Hot Rods 29 RPU- "Street/Strip" B/SR Build - Marty Strode
Discussion in 'The Hokey Ass Message Board' started by Marty Strode, Dec 19, 2019.
  1. Marty Strode
    Marty Strode
    I don't know what that is ?
  2. Marty Strode
    Marty Strode
    @28rpu recommended using a torch and carefully heat the pipes from the inside to cure them, since it will be a while before I start the engine. The ones on his Henry J look great, even after 8 years !
    GuyW likes this.
  3. lumpy 63
    lumpy 63
    Thermal flame spraying , it leaves a textured white high temp coating on the headers. When they are applying it it looks like sparks shooting out of a spray gun. A few powder coating places do it around here. I have found it to be much more durable than paint. it seems to me it was really popular in the 60s-70s?
    loudbang and 427 sleeper like this.
  4. lumpy 63
    lumpy 63
  5. lumpy 63
    lumpy 63
    These are on my 37
    427 sleeper likes this.
  6. Marty Strode
    Marty Strode
    Stogy and lumpy 63 like this.
  7. My Dad would have that done on his headers and rams horn exhaust manifolds, It never failed. He called it aluminizing. Oakland sand blasting in Oakland CA. did it for him. This was back in the 70's.
    porkshop and Stogy like this.
  8. Larry Anderson
    Larry Anderson
    Stogy likes this.
  9. lumpy 63
    lumpy 63
    It feels like 60 grit sandpaper.
    Stogy likes this.
  10. flatheadgary
    flatheadgary
    from boron,ca
    flame spraying is something we did in aerospace quite often.
    alanp561 and Stogy like this.
  11. Marty Strode
    Marty Strode
    I built headers and side pipes for a Big Block Cobra, and the guy had them aluminized, it was like 24 grit. A little rough for my liking, but yours look great.
    GuyW, lumpy 63 and Stogy like this.
  12. Dean Lowe
    Dean Lowe
    The headers on my previous RPU were aluminized, still are. 60 years later they still look presentable.
    GuyW, porkshop, lumpy 63 and 3 others like this.
  13. Marty Strode
    Marty Strode
    ottoman, Dyno Dave, krusty40 and 30 others like this.
  14. Larry Anderson
    Larry Anderson
    Stogy likes this.
  15. curbspeed
    curbspeed
    Marty, please tell me more about how things went with your rollbar conversation and whether it will be NHRA legal or not. I've been trying to figure out a way to look traditional and still be legal. Are you? I'm in the planning stages in my head.
    Stogy likes this.
  16. alanp561
    alanp561
    Did a lot of it on aircraft cylinders back in the early '60s.
    Stogy likes this.
  17. bskustoms
    bskustoms
    from Aloha, Or.
    Boy the RPU is really killer
    Stogy and Dean Lowe like this.
  18. Marty Strode
    Marty Strode
    Dale,
    It will be legal to 7.00 1/8 mile, 11.00, 1/4 mile, like any roll bar. The reason I had Dave stop by, was according to the rule book, it needs 6" square plates or 36 square inches per mounting plate in another configuration. He said the plates can have flanges formed, the keep the size of the footprint smaller, which is what I need, to get the bar in and out.
  19. curbspeed
    curbspeed
    Thanks Marty. Keep posting pics of the roll bar as you progress. I don’t want a cage. Something simple like yours. Cheers from the High Desert Dale(Is it all bolted in?)
    Stogy and Just Gary like this.
  20. Marty Strode
    Marty Strode
    It will be.
    Stogy and curbspeed like this.
  21. Marty Strode
    Marty Strode
    Dale if you are doing a closed car, and the back braces aren't too long, it will slip out the door opening. This 32 sedan has 2 bolts into the frame rail, and the other into a gusseted bracket welded to the frame rail. IMG_3784.JPG IMG_3782.JPG
    Stogy, rod1, alanp561 and 2 others like this.
  22. curbspeed
    curbspeed
    Marty, 29 roadster with a blown Olds 324 and a Muncie 4 speed, 66 Bronco 9inch, A/SR style. Period 1962-65. I'm building the ch***is now. What do you mean by flanges formed? Thanks
  23. GuyW
    GuyW
    It is molten aluminum spray I believe, I have a set that I had sprayed....
    Stogy likes this.
  24. dirt car
    dirt car
    from nebraska
    While a helmet is required, I was wondering about that that bar to the rear being a head knocker, but then the closer to the head the less momentum should the unspeakable happen.
    Stogy likes this.
  25. Marty Strode
    Marty Strode
    I just finished the rear brackets and plates for the roll bar rear struts. I wanted everything under the bed floor, so if the roll bar is removed the boards can be replaced, and it will be flat and free of exposed mounting brackets. The brackets that will be welded to the frame are 3/16, and the roll bars plates are 10 ga. I formed the lower brackets in the press, and upper plates in the hand brake. Also, I have all the wheelie bar brackets fabbed, and will mount them once the truck is sitting on the floor. Then on to the main roll bar hoop mounting. IMG_0570.JPG IMG_0571.JPG IMG_0573.JPG IMG_0574.JPG IMG_0576.JPG IMG_0577.JPG IMG_0578.JPG
    bymanr, lumpy 63, curbspeed and 13 others like this.
  26. Marty Strode
    Marty Strode
    I did a rough mockup with the wheelie bars, the length is perfect, now need to decide the wheel height, and tack the brackets. There is plenty of adjustment, so I am starting in the middle. IMG_0579.JPG IMG_0580.JPG IMG_0583.JPG IMG_0585.JPG IMG_0587.JPG IMG_0588.JPG IMG_0589.JPG
    bymanr, ottoman, Dean Lowe and 27 others like this.
  27. rod1
    rod1
    Nice ,as always Marty !
    Stogy likes this.
  28. bskustoms
    bskustoms
    from Aloha, Or.
    Love the look of the white headers against the black body
    Stogy and loudbang like this.
  29. Marty Strode
    Marty Strode
    I worked on the transporter yesterday, the pan on the C-6 trans has had a leak since I put it together. So I bought a deep aluminum pan and Lubelocker gasket. It carries and extra couple of quarts of fluid, and the drain plug is also very handy. IMG_0595.JPG IMG_0596.JPG IMG_0597.JPG IMG_0598.JPG
    prez, bymanr, Dean Lowe and 12 others like this.
  30. Marty Strode
    Marty Strode
    I have been experimenting with what to do with the hood, I fabbed a scoop that I really didn't like, it would be more suited on the hood of G***er. Tonight I laid out an oval and cut it out, using the Kett Shear to cut the heart out and finished the t******* with Wiss tin snips. I may form a flange down around the inside. But after cutting it out, I think it might p*** just the way it is. It will make squirting the injectors easy ! IMG_0161.JPG IMG_0599.JPG IMG_0601.JPG IMG_0604.JPG Hood 1.jpg Hood 2.jpg Hood 3.jpg
    bymanr, brEad, '40 Coupe Fan and 12 others like this.
