I have a gen 1 327. There is a byp*** port on the p*** side of the water pump. The port on the block is not drilled through to the water jacket. Does anyone know why there is this unused port?
It's not a heater hose connection. The hole is about 3/8" dia. and it's located just under the water pump mounting bolt holes on the p*** side. There is a port on the water pump that matches up to this port. The hole on the block is a blind hole. It's not drilled into the water jacket.
It’s to byp*** the thermostat when it’s closed. Some SBC used a byp*** hose out the top of the pump instead of the port. I just drill 3 holes in the thermostat to allow for byp*** in your situation.
Something to do with truck engines? as mentioned, there's a fitting on the top of some water pumps, used as a byp*** on trucks, and for the surge tanks on 60s Vettes.
If you buy a gasket set for a SBC the is one of the gaskets for this style by p***. If the block doesn’t have it you cut off that section of the gasket. If the block has it you must get the proper water pump or true up the hole and use a cup style freeze plug. With it there is no need to drill holes in the thermostat as this will cause the engine a slower heat up time…or choice.
This may help. Keep in mind that ‘vortec’ heads don’t have the ‘flow port’ in them that feeds this byp*** hole, so if you slap vortec heads on your pre 86 block you will need to use the intake to water pump byp***.
Back in the mid 60's when I was the truck mechanic's helper at a Chevy dealer, the water pumps came with a small plug to block that hole if the engine had a by-p*** hose.
