Introducing my Fuel Coupe-styled Tudor
Discussion in 'The Hokey Ass Message Board' started by Just Gary, Sep 18, 2006.
  1. Just Gary
    Just Gary
    Thanks! It hung out the back about 3'. We flipped up the tailgate and the frame rested on its top edge.
    BTW, the color was decided back in 2006:
    83707292_10216326344174483_6289258930954567680_o.jpg comp coupe.jpg DSC_3050.jpg FB_IMG_1614313722889.jpg gbp 04.jpg HLP.jpg orange crate 02.jpg orange drag roadster.jpg sheldon schmidt 01.jpg street roadster.jpg ThurmondBros-1.jpg
    shortypu, Outback, Stogy and 13 others like this.
  2. Blues4U
    Blues4U
    from So Cal
    Can't believe I just found this thread and powered my way through the whole thing. What a *****in build Gary, thanks for sharing everything. All this time and I didn't know you had this going on. Keep on keepin' on, you're getting closer all the time.
  3. mad mikey
    mad mikey
    One of the very best build threads on the HAMB.
  4. X38
    X38
    Frame's going to come out slick!
  5. Just Gary
    Just Gary
  6. X38
    X38
    Bright!
    Is that a straight tinter or a mix?
    lothiandon1940 and Just Gary like this.
  7. mad mikey
    mad mikey
  8. 32fenderless
    32fenderless
  9. AHotRod
    AHotRod
  10. Just Gary
    Just Gary
    Thanks for the kudos, guys. :)
    It's stock '69 C*m*ro Hugger Orange, code 72. Pontiac used the same code, but called it Carousel Red.
  11. lothiandon1940
    lothiandon1940
    WOW!!!.Love it Gary. Perfect color.
  12. Tim
    Tim
    from KCMO
    Holy **** that’s a shocker! That’s got to feel totally different in the garage now
    Just Gary, Dino 64 and mad mikey like this.
  13. Just Gary
    Just Gary
    Back to the bodywork "sand-prime-sand" do-loop.
    I also tapped down a few bare metal highs and spread a thin schmear of epoxy glaze in the remaining lows.
    BTW, black guidecoat mixed with sanding dust is like tal*** powder; it gets everywhere. :eek:
  14. Bandit Billy
    Bandit Billy
    It is a sign of intelligence to have longer toes on your right foot than the left. Working barefooted sort of negates that premise, however. :cool:
  15. catdad49
    catdad49
    A favorite color ever since I first saw The Orange Crate!! Please cover your feet before you paint the color coat, pretty sure the Wife will appreciate That.
  16. RodStRace
    RodStRace
    Zombie feet! Appropriate for the season!
  17. brianf31
    brianf31
    Nice progress! That powder guidecoat is the bomb. I discovered that and 20' rolls of PSA blocking sandpaper at the same time.
  18. Just Gary
    Just Gary
    I scuffed and masked the interior and undercarriage....
    ...and jacked up the body to access the sub- and cross-rail bottoms.
    Then I squirted on some TAMCO matte black single-stage urethane.
    It's mixed 4:1 plus ~5% reducer and sprayed through a 1.4 mm tip at 28 psi, per the TDS, and (what I thought was) 50% overlap.
    Two coats didn't cover the white primer very well.
    Maybe gun pressure? Or fluid setting? Or too thin? Or a combination?
    Anyway, I snuck out of work early today, re-masked, mixed, and sprayed another coat; this time unreduced, which covered much better. :)
    The satin finish should contrast nicely with the sparkly stuff. :cool:
    Now for some final sanding then off to Roy for paint!
  19. X38
    X38
    I'm glad I wasn't inside that tiny room while you were painting it! Could you see? :eek::D
  20. Dino 64
    Dino 64
    from Virginia
    Looks great !! More sanding ??? :eek::D:rolleyes: Let Roy do it :);)
  21. mad mikey
    mad mikey
    You got that right Dino, can't wait to see this in paint and being ***embled.:):)
  22. Dino 64
    Dino 64
    from Virginia
    It’s getting to the exciting phase ;)
  23. Just Gary
    Just Gary
    While impatiently waiting for my turn at Roy's paint booth, I blocked the edges of the door openings & raised beltlines to get nice consistent radii.
    Then began ***embling the ch***is. It's fun- like a giant Lego set...:)
    .... but with protective quilts & anti-seize.
    20231110_093811.jpg 20231110_093549.jpg 20231110_094942.jpg 20231110_094349.jpg 20231110_095511.jpg
    Joe Blow, tomcat11, -Brent- and 29 others like this.
  24. Tim
    Tim
    from KCMO
  25. goldmountain
    goldmountain
    Just found this thread. Avoided it for years because I couldn't understand the ***le. How can a Tudor be a coupe? Love that color.
    Just Gary and Stogy like this.
  26. 19Eddy30
    19Eddy30
    from VA
    Gary ,,,
    Your build just Pop's with detail !!
    ( knowing what you have to work with out of your Shop /Garage)
    I Love the look , color combo of your "Mill "
    I want a pair of those covers just to Hang on the Wall !!!
    ( Like I need more Go fast bling parts)
  27. mad mikey
    mad mikey
    WOW Gary, now that it is being ***embled , this is a sight to behold. Outstanding!:);)
  28. Dino 64
    Dino 64
    from Virginia
  29. Stan Back
    Stan Back
    The drag racing organizations came up with the Coupe designation to differentiate the other body styles than the Roadsters -- like 2- and 4-door sedans, coupes and, yes, even station wagons. The Roadsters usually had more entries that the "Coupes" and were usually faster than the "Coupes" and they all branched out to different levels like Gas Coupe, Altered Coupes, Compe***ion Coupes and further designations concerning superchargers and fuel used.
  30. lumpy 63
    lumpy 63
    Car is stunning Gary:D Problem is you've made it so *****in the single 4bbl is out of place......Blower time!!!!
