Projects 32 5W Build - The $4K Swapmeet Body / The Old Chrome Coupe
Discussion in 'Traditional Hot Rods' started by NealinCA, Feb 2, 2023.
  1. banjorear
    banjorear
    Neal,
    Your car looks perfect. Perfect chop, stance, everything. Killer car.
    NealinCA likes this.
  2. Thank you again for allowing me to play a part in the build My friend. Really happy with how it turned out.
  3. Atwater Mike
    Atwater Mike
    Neal...
    Those castings are superb. (Is it a type of 'Investment casting'? Can't be sand cast)
    Very interested in obtaining one for my '27 T tub on Deuce rails...
    Phenonomen work on the chop! Rudy is a metal genius...
    Outback likes this.
  4. NealinCA
    NealinCA
    The castings are indeed sand castings, Cl*** 30 Gray Iron. Part of what we have been working on with the foundry was surface finish, and they finally got that dialed in.
    The metal work on the car is the work of Josh Carrillo, Carrillo Customs in Los Osos, CA
    porkshop, bchctybob, sko_ford and 2 others like this.
  5. Outback
    Outback
    from NE Vic, Oz
    Wow great work all round! Coupe is looking grouse!
    The steering boxes? What are they? A copy or a hybrid? Tell us more!
  6. NealinCA
    NealinCA
    I started modifying and converting 37-39 Hudson and Nash steering boxes for 32-34 Fords about 15 years ago. As the supply of original boxes got tighter, I started looking into manufacturing my own version about 10 years ago. We cast the first batch about 5 years ago and have been doing small batches since.
    They are based off of the 37-39 Nash, but with either a 32 Ford or 33-34 Ford style flange cast in place. These boxes are a Gemmer rolling sector design, with an 18:1 ratio. They are built to order in small batches, usually filling orders from the back log.
    Aaron J, Carter, porkshop and 14 others like this.
  7. krylon32
    krylon32
    Alliance Vendor
    from Nebraska
    Haven't been able to afford one of the new boxes but I did have Neal rebuild and convert an original Hudson box to fit a 32 pickup I built. Worked great.
  8. Outback
    Outback
    from NE Vic, Oz
    Thanks Neil, it's great that there are people like you manufacturing things like this!
  9. NealinCA
    NealinCA
    I wasn't ignoring your question, was just waiting to be able to show the answer.
    I picked up this funky old chrome steering box from a friend
    Screenshot_20230723_181431_Instagram.jpg Screenshot_20230723_181440_Instagram.jpg
    It was a 37-39 Ford cross steer box thot someone had neatly pruned the mounting bracket off and converted it to side steer.
    They had kept the Ford internals, which points the pitman arm up, but I had a plan for that.
    I machined off their frame flange and fit a 3-bolt 32 style flange in it's place
    I also drilled the top of the case for a fill plug, and welded up the original fill plug in the side cover
  10. NealinCA
    NealinCA
    I was making up steering shafts for a few other steering boxes today, so added one in for myself
    With the shaft done, i was able to ***emble the box. I had saved out a nice set of 16:1 internals from a 39 Nash box, so used that, along with new bearings, bushings, gaskets, seals, etc.
    20230723_174915.jpg 20230723_174907.jpg 20230723_174936.jpg 20230723_174958.jpg
    So that knocks one more project off the list
  11. banjorear
    banjorear
  12. NealinCA
    NealinCA
    I've been busy with other projects, like a hay barn and the flathead race car i help Josh with.
    20230904_191714.jpg 20230903_173650.jpg IMG_20230925_124102_357.jpg 20230922_184423.jpg 20230923_122017.jpg
  13. NealinCA
    NealinCA
    But I did get a few more parts for the 5w.
    I lightened a 35-40 flywheel (from 38lbs to 27lbs) and had it surfaced and balanced.
    Also got the pan and water pumps back from the chrome shop. Getting closer to being able to ****on up the engine.
  14. NealinCA
    NealinCA
    Here are some before and during pics of the flywheel lightening. I will say,10-11 lbs of chips makes a mess of a lathe and the area around it!
    20230906_182406.jpg 20230906_184914.jpg 20230906_192339.jpg 20230906_192533.jpg
  15. alchemy
    alchemy
    Not chroming the flywheel?
  16. 60 Special
    60 Special
    from Omaha Ne.
    Outback likes this.
  17. -Brent-
    -Brent-
    Hahaha
    31chevymike and Outback like this.
  18. NealinCA
    NealinCA
    The flywheel and pressure plate should be back from the chrome shop in a few weeks...haha...not really. But I did get all my rear axle parts gathered, cleaned and ready. I really do not enjoy cleaning up the insides of parts after plating. I probably had 4 hours in the banjo and bells, cleaning threads and rust and flakey chrome from the insides. The end game with chrome is great, but getting there isn't for the faint of heart.
    I dropped them off with a friend yesterday so he can ***emble and adjust. Hope to have that back in a few weeks.
  19. Outback
    Outback
    from NE Vic, Oz
    I wouldn't be excited about ***embling the chrome diff either, for fear of damaging it!
    It will look amazing afterwards & worth the effort!
    Dedsoto and dwollam like this.
  20. sanfordsotherson
    sanfordsotherson
    from So. Cal.
    Neal, who're you using for your chrome plating?
    -Brent- likes this.
  21. Fogger
    Fogger
    See post #189, Neal listed the chrome shop
  22. NealinCA
    NealinCA
    Messed with rear fender and bumper placement yesterday. I took some inspiration from the Lloyd Bakan coupe on the rear fender treatment, then tweaked my worst pair of original rear bumper brackets to mock up the rear bumper. I ended up moving the bumper up about 2-1/4" and closer by about 2-1/2".
    20231015_141923.jpg 20231015_150157.jpg 20231015_155725.jpg 20231015_173130.jpg 20231015_173138.jpg 20231015_173308.jpg
  23. -Brent-
    -Brent-
    Huge improvement!
  24. NealinCA
    NealinCA
    Thank you. I think so...getting rid of the tall roof and long fenders cleaned up the look. More the subtle vibe I am going after.
  25. alchemy
    alchemy
    Wow, look at the curve on that bumper! I’m too used to seeing repro bumpers.
    Outback likes this.
  26. krylon32
    krylon32
    Alliance Vendor
    from Nebraska
    I'm missing something. Where did you section the fenders or is that a photo chop?
  27. NealinCA
    NealinCA
    As was done on the Bakan coupe, fenders are rotated forward, and about 2" sectioned off at the running board.
  28. hotrodA
    hotrodA
    Great look! Thanks for the tip!
    A Boner likes this.
  29. krylon32
    krylon32
    Alliance Vendor
    from Nebraska
    Thanks. Didn't know you could do that. Slick Idea.
    A Boner, -Brent- and Outback like this.
  30. Mikko_
    Mikko_
    from Sweden
    Been following this project from start and I must say you're doing a great job, everything is just spot on in my opinion.
