Hot Rods Turn signal type
Discussion in 'The Hokey Ass Message Board' started by Timothy Murphy, Sep 21, 2023.
  1. Timothy Murphy
    Timothy Murphy
    I’m building a ‘32 Ford roadster with an early ‘60s look. What was used for the turn signal switch? Thank you.
    Stogy likes this.
  2. Bandit Billy
    Bandit Billy
    Hand signals. I just used one today on my home from work.
    chevyfordman, Stogy, SS327 and 6 others like this.
  3. dana barlow
    dana barlow
    from Miami Fla.
    Like Bandit said,,,I used hand signals also,,starting from 1959 tell now with my 28A. Now days there's a few I'd like to give finger signals too.
    chevyfordman, Stogy, da34guy and 4 others like this.
  4. klawockvet
    klawockvet
    The people who don't know how to shift a manual transmission or roll up a window with a crank, have no idea what a hand signal is. I afraid that cons***utes 90% of the drivers on the road today.
    5window, RMR&C, Hotrodmyk and 4 others like this.
  5. Bandit Billy
    Bandit Billy
    To be honest it was the finger signal I used. There isn't a hand signal for "why are you doing 35 MPH in a 55 MPH zone on a sunny afternoon on a 2 lane highway...IN THE FAST LANE"? However, I felt I expressed myself quite clear with a single finger, pointed toward the slow lane and "flashing". She responded promptly.
    You're all right in my book Dana. Except for that whole "small headlight thing", but we can still be friends. I don;t drive at night much anyway.
    Stogy, SS327, kadillackid and 3 others like this.
  6. Joe Blow
    Joe Blow
    Add-on's were Allstate, Signal Stat, Yankee....to name a few. Here's a Yankee I have.
  7. Bandit Billy
    Bandit Billy
    That's a fact, Jack!
    Hotrodmyk likes this.
  8. skooch
    skooch
  9. Bandit Billy
    Bandit Billy
    I used that on my OT dune buggy to be compliant with local rules. It works great but end up driving with my right turn indicators blinking...a lot. I used to make fun of gray hairs doing that, now I am one.
    The light on the stalk works fine but out of sight of mind. And I am out of both.
    Stogy, Hotrodmyk, 41rodderz and 3 others like this.
  10. 51504bat
    51504bat
    This self cancelling turn signal might be considered OT but one from a vintage British car is an option. It mounts on the dash or a bracket under the dash unlike the typical column mounted add on switch.
    Description from a supplier's catalogue:The pneumatic turn signal switch ***embly fitted to a variety of cl***ic British cars was an ingenious solution to the need for a simple self cancelling turn indicator s-l1600.jpg
    Stogy, Ned Ludd and Bandit Billy like this.
  11. BJR
    BJR
    Remember, it's made by Lucas, the prince of darkness. The reason Britts drink warm beer is Lucas also makes refrigerators. :D
    Stogy, SS327, winduptoy and 2 others like this.
  12. Bob Lowry
    Bob Lowry
    Goes for the horn, too...
    Stogy, Hotrodmyk and dana barlow like this.
  13. DDDenny
    I'm not much of a traditionalist.
    Tman, winr, Stogy and 5 others like this.
  14. Ned Ludd
    Ned Ludd
  15. klawockvet
    klawockvet
    I never liked the looks of the aftermarket switches. I used a Tikin Through Time kit that mounts on the shift lever. I got a long piece of shrink wrap and covered the wires that are about the size of a telephone cord. It has a loud obnoxious noise that will remind you to switch it off. IMG_4013.JPG
    Tow Truck Tom and chevyfordman like this.
  16. '29 Gizmo
    '29 Gizmo
    from UK
    If you have the stock column use the stock headlight switch rewired to control the turnsignals.
    RICH B, winduptoy and Ned Ludd like this.
  17. Tow Truck Tom
    Tow Truck Tom
    from Clayton DE
    Not that you need to know.....
    Back when electric signals came into vogue, conversions were available that featured a small rubber wheel; - that rode on an angle to contact and be rotated by the steering wheel hub.
    After turning,,, the wheel tripped and canceled the switch.
    Today most switches are for use on Big trucks.
    The act of dragging a 53 footer around a corner requires the wheel to be turned in both directions.
    A series of moves to go wide, turn, and tuck the tractor in, then clear the trlr wheels at the corner and finish in the proper lane makes canceling the signal before the finish improper.
    Sooo most common switches today are priced so.
    The specialized ones for rod and custom, can get pricey. IMHO
    jaracer and winduptoy like this.
  18. 41rodderz
    41rodderz
    from Oregon
    I believe Limeworks has a cool aluminum finned one.
  19. X38
    X38
    That's an attractive decorator shell, the inside is the same as the one in post 8 that everybody sells.
    Tman and olscrounger like this.
  20. Flathead Dave
    Flathead Dave
    from So. Cal.
    I would go with the ones that blink...
  21. hotrodA
    hotrodA
    Here’s one that I found out about from a Brit HAMBER @neilswheels
    It’s early VW beetle or van. Manual canceling, simple in appearance and fits the early Ford column
    BUT, not so easy to find and kind of pricey unless you live across the pond.
    Used it in my 40/1 pickup.
    His (RHD)
    Mine
    chevyfordman, skooch and pprather like this.
  22. Billy I use hand signals all the time, I have never owned a bike with turn signals and a lot of my old cars/trucks don't have them either.
    As for the original question, yes hand signals are trad, or these were used on cars that did not come with them.
    Tow Truck Tom and Bandit Billy like this.
  23. X38
    X38
    That's a Hella piece and you can still buy them new, although the housing is now plastic rather than metal.
    I'm using one. I also have an old metal housing version out of a VW. The new one I have mounts with the same radius as the 40 mast jacket, the VW is tighter (like the pic of yours.)
  24. ramblin dan
    ramblin dan
  25. Bob Lowry
    Bob Lowry
    And, depending on your diameter/style of your steering wheel hub, the factory turn signals from
    a '53 to '62 Corvette may fit. Self-canceling. Just attach a small plate to the back of your steering
    wheel hub. Very easy to install.
  26. Bandit Billy
    Bandit Billy
    I saw the plastic housed unit when shopping for one for the dune buggy. The United piece is chrome steel though.
    Tow Truck Tom, Stogy and Hotrodmyk like this.
  27. Doublepumper
    Doublepumper
    from OR-WA, USA
    I like the United Pacific unit. Replaced the indicator light with a LED...I don't forget to turn it off now.
    Bandit Billy and Stogy like this.
  28. Stogy
    Stogy
    So @Timothy Murphy, what did you settle on...I'm going out to take a pic of mine...Its a modern knock off of a vintage unit with 4 ways added...a nice feature really these days...Not self cancelling and the odd time I get caught on that one...:D
    Its a column mounted with a hose clamp along with the tach...fitting to the Hotrod narrative along with my outhouse door locks...
    Tow Truck Tom and Joe Blow like this.
  29. Dad's roadster just had a couple toggles on the dash. Each had a jewel light to indicate that it ws pn.
  30. vtx1800
    vtx1800
    IMG_5311.JPG IMG_5312.JPG I've had this one laying around a few years, it would need some "fancy wiring" because it isn't a six or seven? wire unit. I had a similar one (with more wires) that I used on a 49 Ford...wish I'd have kept it. This unit has the roller to turn it off.
    Okie Pete, Hotrodmyk and pprather like this.
