Hey guys, I have a bad case of roadster lust... So I'm contemplating wether I should sell my coupe or just rebody it as a roadster... Figured I'd ask y'all what you think it's worth and that might help me make my decision... Thanks for your advice! Model A Special Coupe on 32 rails. Traditional bare bones hot rod style build. 51 331 Hemi, rebuilt a couple years ago, approximately 2500 miles. small performance mechanical cam. Howards direct lube lifters. Adjustable push rods. Machined NOS 392 oil pump. New timing set, bearings and rings. Progressive 3x2's yes they all work. And when you punch it she goes! GM T5 transmission, 5 speed with overdrive. 9 inch rear 3.25 gears TracLoc. F1 pedals, 37 ford axle, 46 bones and brakes. Posie's spring. GM Vega box. 40 ford steel wheels Auburn Deluxe Radials 5.50/7.50 Rides and drives great, goes down the rode 60-65 mph with one finger on the steering wheel. Body is not perfect, but pretty solid. No side windows or regulators.
