Projects Recreating the jesse lopez coupe
Discussion in 'Traditional Customs' started by jivin jer, Aug 18, 2012.
  1. jivin jer
    jivin jer
    Stogy, rob-redm, drdave and 8 others like this.
  2. jivin jer
    jivin jer
    "HOUSTON, WE HAVE A PROBLEM!”
    Stogy, Outback and AChopped1950ford like this.
  3. Outback
    Outback
    from NE Vic, Oz
    Oh no!
    Stogy likes this.
  4. jivin jer
    jivin jer
    Occasionally G/MA will come into the "command module" in the morning with her coffee cup and want to see what I'm up to. My morning usually starts with a look at the HAMB, and then I look at the news of the day etc, etc.
    Last Saturday she came in, sat down and we started our "whatcha doin", what's new etc. I had the recent page that has the two "woodies" on the bed, and we were looking at them and comparing the JCC on the screen to the one on the wall, dominating the room.
    Looking up from where I was sitting it appeared to IMG_1843 (1).jpg me that there is a problem that I had overlooked, or had ignored before this, with proportions on the front of the "car". It looks like the area below the headlight has to be extended downward to get the bumper below the center of the hubcap.
    With all the effort that Junior put into his creation to make sure that it couldn't be driven any lower than it was, this won't do. He told me that he "took" the oil pan off the car driving down a particular Blvd. that all the guys with lowered cars considered safe. He told me that when/if a potential rival was seen in his neighborhood that might be lower than his car, was a moment of great concern that produced an immediate investigation and response if needed.
  5. ne'erdowell
    ne'erdowell
    FWIW, looking at the wooden version from down low and the photo of the car shot from slightly above could provide dramatically different perspectives.
  6. jivin jer
    jivin jer
    Hang on Dave, I appreciate the help. I suppose this means I have to get outta my chair?
  7. ne'erdowell
    ne'erdowell
    It's your call...:)
  8. jivin jer
    jivin jer
    OK, I did get out of that chair and put a line through that pic of the actual car to see where the bumper needed to be, and then measure the "car" for comparison.
    Thanks for the sharp stick, Dave. It's close enough.
  9. You're having the same issues I found with faux 'chrome' finishes. The basic finish gets pretty close but as you noted, it just can't take any handling. And it seemed that any protective 'sealing' coat over it would dull the finish in some degree.
    Two possibilities; have you looked into the 'chrome' foil the model builders use? That may work for some of the smaller trim, although wrapping it around the larger curved bits would probably be tough. The other one is vacuum metalizing, the process used to create the 'chrome' trim in model kits but also used by Detroit in the '60s/70s to 'chrome' things like instrument clusters and other interior trim. There are companies that do this, likely not all that cheap but improved durability.
    Stogy likes this.
  10. ne'erdowell
    ne'erdowell
    Glad to provide some help. It's good you're OK with it.
    Stogy and rodncustomdreams like this.
  11. jivin jer
    jivin jer
    Thanks for the input, Steve, this is the stuff that I think I'm going to go with. I'll have a look for you shortly.
    Stogy likes this.
  12. jivin jer
    jivin jer
    Here's the JCC hubcap, and the JLC spotlight. They will probably work; I'm not going to do the bumpers to be able to see how everything ages. They feel very strange to the touch. IMG_1848 (1).jpg
  13. greybeard360
    greybeard360
    Stogy likes this.
  14. jivin jer
    jivin jer
  15. jivin jer
    jivin jer
    The JCC has an interior. This doesn't mean that the IMG_3267.JPG "woody" gets one.
  16. Outback
    Outback
    from NE Vic, Oz
    @jivin jer your attention to detail with these 'woodies' is inspirational!
    Stogy likes this.
  17. jivin jer
    jivin jer
    Thanks.
    Stogy and Outback like this.
  18. jivin jer
    jivin jer
    Gettin ready to wrap up the windows. The head of the large Molotow chrome pen is big enough to fit in the ridge of the opening and give me a nice stable line around the opening that mimics the stainless trim. IMG_1857.jpg
  19. jivin jer
    jivin jer
    I just saw that Gene Winfield is in what looks like serious trouble posted on here, and now it's gone???? It’s back on the Hamb,, check out Facebook!
  20. jivin jer
    jivin jer
    Windows are done, IMG_1860.jpg this whole thing is almost a "wrap".
  21. jivin jer
    jivin jer
    It's IMG_1732.jpg time to get the tail Lites done and installed. It starts here.
  22. jivin jer
    jivin jer
    Sometimes it helps to remind ourselves that we don't live in a cartoon world. IMG_1868.jpg
  23. jivin jer
    jivin jer
    I made a real life size "buck" out of wood to fit in the space for the tail lite , and then duplicated it in the red tail lite plastic. IMG_1869.jpg
  24. jivin jer
    jivin jer
    Here's the t/lite and the back/up lite almost ready to install. IMG_1870.jpg
  25. jivin jer
    jivin jer
  26. jivin jer
    jivin jer
    Well its time to figure out how these things are going to sit next to the real cars. I went back to the storage shed in the back yard and grabbed some wooden wedges that I had made years ago to prop up the small signs I made to explain to the car show attendees what they were looking at. A picture is worth a thousand words . so this is a look at the IMG_1881.jpg wedges and a couple of pics that they propped up. This was for the JCC.
  27. jivin jer
    jivin jer
  28. jivin jer
    jivin jer
  29. jivin jer
    jivin jer
  30. jivin jer
    jivin jer
