Technical Cleaning oil off new Brookville body
Discussion in 'The Hokey Ass Message Board' started by Duke, Sep 29, 2023.
  1. Duke
    Duke
    If the weather allows this weekend I plan on cleaning and preparing the roadster body for paint. I was going to wash it with brake clean in a pump sprayer and wipe with blue shop towel. I was then going to sand with 150 and red scotch pads. First coat of primer will be DP 90, followed by PPG single stage paint. Any other tips? Any good ideas on access to the underside while working alone? What are good lifting points?
    Thank you
  2. Ive used several Brookville 32 roadster bodies and I built a simple framework to bolt into the ****pit area to help keep it from folding up while the doors are open or off. Then you can stand it on the nose with the firewall out to work on the underside
    doug3968 and banjeaux bob like this.
  3. Duke
    Duke
    Do you have a picture of the frame work that you built. That sounds like a really good idea!
  4. With the doors off , firewall out and the deck lid off it really isn’t very heavy , a couple of average guys can handle it
    as for primer/paint….the real paint guys can answer
  5. Sorry , I don’t have a picture , I’m sure it’s in my shed somewhere? I’ll see later
  6. RodStRace
    RodStRace
  7. ekimneirbo
    ekimneirbo
    I would pay particular attention to the underside rocker panel area and inside the doors. I bought an "undercoating" gun and used a flexible tube with the spray nozzle in the end of it. It allowed me to fish it through the holes in the backside of the rockers and spray inside before rust could form. Same with the inside of the doors. Not real controllable as far as a great finish, but those are surfaces that if you allow them to rust, you will pay for it later.
    Took a little experimenting to get it to spray well, but I'd do the bottom before I worried about the easy to get to surfaces.
  8. Duke
    Duke
    Is 150 the correct grit paper?
    Has anyone used soap and water as the first treatment to get the oil off? Did it flash rust right away?
    Thanks
  9. Im not a fan of brake cleaner.
    We used a PPG metal cleaner (DX series I think) and lots of wax and grease remover.
    Cleaned, cleaned, cleaned
    We DAd with 80 then epoxied
    Read your epoxy tech sheet for the recommended grit for bare steel
  10. K13
    K13
    This is the correct answer for about 90% of the questions people ask about paint. It still amazes me that so few people actually read them.
  11. woodiewagon46
    woodiewagon46
    from New York
    I gotta agree with Anthony, use something that is known to be compatible with paint, not brake cleaner.
  12. 05snopro440
    05snopro440
    Last year I bought a set of Model A reproduction steel rear fenders. They were covered in a waxy protective coating. I used a Wax and Grease Remover on a cloth. It took all the residue off, then I was able to sand the fender and prime it easily.
    Don't use brake clean, use something intended for the task. Wax and Grease remover or equivalent is my recommendation.
  13. krylon32
    krylon32
    from Nebraska
    For years when we were building 32 roadster package cars using Brookville sheet metal we we sprayed the bare metal ch***is, body and hood with Gibbs. Never had any problems. Wonder what my customers used to clean that off before paint?
    brady1929 likes this.
  14. I start with lacquer thinner then move onto wax and grease remover like @anthony myrick said. Just a habit I picked up 40 years ago when I learned this stuff. I feel the thinner is a bit better cleaner to start with
  15. We did a few brookville bodies
    We had one covered in wd40
    We started with wax and grease remover. It didn’t do as good as we wanted. Used the DX cleaner from ppg. Rags were filthy after recleaning where we used the wax and grease remover
    Use white rags. Clean until the rags stay white.
    Wear gloves
    Try thinner as suggested. Then follow with wax and grease remover.
  16. HOTRODPRIMER
    HOTRODPRIMER
    Follow Anthony's advice and you will be ahead of the game, forget the brake cleaner. HRP
  17. What I do before I spray anything, including primer, is wipe whatever I'm painting with Windex, and the blue paper towels from Lowes. I do this on bare metal, or primed, or painted surfaces. And if you spray it on it will evaporate and wont stay in the cracks.
  18. overspray
    overspray
    Cleaning the nooks and crannies is the worst. I use lacquer thinner in an old spray gun in a WELL ventilated area to get the oil off the hard to reach areas, and blow dry if you can't wipe. Using a self etching primer in those areas that are impossible to get at for sanding, is probably the best way to "treat" the bare steel after cleaning.
    here's a thread on Brookville body prep from 2011.
    https://www.jalopyjournal.com/forum/threads/bare-metal-prime.610011/#post-6776903
    and my 2 cents:
    I called Brookville for a friend to see what they have the steel prepped to and they told me it was cold rolled, not phosphated, and if you want it primed, they use a cheap grade of lacquer primer. I told him to order the body not primed and to either use metal conditioner to phosphate the metal or scuff or sand the metal and use a self etching primer followed by a hi build urethane primer. With most of the good primer systems (check the tech sheets for your brand) you can apply self etching primer on the clean, sanded steel and let that flash off for the reccommended time (around 30 minutes to 1 hour) then apply the compatible urethane hi build wet on wet over the flashed etch prime.
    A good epoxy (not DPLF) would work also, but would be best applied after using metal conditioner to phosphate the steel.
    Read the tech sheets for whichever primer system you consider.
    Tman and anthony myrick like this.
  19. The ago old question: is a conversion coating needed for epoxy?
    When you dig in tech sheets you might see something like “For best adhesion clean with **X”
    Not all epoxies say that.
    gimpyshotrods likes this.
  20. Duke
    Duke
    I phoned PPG tech yesterday. I asked about the sx579 and 520 treatment before DP90. They said I could do that. The issue is that you have to spray epoxy the same day. The big challenge is that those treatments need to be rinsed with water. Might cause more issues with getting the water out of all the metal folds and getting primer on in the same day. My plan today is to try a small area with soap and water. I will rinse with hot water and blow off the water. If the small area does not turn into rust, I will clean the rest of the body that way. I then plan on spraying and wiping with lacquer thinner. I will then hand sand with 150 and then wipe again. I am going to see what type of framework I can build to support the body.
  21. When you use the product correctly it can have a slight zinc coloring that gets confused with rust.
    It isn’t
    I used ppg VP on my last year. It’s their epoxy filler. Cost around the same as DP
    No conversion coatings are mentioned in the tech sheet I read.
    winduptoy likes this.
  22. ekimneirbo
    ekimneirbo
    Mine didn't, but I'm not in Canada. I primed the body after a couple of months and it was getting some splotches of rust here and there. Again, the biggest issue on mine was the inside of the rocker panels and some of the areas around the dash and windshield. I bought one of those handheld Harbor Freight sandblast guns with a reservoir on top. It worked very well at getting into the folds and difficult sanding places to remove the rust that had begun to appear. I have the fenders sitting in my ba*****t 2 years later with nothing done to them, and they still are fine. I have another decklid panel sitting in the pole barn which never gets below about 50degrees F in the winter and its just fine. If any rust does appear before I prime them, I'll just use the HF gun again. Like I said before, I would take the time to prevent rust inside the rocker panels BECAUSE the backside has open holes and will allow moisture inside them. I ***ume the Roadster is made the same as the Coupe rocker panels.
  23. Duke
    Duke
    I plan on doing the same thing to get paint everywhere. I will also use some spray in rust protection that creeps into the seams when the paint it cured and I am done with all paint work.
  24. 05snopro440
    05snopro440
    ekimneirbo likes this.
  25. overspray
    overspray
  26. overspray
    overspray
  27. winduptoy likes this.
  28. 05snopro440
    05snopro440
    That looks like a good option. Why is it a better option than the Eastwood product or similar?
  29. overspray
    overspray
    VP2050 is a two component gray direct to
    metal high build primer. VP2050 is fast
    drying and easy to sand and may be applied
    to over_" properly prepared steel, aluminum,"_
    fibergl*** and existing coatings in good
    condition.
    What Does "Properly Prepared Bare Metal" Mean?
    In many of our product data sheets, you may notice this or a similar statement under the Compatible Surfaces or Substrates section:
    “May be applied over properly prepared and treated bare metal”. But what does this mean?
    This means that your bare metal substrate must be properly sanded and treated with an appropriate direct-to-metal product such as an SX metal treatment, etch primer, or epoxy primer prior to applying anything else. These coatings insure adhesion for subsequent layers over the bare metal as well as provide additional corrosion protection.
    This step is especially important when using urethane primers or sealers. Their chemistry typically does not provide adhesion to bare metal – they must only be used over treated bare metal to insure optimum adhesion. So if you happen to sand through to metal, apply a bit of etch primer to insure it sticks!
    anthony myrick likes this.
