Projects Bought a Mercury on purpose
Discussion in 'The Hokey Ass Message Board' started by anthony myrick, Feb 4, 2023.
  1. Will do
    Using them for valves not falling on the floor insurance
    I’ll use the spring cups and o-rings just like old man gm did
  2. lilCowboy
    lilCowboy
    looking great, not sure if you mentioned it already, but if running a mechanical fuel pump looks like you may need to notch that crossmember
    chryslerfan55 and anthony myrick like this.
  3. Plan is for electric
    lilCowboy likes this.
  4. A Boner
    A Boner
    Best with 2 electric pumps…second one in the box in the trunk!
  5. Yep
    I do that with mechanical as well
  6. 4 pedals
    4 pedals
    from Nor Cal
    On your valve seals I've converted all my stuff over to viton in recent years. The guide has to be machined down some to fit, but I consider it cheap insurance for not having to pull the heads off.
    Devin
  7. Picked up a couple carbs at lloydfest.
    The center one seems to be in the best shape.
    There are some linkage differences.
    the rear carb linkage is an ez fix.
    The center one shouldn’t affect a thing.
    I can remove and plug this vacuum port
    Ive got this manual choke top. I’ve got all the pieces with it.
    shouldn’t make a difference, should it?
    Other than the visual
  8. alanp561
    alanp561
    Big enough breather and no one will ever notice ;)
  9. Yep.
    Closest I’ve got to a “matched” set
  10. SS327
    SS327
    For some stupid reason I think it may not work. Bowl venting or accelerator pump?
  11. The manual top does have a hole
    I’ll clean em all up and check
    bchctybob and SS327 like this.
  12. IMG_4955.jpeg Students ****oned up the front suspension.
    Cotter pins and grease fittings.
    We’ll get it painted then grease it.
    Had to notch for the stabilizer bar under the core support mount. We will make a small spacer for the stabilizer bar frame mounts.
    Core support was lowered for radiator clearance.
    Started bending brake lines.
  13. Students back this week.
    We’re covering basic hammer and dolly work. Bout got this fender dialed in
  14. guthriesmith
    guthriesmith
    Nice! Looks like another old Ford in the shop too?
  15. Students are going to replace a qtr on this 58 ranch wagon
  16. wide34
    wide34
    from Texas
  17. Okie Pete
    Okie Pete
    Looking good . Great skills being taught. Your a great teacher
  18. Wish I had a good before pic on the fender. Previous owner pounded on it with a ball peen and the headlight area was pushed in. Plus some previous filler work.
    This was during the straightening and pulling
    This is after being roughed out
  19. Greg Rogers
    Greg Rogers
    That is amazing!
    ffr1222k and anthony myrick like this.
  20. Before-after. Still haven’t touched it with a file. Has a couple areas that might get it. The grinding marks are from the previous repair. All hammers (a small ball peen mostly) and a shrink disc.
    we had it close at the end of last school year but yesterday we fine tuned and fit the headlight bucket.
    The trim under the headlight and the blinker ***embly was a job to re-shape the fender to fit.
    I’ve got a 51 parts car. I didn’t realize subtle difference between early 51s and later 51. The parts car had the early style flathead trans the other had the style used until 64. The parts car headlight buckets are aluminum with a pot metal ring. The other had steel buckets with a stamped ring.
    Squablow, bchctybob, Sancho and 10 others like this.
  21. FoMoCoMoFo
    FoMoCoMoFo
    from WY
    Wow, you do some amazing fab work on all these threads.
    When do you sleep haha?
  22. All the time (the sleep part)
    I have no social life :)
    other than car and s****yard stuff
  23. Gettin closer on the front alron
  24. Sky Six
    Sky Six
    from Arizona
    Would you drive it?
    :p:D
  25. I hope I get to
  26. Would you mind sending that Crew to my house for a Week?
    Sancho, williebill, bobss396 and 6 others like this.
  27. We replaced a headlight bucket and trim ring. Fixed the rest. Not bad for an old wreck. Have one small piece to fab under the headlight. IMG_6422.jpeg
  28. Not bad. Needs a 54 Desoto grille though. Hehe.
    Tow Truck Tom and anthony myrick like this.
  29. I got this one
    Rawrench, 40two, wide34 and 16 others like this.
