Hot Rods Stromberg 97 vs Holley 94
Discussion in 'The Hokey Ass Message Board' started by stubbsrodandcustom, Sep 26, 2023.
  1. stubbsrodandcustom
    stubbsrodandcustom
    from Spring tx
    I see benefits in both designs for sure. So trying to get the low down on why you like one over the other, quirks, performance etc.
    So what's the benefit of Stromberg's vs the Holley's in yall's opinions for multiple carb setups?
    Photos for reference only....
    products-Stromberg_97_Carburetor_4_web__50938.1394167421.1280.1280.jpg s-l1600.jpg
    GordonC likes this.
  2. V8 Bob
    V8 Bob
    One, Stromberg 97 style carbs are shorter in length and fit better on many multi-carb manifolds.
    Two, these Strombergs have mechanical power valves vs the problematic vacuum power valves on 94s., imo.
    X38, dana barlow, GordonC and 5 others like this.
  3. Petejoe
    Petejoe
    from Zoar, Ohio
    I prefer 97’s but 94’s run just as well and are a lot more reasonable.
    FYI…94’s are mandatory for an original loadamatic distributor.
    Yes I’ve heard of some issues with the 94 power valves but I have never experience it for twenty years running them on my 8ba.
    stubbsrodandcustom and GordonC like this.
  4. theHIGHLANDER
    theHIGHLANDER
    I'm not running em but I like the 94s for the fact there's a **** ton more of em, they evolved over the years and lots of parts interchange or upgrade with newer development stuff, that there are so many they're a lot cheaper, easy to rebuild, Ford ran em til the mid 50s, and I hear that S'bergs have their own issues and tend to leak easily. I haven't experience many on the big 'bergs in the Packards but dig around. You'll find a fair share of common foibles surrounding 97s. Or just drop a grand on a pair of new ones. Yeah. $1,000. For 2. Used 94s and a couple Daytona kits might cost ya 250 and some quality time at the table. Works for me, I have a ½ dozen cores already for chump change.
  5. hrm2k
    hrm2k
    I had 48’s on my old coupe ( 25 more CFM ish ) my current project is four 97’s
    chevyfordman likes this.
  6. GordonC
    GordonC
    Growing up in my world you were cool as hell if you ran trip carbs with Stromberg 97s. Here is my set ready to go once my flattys break in miles are done. Which is being done on a single 94 by the way!
    Scott079, clem, dana barlow and 5 others like this.
  7. dana barlow
    dana barlow
    from Miami Fla.
    Cost,and what I could find. I run some 94 as 2x2,3x2, 4x2 w 94s, had fun w 6x2* w 94s n 8x2* 94,but were too much* for y-block v8.
    Made all my own intakes,log set ups from old cut up driveshafts.
    Home made linkage n fuel logs.
    I would of run 97s if I could of found them. Would of liked to try 97s. If I could find rebuildebls for free.
    I block off the power valves w 94,the 97s have a better type power valve.
    bchctybob, CSPIDY, hrm2k and 5 others like this.
  8. tubman
    tubman
    This is correct. Indeed, there are some aftermarket manifolds on which 97's will fit, but 94's won't. I found this out the hard way with an early Hemi Weiand 4 in a row manifold. Other than that, I prefer 94's as, set up right, they are simply a better carburetor than a 97.
  9. cs39ford
    cs39ford
    The Holley 94 or the Stromberg 97. I use the Stromberg because they fit multi carb intake and if you were ever in a stuck dirty needle and seat on the road. All you need is a 11/16 wrench to remove and clean. No dis***emble needed As far as performance I think the are about the same
    hrm2k and stubbsrodandcustom like this.
  10. I tried for 2-3 years to find some reasonably priced Stromberg 97s. I decided to go with Holley 94s and now have 24 of them.
  11. kadillackid
    kadillackid
    Cost, performance, fitment aside I think the 97's are a ***ier looking unit ;)
    '34 Ratrod likes this.
  12. hrm2k
    hrm2k
    @GordonC , these are beautiful…..
    '34 Ratrod and GordonC like this.
  13. nochop
    nochop
    from norcal
  14. 27TV8
    27TV8
    Some mention blocking off the power valves? If I use two on a Hexagon intake what would be the procedure for blocking and would that have an effect on the way it runs? What does a power valve do? I have 97 s and 94 s
    would like to try the 94s
    Adriatic Machine likes this.
  15. GordonC
    GordonC
    Thanks hrm2K. I love the look but have no idea how they would run on the street. I was just figuring things out in that pic.
    hrm2k likes this.
  16. Model A Gomez
    Model A Gomez
    I'm running 94's on my flathead and they barely clear each other on the Offenhauser manifold, I had straight linkage on it to start but went to progressive linkage and it runs better. Got about 1200 miles on it and happy with the set up. I think 94's are a little less leak prone and cheaper and easier to find. plugs.jpg
    bchctybob and GordonC like this.
  17. railcarmover
    railcarmover
    IMG_4479.jpeg Holley 94 the first ‘smart’ carb, it listens to engine vacuum to provide enrichment through the power valve.
    I found harvesting old power valves to be the answer, modern ones have fit and function issues.I run them as a single on a banger, I have no experience running multiple 94’s, logic says you should plug one if you’re running two to prevent overfuel.
    bchctybob likes this.
  18. 57Custom300
    57Custom300
    from Arizona
    I ran 94's on my 57 3x2 setup. Took a while to dial in but once I got there it ran great. That said, I would have liked to try 97's but could never find some reasonably priced. I agree that 97's are more ***y looking.
  19. hrm2k
    hrm2k
    call me weird but a row of 97’s with accelerator pump rods and SP tops is beautiful.
    Do you have the pump arms for those ?
    GordonC likes this.
  20. bchctybob
    bchctybob
    ^^^^ You’re not weird, they are beautiful when they’re all dressed up right.
    I had three 97s on the 283 in my roadster and it ran ok, I gathered up three 94 style Holleys from ‘55-56 Fords, rebuilt them and stuck them on. Big difference in foot-to-the-floor power. Seemed to run better overall. Had the same frog mouths sticking out of the half hood.
    I’ll be trying 97s again. I’ve got six of them for my new roadster.
    hrm2k likes this.
  21. 1952henry
    1952henry
    upload_2023-10-24_11-19-34.jpeg 94s can be pretty
    GordonC, hrm2k and '34 Ratrod like this.
  22. 1952henry
    1952henry
    front carb had choke and kicker bosses shaved before a swim in dichromate. Factory linkage pieces were replaced with pieces I made from stainless steel-polished.
    GordonC and hrm2k like this.
  23. GordonC
    GordonC
    hrm2K all I have for those is right there in the pictures. I haven't spent a lot of time looking into what all they are going to need if I decide to run those tops. The 97's are all rebuilt and ready to go so my plan was to start there and see how things go.
