Art & Inspiration Let's see some rattle can excellence
Discussion in 'The Hokey Ass Message Board' started by 57chevymadman, Aug 20, 2023.
  1. Deuce Daddy Don
    Deuce Daddy Don
  2. D-Russ
    D-Russ
    Preface: This is not a rattlecan job, but equally low tech and low budget, so I thought it could be a good option for folks comfortable with mixing paint.
    I had a pretty bad scratch on my car that I tried to fix by filling it with paint applied with a fine brush and then color sanding and buffing to bring the surfaces to the same level. Welp, the color sanding stage got a little out of hand and I got down to sealer and filler, so I had to respray the area. I have a couple of spray guns and a touch up gun, but nothing that would spray a small controlled area. So in my airbrush research, I came across these little aerosol spray canisters from Preval. They come with a jar and allow you to spray any thinned paint without a gun or compressor. It was only about 8 bucks so I figured I'd give it a try. IMG_9517.jpeg
    Here's the area I needed to fix:
    A little rattle can sealer: IMG_9515.jpeg
    Feather the edges:
    Shot the single stage top coat with the Preval sprayer (could have been thinned a little more):
    Color sand the entire area up to 2000 grit:
    And buff the finish:
  3. 4speed411
    4speed411
  4. topher5150
    topher5150
    Is this an automotive paint or just regular rusto off the shelf?
    Deuces and Sharpone like this.
  5. 4speed411
    4speed411
    Off the shelf, 2X Screenshot_20230924-175214.png satin primer paint
    Deuces, bondojunkie, Sharpone and 2 others like this.
  6. the rustoleum special. a nice thin coat of paint. 20230924_153105.jpg 20230924_153118.jpg 20230924_153122.jpg
  7. 57tailgater
    57tailgater
    from Georgia
    Deuces, Sharpone and topher5150 like this.
  8. topher5150
    topher5150
    turned out pretty nice. maybe a few more coats and some sanding IMG_20230925_173242380.jpg
  9. PONTNAK123
    PONTNAK123
  10. kabinenroller
    kabinenroller
    Rattle cans are great but shaking them is a PITA. So share your ideas for shaking the cans. I have seen the hose clamp a can to a reciprocating saw trick but I’m looking for a better mouse trap.
  11. lostone
    lostone
    from kansas
    I always shake my cans upside down. I figure the pigment settles to the bottom and the ball always goes to the end of the can so I shake it upside down thinking the ball will beat the pigment off the bottom and the pigment will have to fall thru the length to get back to the other end. Hopefully being mixed into the liquid as it falls thru.
    Then before I use it I spin it right side up and do it for about a minute then I'm ready to spray !!
    Deuces, bondojunkie, Sharpone and 4 others like this.
  12. atch
    atch
    Immersing the can in hot water for a few minutes seems to help it spray better. A 2-liter soda bottle with the top cut off makes a perfect vessel for this.
    Deuces, MMM1693, Sharpone and 5 others like this.
  13. atch
    atch
    I used to have quite a few pix of home-made shakers but have lost all of them except this one and a couple of Sawzall types.
    Deuces, Sharpone, charleyw and 9 others like this.
  14. PONTNAK123
    PONTNAK123
    grille shell rattle can. car was painted earl schieb 1963. took hood top to earl schieb (snap) and they made me 2 rattle cans thumbnail_20230929_102351 (1).jpg thumbnail_20230929_102256.jpg
    Deuces, clem, Splitbudaba and 13 others like this.
  15. Johnny Gee
    Johnny Gee
    from Downey, Ca
    At work I’d chuck a spray can side way’s into the jaws of the LeBlond lathe at its lowest speed. Clunk clunk cluck…
  16. 08racer
    08racer
    from Gilbert AZ
  17. Same.
    I had no idea either. Who would have thought There are different nozzles for run of the mill spray paint.
    Deuces, bondojunkie and Sharpone like this.
  18. In the future if you ever do this again use a hardener like this one↓ or Krylons harder
    https://www.tractorsupply.com/tsc/p...wkEoK_X4jj8OhBxvvfoGNDr46MHshQnxoC9W4QAvD_BwE
    The hardener helps the paint get a better shine and it definitely helps it set up quicker so at least you can handle it.
    Also instead of using mineral spirits (mineral spirits and paint thinner evaporate way too slowly) use acetone, it evaporates faster and it causes the paint to flash off a little quicker Not to mention as it evaporates it seems to pull out most of the orange peal in the paint. The only time I won't use acetone is if it's about 100° outside and I'm spraying in the direct sunlight.
    I have sprayed probably 20 travel trailers with the enamel rustoleum / tractor supply/Krylon type paints, a few even won awards at trailer shows here in California.
    Enamel paint generally takes a long time to truly dry But if you use the hardener and the acetone you can get it touched dry within an hour or so avoiding a lot of the bugs that seem to be attracted to fresh paint vapor.
    To anyone else reading this that has never sprayed enamel paint, The paint doesn't get truly hard or dry for a few weeks generally speaking If you stick your nose up to it and you can smell it it does not completely dry.
    At any rate I am going to paint my Model A pickup with tractor supplys majic brand Massey Ferguson red with a cheap Harbor freight spray gun And then once it is completely dry I'm going to spray it with a gallon krylons acrylic clear.
    For 2 gallons of red paint and a gallon of clear plus a gallon of acetone It's a little over $130- (as of three or four weeks ago).
    I don't know if I will have a chip foose show car But to the average person it will look as good as anything else on the road I love my cheap paint jobs that are easy to repair if fender benders or damage happen.
    Deuces, bondojunkie, Sharpone and 3 others like this.
  19. Ask and you shall receive I did not come up with this invention that is not me in the video I saw this a few years ago and it is stuck in my head ever since...
    That being said for full disclosure I have never actually spent the 10 minutes to make the gizmo lol I will say this guy in this video has got to be one of the most practical application hands-on people I think I've ever watched.
    I learned how to repair an arc welder from him but that's another story.
  20. ibhotrod
    ibhotrod
    The dash in my 50 Chevy. The black base then Lil Daddy Roth rattle bomb cherry pie flake and 2K rattle can clear over the top.
  21. dart4forte
    dart4forte
    from Mesa, AZ
    My junk
    Deuces, Okie Pete, Sharpone and 2 others like this.
  22. Sanford&Son
    Sanford&Son
    from Visalia,Ca
    It was a little scary, when I had to take the black rattle can to the doors on my Sanford & Son pickup 18 years ago!
  23. Sharpone
    Sharpone
    Heat shield that I free hand engine turned and then sprayed a couple coats of Krylon metal cast and a coat of clear on the carb sided polished and cleared exhaust side. I am really impressed with the work you all do with rattle cans IMG_1830.jpeg
  24. clem
    clem
    I store them upside down as soon as I buy them, as the guys in the shop always store them upright for months on end. Then if not using within a few days I might stand upright or lay them on their side the day before I use them, sometimes in the sun, if cold inside, then only shake them for around 30 seconds before use.
  25. verde742
    verde742
    My favorite roadster in Gilbert, Az.
    wonder if its still around ?
  26. verde742
    verde742
    HINT ??? What works best to get over spray of Rust O Leum off yer tires ????
  27. 05snopro440
    05snopro440
  28. Splitbudaba
    Splitbudaba
    PXL_20231012_210005134.jpg So far any primer red areas are rattle cans! Krylon red oxide for the body, $38.00 for a gallon. I can afford that price, PPG is out of reach!! Besides when I get a chip or scratch, out comes the rattle can!
  29. El Caballo
    El Caballo
    from Houston TX
    Many moons ago I did a thread on the lace job that I did on the roof of my old ‘58 Biscayne. I miss that car. IMG_7574.jpeg IMG_0739.jpeg IMG_0746.jpeg IMG_0747.jpeg IMG_0749.jpeg IMG_0751.jpeg
  30. p__moore
    p__moore
    Body and wheels are rattle can, chassis and engine are paint brush.
    The trigger handle was a good investment.
