History Racing a historic flathead dragster
Discussion in 'Traditional Hot Rods' started by ukgav, Jan 17, 2023.
  1. ukgav
    ukgav
    I forgot to post this at the time so here we go...
    Around the middle of last year I became the temporary custodian of the Charles Bang flathead dragster.
    I have known the owner, Dean Butler, for a few years now and every time I visit him I try to convince him to drag the car out of retirement. Dean is still a very busy businessman and has an enviable collection of vehicles which mean the dragster is way down on his list of priorities so his solution was simply to tell me to take it away, go through it, get it running and potentially race it!
    Not ideal timing as I'm trying to get my coupe built but there was no way I was going to p*** up the opportunity to tinker with such a piece of history so the 32 was put on the back burner for a little while.
    The rough history is that Charles Bang was from Cincinnati and a talented engineer. In the 60's he decided he wanted to go drag racing so built himself this flathead powered rail. He ended up being very successful in the Cincinnati area during the late 60's early 70's going on to set the D cl*** record at 10.39seconds at 132mph before retiring the car.
    Dean got to know Charlie years later while Charlie worked on and tuned some of Dean's cars. Talk turned to the dragster if he still had the car. He did but it had been dismantled after Charlie had stretched it to go dirt drag racing. Dean wanted the car so commissioned Charlie to rebuild it just as he had it in the 60's although the motor isn't quite as 'built' as the original.
    Quick spec now is the engine 276ci, has a 4 inch crank, forged pistons, isky 400 cam, vertex mag and 4 Stromberg 48's. Gearbox is a side shift early 3 speed, 1st isn't used, and the rear end is a narrowed banjo but with later half shafts.
    It has been in Dean's collection since the rebuild but has occasionally seen the light of day. In 2004 Dean flew Charlie over to the UK, while now in his 70's, to drive the car at the Nostalgia Nationals where he ran a best of 11.26 at 124mph, lifting the wheels on every launch. In 2006 it took part in the historic dragster display at Goodwood and was fired up during the daily cackle fest. Other than being displayed a couple of times at events around 2008 it hadn't been ran.
    Pics from when I picked it up
    The plan now was to go through the car and get it to the point that it could be raced again at the Hot Rod drags at Santa Pod raceway last September.
    A few issues arose during the rebuild like 1st gear being smashed, airheart brake calipers were corroded, carbs needed rebuilding, etc etc.
    The spider gears were also no good so I asked my good friend Pete (nutrocker) to weld them up so we had a 'Lincoln locker'!
    By this point Pete had also jumped on board to help with the car at the track, loan a trailer etc so I asked Dean if Pete could co-drive which he agreed to.
    First fire up, brake and gears check.
    So how did we do?
    Pretty good but we couldn't better Charlie's performance from 2004. We put 11 runs on the car over the weekend with Pete running a best of 11.7 at 116mph and me a 11.8 at 116mph. Of course we were both acutely aware that it wasn't our car and that it is pretty historically significant so side stepping the clutch off the line and pulling wheelies wasn't going to be an option!
    The coolest part was that we got to match race with the only other flathead dragster currently competing in the UK owned by Bradley and Ken Cooper. Ken is THE flathead guru over here and was running 10's in his own flathead dragster back in the 60's. Their car now runs high 10's on methanol so had us covered on every race but it was fantastic to have the cars side by side.
    The whole weekend was an incredible experience and a real bucket list item ticked off. It wouldn't have happened though without Pete's help and Dean's generosity. The car is now back with Dean but we will hopefully run it again in the future.
  2. Jalopy Joker
    Jalopy Joker
    WOW! Thanks for sharing. what an opportunity, and you took it forward. Congrats. hope that it will be on the track again.
    Stogy, 210superair and Church Key like this.
  3. GordonC
    GordonC
    Thats awesome! Good on you!
    Stogy likes this.
  4. NoSurf
    NoSurf
    Very very cool.
    Stogy and seb fontana like this.
  5. Petejoe
    Petejoe
    from Zoar, Ohio
    Bad ***. Thanks for sharing.
    Stogy likes this.
  6. And a good time was had by all.
  7. 210superair
    210superair
    from Michigan
    Awesome...
    Stogy likes this.
  8. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    nice
    And I like the balcony seating on the tower at Santa Pod. Unique.
    Stogy likes this.
  9. 1940Willys
    1940Willys
    Very Nice! Have Fun!
    Stogy likes this.
  10. ukgav
    ukgav
    All being well we hope to attend a couple of events this year and possibly lean on it a bit more.
    Stogy likes this.
  11. roseville carl
    roseville carl
    Wow how did I miss this thread??? Verry verry kool yer always welcome at Eagle Field!!!!!!!
  12. youngrodder1929
    youngrodder1929
    Very cool ! Thanks for taking the time to share and take us along !
    Stogy likes this.
  13. Atwater Mike
    Atwater Mike
    This KEEPS the 'Merry' in Olde England! Good on you!
    Stogy likes this.
  14. ukgav
    ukgav
    Man that would be awesome. Unfortunately a rather large expanse of water and limited funds probably means it will never happen.
    Baumi and Stogy like this.
  15. fredb
    fredb
    Thank you for sharing…nothing like a flathead digger to get the blood boiling
    Stogy likes this.
  16. Squablow
    Squablow
    It's shocking to me that the guy was pulling wheelstands with this car through a regular '48 Ford side shift trans and never broke it, that is the definition of someone who's one with his machine. The sideways mounted radiator is neat too, not sure I ever saw that before, but it makes sense. Great car with great history, thanks for sharing.
    Stogy likes this.
  17. Rand Man
    Rand Man
    They are tons of fun.
  18. ukgav
    ukgav
    Yeah, both me and Pete can't work out how he managed to race all those years and not smash a trans. Sadly Charlie is no longer with us to share his secret.
    The radiator and cooling system was an addition during the restoration purely to make the car more user friendly at the track. No need for a tow car, just drive it back to the pits.
    Toms Dogs, Stogy and Squablow like this.
  19. flatheadpete
    flatheadpete
    from Burton, MI
    Dang that's cool!
    Stogy likes this.
  20. ukgav
    ukgav
    One year on and Pete and myself found ourselves once again racing at the Hot Rod drags in the Charles Bang special.
    Huge thanks to Brett for loaning us his trailer and to Damon who ably ***isted in running the car all weekend.
    Slight bit of drama on the Thursday as the airheart caliper's that I had to strip and rebuild numerous times last year to get them to stop leaking decided they didn't want to hold fluid again after sitting for 12 months. 3 hours and numerous rebuilds later we had brakes that worked, sort of.
    Once again we had the honour of match racing Ken and Brad cooper although engine woes put them out on the Saturday. During the Friday we were also able to pair up with Azza and Eff's Topolino. Another rear deal, flathead powered, built in the 60's dragster that hadn't seen a drag strip for many many years.
    Times were down on the previous year with a best of 12.2 but we think the clutch has seen better days and is slipping on the launch, backed up by slower 60 foot times. Still a great weekend and hopefully if we get to run the car next year we can spend a bit of time sorting the little issues out.
    IMG_0044.jpeg IMG_0055.jpeg 178CBE7C-16EF-4918-B311-5BDF4C34D7A1.jpeg 6a003177-9645-463a-9837-7c865def613a.jpeg IMG_0044.jpeg 6dd7efbb-4bf6-4a19-94a1-fe7aeb4cc7a1.jpeg IMG_0071.jpeg IMG_0063.jpeg
  21. Way to go! I enjoyed this thread . . . and this dragster is doing pretty well for a small flathead motor.
    Stogy likes this.
  22. 1930ModelA
    1930ModelA
    So cl***ic. Watched the clips several times. Thanks for sharing.
    Stogy likes this.
  23. mpbdlc
    mpbdlc
    That flathead is gorgeous and it sounds amazing in the videos! Thanks for sharing
    Stogy likes this.
  24. Harv
    Harv
    from Sydney
    Very, very cool :cool:
    Cheers,
    Harv
    Stogy likes this.
  25. Stogy
    Stogy
    Thanks for sharing @ukgav...pretty cool what you fellas did there...and that's pretty awesome performance for babying it...
    Yeah the Coupe...I'm popping over to see where you are with it...
    brady1929 likes this.
  26. ukgav
    ukgav
    Thanks man. The coupe is getting there slowly.
    Stogy likes this.
  27. roseville carl
    roseville carl
    ABSOLUTLY Love it !!!!!!!!!
    51504bat, razoo lew and Stogy like this.
  28. brady1929
    brady1929
    Great story and history.
  29. AmishMike
    AmishMike
    Fun times, great experience. Be nice to see detail story & pictures on the Cooper rail
  30. ukgav
    ukgav
    Here you go. A feature on Bradley and the current dragster and also a 5 part interview with Ken detailing his racing exploits from the early days.
    Bradley Cooper's story (eurodragstereventcoverage.com)
    Ken Cooper's story and history - Part 1 (eurodragstereventcoverage.com)
    Ken Cooper's story - part 2 (eurodragstereventcoverage.com)
    Ken Cooper's story - Part 3 (eurodragstereventcoverage.com)
    Ken Cooper's story and history Part 4 (eurodragstereventcoverage.com)
    Ken Cooper's story - Part 5 (eurodragstereventcoverage.com)
