Hot Rods 32 Ford Headlight Stands Mounting Position?
Discussion in 'The Hokey Ass Message Board' started by davvet2, Sep 30, 2023.
  1. davvet2
    davvet2
    Could I see photos of the headlight stands mounting position on 32 Ford 3 window?
    Also trying to determine which stands to use. The frame is boxed so mounting them will be interesting....
    Thanks,
    Jim
  2. deathrowdave
    deathrowdave
    from NKy
    Ha ha ! Mine were easy they attach to a headlight bar
    '29 Gizmo and X38 like this.
  3. davvet2
    davvet2
    Here are frame horn photos showing the shock mounts
  4. X38
    X38
    I don't know about the headlights, but the shock seems to have an alignment problem.:confused:
    edit: you need to mount the rad shell and mock up the lights in locations until you arive at one that looks balanced to you.
    Happydaze and 05snopro440 like this.
  5. davvet2
    davvet2
    Yeah, I saw the misalignment on the shocks, that's the way I got the car. I have figure out how to fix
    it without ruining the powder coat. May have to space them out at the bottom of the shocks to straighten them out. Edit: not enough room on the powder coated spring perch bolts to space them out. May have to bend the upper mounts. I'll figure it out later.
    Don't have the stands or headlights yet, can't mock them up. I was just wanting to
    see how other owners had done their cars.
  6. HOTRODPRIMER
    HOTRODPRIMER
    Old School style. HRP
  7. HOTRODPRIMER
    HOTRODPRIMER
    Shock mount. HRP
    Just Gary likes this.
  8. davvet2
    davvet2
    Can I get a side shot on the mount? Thanks, Jim
  9. davvet2
    davvet2
  10. RockyMtnWay
    RockyMtnWay
    You’ve probably already cruised the deuce threads for pics, but the easiest solution if you use smaller king bee or dietz lights is to use the upper shock mount location (shown above).
    If you use a frame rail mount style, just watch how far back you put it. You can run into interference with the back of the light bucket on the shock mount or your hood sides when opening them.
    I’ve only done a few 32s, but always seem to end up using frame mounts and putting them in the same spot. Here’s a pic for reference. Sorry it’s not a 3W.
    ShelbyGuy likes this.
  11. pprather
    pprather
    Some ideas. However,the shock mount / stands are welded to frame rail.
  12. shortypu
    shortypu
    I used the So Cal Speed shop stands with 32 lights on my fenderless 3 window but my frame is not boxed from the front crossmember forward.But i think you could drill and tap threads on the frame.I used the same mounts on my model a with the Guide headlights anb thry are polished stainless. IMG_0609.JPG IMG_0064.JPG IMG_0674.JPG IMG_0676.JPG
  13. davvet2
    davvet2
    Thanks guys, the photos really help. Jim
  14. Use nutserts, or rivnuts to attach the stands to the boxed frame.
    lowrd likes this.
  15. RockyMtnWay
    RockyMtnWay
    Don’t know what you’ve checked already (or not) but on your shock alignment issue, I wonder what angle your front crossmember is welded in at, then what position you have your axle (for or aft), and what your caster on the axle is set at. If you check your frame angle against your upper shock mount angle (put a long rod in the bolt hole) and you have 5-7 degrees difference, they may be welded on properly. Might just need to adjust your hairpins to position the axle for fit/caster.
    Just food for thought.;););)
    Happydaze likes this.
  16. clem
    clem
  17. Happydaze
    Happydaze
    This! And you can clearly see the spring isn't happy, its a bind and whats causing it is doing the same to the shock.
    Chris
  18. ramblin dan
    ramblin dan
    This to me is an interesting topic as it changes the entire appearance of the car. Here's a few pics I've c ;po.jpg 3 wind.jpg 32 1.jpg 32 shocks mounts.jpg 1932-5-window-coupe-hot-rod-24.jpg dfeg.jpg front end.jpg ollected over the years.
  19. krylon32
    krylon32
    from Nebraska
    I've done a few ch***is over the years and you've got some other problems that need addressed before you worry about the lights. Sadly your frame is powder coated. I did a repair on a ch***is for a customer many years ago that was powder coated and I managed to get a paint match from a local paint store that put it in an spray can. I carefully prepared the area after the repair and s**** canned it and I got lucky and the repair disappeared. You might get lucky mounting the lights with some 7/16th steel nutserts if your headlights aren't to heavy. Lot going on up front with a straight axle car.
  20. HOTRODPRIMER
    HOTRODPRIMER
    Hows this? HRP
