  1. bushwacker 57
    bushwacker 57
    Yes.
  2. Denny Fitt in Bob Meyer's car 1967...
  3. alanp561 likes this.
  4. ClayMart
    ClayMart
    I suppose it could be. But they're far enough away from the bleachers that it looks like they'd have to be outside of the oval and a ways north of turns 3 and 4. From the early 70s or so I've never seen them use that area for pit space. It looks like that would be an area that's usually used for east side parking. There's just not enough landmarks to compare. It's too bad that you just can't pan the original pit photo from above to the left and see if that tank farm adjacent to IRP is in the background. :rolleyes:
    Dean Lowe and chryslerfan55 like this.
  5. Stan Back
    Stan Back
    I guess you narrowed it down to Hugh Tucker -- or was it Hugh himself that narrowed it down?
    1947knuck, 296ardun, slayer and 6 others like this.
  6. Gene Cooper at Aquasco...
    1947knuck, curbspeed, slayer and 10 others like this.
  7. Marty Strode
    Marty Strode
    Probably still has the Olds in it !
    bchctybob likes this.
  8. skirtless33
    skirtless33
    I saw Dawson's 34 coupe run at Goodguys Indy 204 mph
    Fordors likes this.
  9. Stan Back
    Stan Back
    Marty --
    I read that his car's body was slightly narrowed.
    Stan
  10. bchctybob
    bchctybob
    It does look like the Olds powered version, the headers on the Chrysler were slightly different.
    I read that too, that they narrowed it slightly to fit the frame better. NHRA didn't notice. I don't think it was any kind of performance advantage, just aesthetics.
    Fordors and chryslerfan55 like this.
  11. Marty Strode
    Marty Strode
    Note the steering shock, wise choice, well built car !
  12. ClayMart
    ClayMart
    Deuces and chryslerfan55 like this.
  13. Dean Lowe
    Dean Lowe
    Hugh Tucker's roadster is exactly like it was when it was retired. Still has the Chrysler in it.
  14. DDDenny
    https://www.nhra.com/news/2017/racer-s-s****book-jim-dunn
    “This is one of the first cars I had with [Joe] Reath. People called it ‘the Rainbow car’ because of the paint. It was all candy pearl and changed colors depending on the angle. We had three cars painted like that. I won the March Meet [in 1969] with this car. On this run, at Lions, the crew guy didn't get the oil filter screwed on all the way. Oooops.”
  15. Marty Strode
    Marty Strode
    The hood sides needed to be cut out to clear the Chrysler.
  16. Car is completely restored and is part of the John Neas collection in OK...
  17. chase knight
    chase knight
    Yes, outside of turn 3 at the IRP oval.
  18. DDDenny
  19. Sky Six
    Sky Six
    from Arizona
    Not really, there are only one...maybe two...
    dozen violations.:rolleyes:
  20. Harv
    Harv
    from Sydney
    I was born a little late to have seen push starting or the electric roller starters shown above, but it's got me curious.
    I get the concept (I think) - two rollers, one or both driven electrically spin the rear wheels just like a push start.
    How were the vehicles held in place while the rollers spun? I guess most rails had no front brakes. Was it just the rear tyres sitting down in the gap between the rollers that held them?
    The process would work for manual transmissions and rear-pump autos, but how were front-pump autos started (***umed they retained the factory starter?).
    Cheers,
    Harv
  21. 427 sleeper
    427 sleeper
    Pffffttt!!! Wadda 'ya mean? There's a fire extinguisher right there!!! LOL!!! :p
    chryslerfan55, slayer and saltflats like this.
  22. 427 sleeper
    427 sleeper
    Not too sure, but I think they were restrained by the tow/push vehicle.
  23. dearjose
    dearjose
    Looked and zoomed in but don't see it. Can u explain wht it is, and how it works? And maybe where it is:D
  24. patsurf
    patsurf
    i think you see the **** bracket on p*** side of center,and see the connection hardware on drivers side of the link
  25. Sky Six
    Sky Six
    from Arizona
    @jnaki was a Lions regular during this time period and can give you detailed info for you.
  26. Marty Strode
    Marty Strode
    Steering shock to control front end wobble, especially when the the front end lifts during acceleration, and the tires are only lightly touching the ground. One end is clamped the the tube axle, and the other at the tie rod.
    chryslerfan55 and deadbeat like this.
  27. Harv
    Harv
    from Sydney
