey Ass Message Board' started by Francisco., Sep 7, 2023.
  1. swade41
    swade41
    from Buffalo,NY
    chryslerfan55 and Francisco. like this.
  2. Francisco.
    Francisco.
    There’s no u bolts. He brought leafs that probably are for the ford rear end cause they don’t fit the factory hangers.
  3. Budget36
    Budget36
    I mis read your post. But the “extra set of springs” are overload springs, you don’t want or need them for a cruiser/hot rod. They are made to keep the frame off the axle with a heavy load.
    Now, if you scores a bed full of Hemis, rethink it;)
  4. gimpyshotrods
    gimpyshotrods
    The truck originally had a torque tube around the drive shaft, with picoting spring perches.
    This used square u-bolts. The whole ***embly pivoted on the tail of the transmission, like a big swingarm.
    Towards the ending years of the "Advanced Design" trucks, which were 1947-1954, and the first half of 1955, the torque tube disappeared. First on the automatic equipped trucks, and later on all of them.
    The diagram you posted is for those later years. It is the function that you will be working to duplicate with the Ford 9-inch axle that you have now.
  5. gimpyshotrods
    gimpyshotrods
    Francisco. likes this.
  6. ekimneirbo
    ekimneirbo
    I would pay particular attention to the back of the cab before purchasing. Its pretty normal for cab corners to rot and there is often issues with the front cab as it transitions to the floor. Then there is the floor itself.......which often looks acceptable until you sandblast it. Then all the holes show up.
    I'd buy with the idea that you may need to replace/repair those items. The back of the cab however can be a deal killer. Take a magnet and check for existing fibergl*** repairs and look inside very closely.
  7. Francisco.
    Francisco.
    Ah, now i see why it’s shown with the different rear suspension parts, I think I read that this ***embly manual is originally for the 54 model year but because 47-55 1st series are all basically the same that’s what they printed for us all. I wish they’d of made an addendum to that part of the book.
    I will indeed be trying to replicate this setup with the ford rear. So far I’ve found sources for just about everything needed except the axle plate that the U bolts feed through which if I’m not mistaken, also a bracket attatches to for the lower end of the shocks. Do you know who might sell these axle/u bolt plates?
    Thanks for that link.
    thanks for the advice. Will definitely check those areas although I already bought her.
    chryslerfan55 and ekimneirbo like this.
  8. Francisco.
    Francisco.
    Here’s the response I received from chp this morning through email regarding the vin verification. Being that they’re asking for ***le history & I have non but a bill of sale I’m wondering if I should just go through another place to vin verify?
  9. Francisco.
    Francisco.
    Looks like I’ll be at the mercy of the chp. I popped the glove box open. All I found was an old rats nest, looked under the seat but didn’t see anything as far as an old registration. CF48BAEC-724A-49C5-836C-0A0218EC52A0.jpeg
    Ps anyone know how to move the seat forward? I’m trying to access the seat tracks to get it out to clean & check around under it.
  10. Budget36
    Budget36
    Not sure if you have or haven’t, but start with the DMV, explain you have a BoS and serial number plate on the truck. Have them tell you what to do. I don’t want to tell you what I did is the same exact situation, because it’s been 25 years or so and things probably have changed.
    But let the DMV get you going.
    If you don’t want to go in person, call when you have an hour or so to wait for a call back. Use the 800 number.
  11. Francisco.
    Francisco.
    That’s a good idea. I’m trying that before work tomorrow:)
    gimpyshotrods and Budget36 like this.
  12. gimpyshotrods
    gimpyshotrods
    All-together: https://www.americancl***ic.com/1934-54-Rear-Axle-Conversion-Kit/productinfo/93-311/
    -or-
    https://westernch***is.com/1947-54-..._nKl_S0ng2zMGnZee9aLabfkwYY1zI_Vll8f5cP2FFtrA
    -or-
    https://www.cl***icparts.com/1934-54-Rear-Axle-Conversion-Kit/productinfo/93-311/
    These may all be the same kit. They have provisions for modern shock absorbers, so that helps too.
  13. gimpyshotrods
    gimpyshotrods
    If you have the truck there, they will inspect the number.
    It might be worth it to rent a U-Haul and a trailer.
  14. Francisco.
    Francisco.
    :) Exactly what I’ll need for the rear, much appreciated. I was stressing trying to locate the pieces individually.
    I just left the dmv I was able to get a partial registration started on her. I just need to have the vin verified via the chp. I just responded to their email they sent me last week to set up an appointment.
    We’ll see how that goes.
  15. Francisco.
    Francisco.
    Here’s some photos I took this morning. 3FDBB1BB-B368-4F38-975A-0C1A1DACEEC4.jpeg 5665BEAA-2254-4A58-B675-3A5ACE6C770A.jpeg 74ECEEBC-B010-4C74-9192-D0FE91BEFCD0.jpeg 7DCFAF0D-D88C-4D49-BFFC-D2DE83F04A09.jpeg
  16. Budget36
    Budget36
    Generally it’s easier to do it the designed way (DMV stuff).
  17. Francisco.
    Francisco.
    Dang I got scheduled an appointment with chp next Tuesday but I need to bring it in. Anyone know if they do house calls for vin verification?
    gimpyshotrods likes this.
  18. Francisco.
    Francisco.
    Anyone familiar with how to move the seat around to unbolt it from the floor? There is a lever on the driver side facing as you open the door but it don’t seem to do anything.
  19. Francisco.
    Francisco.
    Bump
  20. 05snopro440
    05snopro440
    Google is a wonderful thing: http://devestechnet.com/Home/SeatFrameRR
    The 47-54 Chevy trucks are referred to as Advance Design or AD, which will help you search online. Simple things like removing the seat are well do***ented online, so Google is a good resource for help on stuff like that.
  21. Francisco.
    Francisco.
    Couldn’t find anything though I was mostly checking YouTube. Thanks.
    that site is a gold mine! Thanks again for posting it.
  22. gimpyshotrods
    gimpyshotrods
    No private verifier can do this, as you do not have any supporting do***ents.
    Only CHP can do it, or a friendly neighborhood law enforcement officer.
  23. Francisco.
    Francisco.
    I got a partial registration on it from dmv on Tuesday. The paper work sais it can be verified by dmv, chp or a licensed verifier so I’m hoping that will work?
    I found a licensed verifier & lined up a tow to them on Monday morning.
  24. Francisco.
    Francisco.
  25. gimpyshotrods
    gimpyshotrods
    The rules must have been changed again.
    I gave up being a private verifier years ago because I could no longer perform the work with no supporting do***ents.
    Good luck.
    Budget36 and Francisco. like this.
  26. Francisco.
    Francisco.
    I got around to pulling the seat frames & cleaning/hosing/sanitizing the heck out of the cab interior. Major rats nest in the glove box & under the seat. Also Ripped off all the remaining upholstery. the garbage bag & bucket are all mostly rats nest DD5C85C0-004E-44C2-A379-A110E7F8D2F4.jpeg 3D7CFF33-D207-4A2A-BE69-DCB866EF5A3E.jpeg 0C1DF32A-7F02-4524-927E-857BA5832BAF.jpeg 49A47868-A3D3-48EB-A08B-FD6E89E59721.jpeg 0045EC91-AC97-4B80-9809-3E2556B93EC3.jpeg
    Toms Dogs and chryslerfan55 like this.
  27. ronzmtrwrx
    ronzmtrwrx
    Man, she looks to be in pretty good shape. That cab floor looks pretty solid from my view.
  28. Francisco.
    Francisco.
    Thanks I think it is. I was stabbing around at it with a screwdriver & no rot yet that I found.
    Budget36 likes this.
  29. ronzmtrwrx
    ronzmtrwrx
    I like the AD trucks. They are simple and easy to work on. The factory ***embly manual will be your best friend. I finished up a 54 earlier this year that had been started at another shop about ten years ago. Mostly a restoration with the exception of 12v upgrade, electric wipers and a/c. Fun project.
  30. Francisco.
    Francisco.
    nice, did you do a thread about it on here?
