Technical The upholstery thread to end all threads
Discussion in 'The Hokey Ass Message Board' started by Roothawg, Jan 5, 2021.
  1. Sporty45
    Sporty45
    I got a lot of fabric samples and ended up liking the feel and look of this particular one. I've played around with the samples quite a bit, like mentioned earlier I glued some to 1/2" sew foam and tried doing some pleats and seams. It sews nicely so far, and I'm hoping it works out for me. I'm going to start with some small stuff first, like kick panels to see how it goes.
  2. stanlow69
    stanlow69
    It`ll be good for flat panels. Just find a contrasting material for the headliner if it`s a bow type. Post some pictures.
    Sporty45 likes this.
  3. safetythird
    safetythird
    Sunbrella works great on basic cushions. I did these on my boat. First time!
  4. Sporty45
    Sporty45
    I actually have picked out material for the headliner that is much more stretchy! :D
    I'll take pics as I go ;)
    stanlow69 likes this.
  5. jims50chrysler
    jims50chrysler
    This thread is great! I just finished reading through the whole thing and have learned a lot, thanks all.
    I have an Adler that I have been practicing with and will be doing the interior on my 50 Chrysler Windsor this winter.
    be prepared for some questions. lol
  6. Whoamel
    Whoamel
    from So Cal
    Well, here's my first seat cushion. It's not pulled tight or attached yet, but I'm pretty satisfied with it. It's mentioned elsewhere, but this is for my 40 Ford.
    The original seat was terrible, and I suspect a previous owner took it to Tijuana and requested as cheap as possible. They just stuffed dacron over the top of the original worn out upholstery, and recovered right over it.
    My first seat recover required spring repair, and new custom foam, so being new and starting from (almost) scratch was a bit of a tall order. I had a lot of trial and error. But, I'm a crotchety old fart, and I don't give up easily.
  7. zman
    zman
    from Garner, NC
    I need to buy a machine, all my local guys are flakes. lol
    JD69, RICH B and Sporty45 like this.
  8. JD69
    JD69
    from Hockinson
    One of the reasons I bought a machine...
  9. jeepster
    jeepster
    from wisconsin
    First attempt at seat covers....
    TrialByError, Cosmo49, reagen and 7 others like this.
  10. Sporty45
    Sporty45
    I have a question about making windlace. Do you guys glue it, sew it, or both? And I'd love to see pics of it being made!
  11. RICH B
    RICH B
    Sewn.
    brEad, GuyW, reagen and 3 others like this.
  12. Sporty45
    Sporty45
    Very nice! What do you use for a foot on your machine to make it?
  13. RICH B
    RICH B
    Nothing special; I just hold it tight to the narrow side. I think my daughter-in-law may have a custom foot for windlace that gets it tighter to the foam cord, I'll ask her next time.
  14. JD69
    JD69
    from Hockinson
    I use a zipper foot.
    3quarter32 and Sporty45 like this.
  15. Sporty45
    Sporty45
    I was thinking of using my cording foot. That puts the needle foot real tight to the cord, if i put the cord to the right of the needle. I ordered some 1/2" sponge rubber cord to make them, but for practice, I picked up some 1/2" backer rod at Home Depot.
  16. JD69
    JD69
    from Hockinson
    Try it.
  17. Sporty45
    Sporty45
    First 2 attempts. Both with the cording foot. windlace.jpg I think I need more practice!
  18. jakesbackyard
    jakesbackyard
    from ND
    I’m lucky enough to have 1/2” windlace feet (on left) that I acquired 30+ years ago. They are probably older than me. Lol. They work great. An alternative is to take the original flat feet which are rarely used (I keep my small cording feet on 99% of the time.) and remove one side of the main foot to be able to get close. The left black foot is an original flat foot. The other two black feet have had one side removed. I use them for special times I need to get close. Work great for sewing the edge of sun visors.
  19. Sporty45
    Sporty45
    I found this set for 1/2" on amazon. How does this set look to you?
    https://www.amazon.com/Consew-Walki...ext&ref_=fplfs&smid=A3HPQS1YHCBIBL&nis=6&th=1
    Also this one.
    https://www.amazon.com/Sewing-Walki...ext&ref_=fplfs&smid=A3HPQS1YHCBIBL&nis=6&th=1
  20. JD69
    JD69
    from Hockinson
    Dick Stevens and Sporty45 like this.
  21. Roothawg
    Roothawg
  22. Sporty45
    Sporty45
    Just ordered a set :D
    Dick Stevens likes this.
  23. jakesbackyard
    jakesbackyard
    from ND
  24. Roothawg
    Roothawg
    I ordered a 1/2" one myself today......
    Sporty45, Dick Stevens and JD69 like this.
  25. Sporty45
    Sporty45
  26. Whoamel
    Whoamel
    from So Cal
    If it's smooth, I'd recommend roughing up the surface with a quick sandpaper treatment. I've done that with a few smooth sided wood and plastic panels and haven't run into any problems yet. I usually use 120-220 grit with a lighter touch not to gouge the surface.
  27. Sporty45
    Sporty45
    Got mine today. Look pretty good. Haven't had a chance to try it yet, though. Have you gotten yours?
  28. Roothawg
    Roothawg
    Showed up last night. All I have done is looked at it...
  29. Whoamel
    Whoamel
    from So Cal
    I have no immediate use for a foot like that, but I'm going to get one, anyway. For $13 or so, seems like a nice thing to keep on hand.
  30. Roothawg
    Roothawg
    Windlace for a 30's era Ford is why I am getting mine.
    Whoamel and Sporty45 like this.
