Technical On-line paint -who is good?
Discussion in 'The Hokey Ass Message Board' started by belair, Oct 3, 2023.
  1. belair
    belair
    Now that it's cooled off a little, I need to shoot a couple of projects. Who and what do you recommend?
  2. topher5150
    topher5150
    There was a thread on here a couple of days ago about Summit Racing paint for the budget-minded person.
    jimmy six, catdad49 and belair like this.
  3. Nailhead Jason
    Nailhead Jason
    id stay away from paintforcars.com . I took the chance on some paint for wheels and bought a gallon because i wanted to do the dash, garnish moldings and the engine with it too. It was garbage, not even close to the right color, and no matter how mixed the reducer and hardener it would set up in the gun after 3 to 5 min, and spray spider webs, even with almost no hardener in it, it would flash to fast. sprayed it with out and it set up looked like **** and instead of gold was brown.
    belair likes this.
  4. Los_Control
    Los_Control
    from TX
  5. evintho
    evintho
    Chucky, ffr1222k, j hansen and 9 others like this.
  6. bchctybob
    bchctybob
    Evintho, is that their standard Emerald Green Metallic? I'm considering that color for my Morris woody. It looks good!
    catdad49 likes this.
  7. evintho
    evintho
    No, it's Firemist Green Metallic. A little lighter and brighter than the Emerald Green Metallic. I absolutely luv the Firemist Green! Here's your Emerald Green...........
    Emerald Green Metallic 3.5 Voc Urethane Basecoat Gal — TCP Global
    Compare the two samples side-be-side and see what you like.
    bchctybob likes this.
  8. TCTND
    TCTND
    I've had excellent service from TCP global. Good selection, good paint, good prices.
    Just Gary and belair like this.
  9. 3quarter32
    3quarter32
    I have painted 3 hot rods with TCP Global and couldn't be happier. Free shipping has always been included with paint purchase.
  10. Do a search for TAMCO here
  11. fastcar1953
    fastcar1953
  12. bobss396
    bobss396
    We had a project to paint in college around 2002 and wound up at a local Sherwin-Williams. They went way out of their way to set us up with a single-stage paint that worked well.
    Now, I go to local auto body supply shops and they have always been very helpful.
  13. loveoftiki
    loveoftiki
    from Livonia,Mi
    I’m sure you all know this..but Summit doesn’t make paint…nor does Napa…or TCP…or Eastwood, they are buying it from a paint mfg like Sherwin Williams, PPG, etc..if you find a local paint jobber and ask for their value line I’m sure the quality and price point will be in line with those mail order places…it’s worth a shot..you’ll get some support, help the local economy, and get some sticks and strainers with your paint…
    abe lugo, Chucky, SS327 and 9 others like this.
  14. safetythird
    safetythird
  15. Correct. Summit's single stage is manufactured by Kirker, but packaged with Summit branding. Not sure about the others.
  16. pbr40
    pbr40
    from NW Indiana
    Ive had great luck with tamco paint and primer. Their tech support is fantastic. Summit base coat is good as well but they do not do custom colors.
    The 53 chev in picture is all tamco
    Tman, Just Gary and Bill's Auto Works like this.
  17. 57JoeFoMoPar
    57JoeFoMoPar
    Absolutely agree, or you can find a line of paint that is commensurate with the level of finish you're after. I know a lot of guys on here like single stage, but the one single stage car I have is more difficult to keep nice than the cars I have that are BC/CC. It's my preference.
    I've used TCP Global in the past and had a good experience. I used Smart Shoppers years ago in Kentucky, which I think became Dads Custom, and I think is now out of business. They were definitely the least expensive at that time, but the paint they sent me was old as hell and the HOK rep I showed it to told me they should have discarded the product due to age. It worked out fine, but I wasn't happy about that.
    More recently I've dealt with a local supplier, MGM in Hawthorne, NJ, who sells HOK. They either met or beat the online prices of other suppliers like TCP or Coast Air Brush, and the owner of the company actually delivered my order to my painter. I couldn't be happier with that level of customer service. They actually just dropped that order off this morning for all of the materials to paint my 61 Olds, which is getting shot over the next 3 days.
    It seems that when it comes to paint lines, the difference is often the coverage of the pigments, and the UV protection of the clear and/or solids level of clear.
    I get it that not every job is going to justify higher end paint materials. However, it has always been my mentality that when it comes to paint materials, you should utilize the best materials that are within your budget. For the most part, you get one crack at it, and you need to make that count. If I'm unhappy with an intake, I can have that on and off an engine in a couple hours and it's no worse for wear. But if I don't like the paint, it's weeks of work and a m***ive step backwards. Some friends of mine that do high-end concours level restorations use Spies Hecker, but money is no object and $10,000 of materials are not unheard of. HOK is more midline price-wise in my opinion, but I think provides a good value. My painter has used mostly DuPont Hot Hues but indulged me for HOK (Valspar) since it would match more closely some of the parts that aren't getting repainted. But I've also seen great looking cars shot with budget single-stage from Kirker and the like. As always, the prep is key.
    loudbang, Just Gary and belair like this.
  18. Fortunateson
    Fortunateson
    Is PaintGuru ***ociated with Tamco? I miss his posts...
    klleetrucking likes this.
  19. Just Gary
    Just Gary
    x2 TAMCO.
    They're a small mom & pop company in southern VA, their prices are very reasonable, tech support is excellent, and they ship products quickly.
    I'd never picked up a spray gun before, but with their tech support and TDS info, I sprayed high-build primer on my frame & body and am very happy with the results.:)
    Chucky, pbr40 and Bill's Auto Works like this.
  20. I will add to the support for TAMCO out of Virginia!
    However Tammy has split from the family & has started her own company (with her husband) it is called Orion & I highly support BOTH companies. Their products are for high end painters with a low end price. Both are family run & you can be sure both companies have amazing customer service. Almost every time you have a question, you will speak with a family member.
    I won't use anything else.
    https://orionautomotivefinishes.com/
    https://tamcopaint.com/
    God Bless
    Bill
    https://www.jalopyjournal.com/forum...ar-transport-hauling-open-or-enclosed.614419/
    rod1, williebill, pbr40 and 1 other person like this.
  21. flynbrian48
    flynbrian48
    EB5E0812-08DF-4608-9E06-899ED3353A64.jpeg I've had good results using "Kirker" paints. Full line of primer surfacers, sealers, colors, clear. They have candies and pearl as well. The pearl I've used, not the candy, good result with that. 24677B6A-CA7F-4F2A-9C36-7195C0D3CF3B.jpeg
  22. belair
    belair
    Thanks everyone.
  23. HOTRODPRIMER
    HOTRODPRIMER
  24. bobss396
    bobss396
    Valspar also owns lot of paint companies. I used mainly Omni products when I did the jambs on my car while it was apart. Sourced locally, open on Saturday mornings. I shot the bare interior with Duplicolor white "lacquer" I picked up at Auto Zone. That laid down nicely.
  25. notaford1
    notaford1
    from webster ny
    Has anyone heard about Restoration Shop paint?? They have some paint packages that are reasonably priced. Wondering if anyone has used or if any good
  26. BamaMav
    BamaMav
    from Berry, AL
    Haven’t used them yet, but I’m looking at them for paint to do my car. One thing I like about them is you can go to their auto color library and look at chips of factory colors back to the early 1900’s. If you want to use a factory color that would be easy to match for any repairs, I think they would be good to look at. I’ve spent hours looking at different colors and shades on there for my car, but I finally decided on a seldom seen color used on an ot vehicle.
  27. Petejoe
    Petejoe
    from Zoar, Ohio
    I’ve used their enamel with a gloss hardener on this 10 yrs ago. Worked out good. IMG_0090.jpeg
    Tman likes this.
  28. Lloyd's paint & glass
    Who makes the Tamco products?
    Just Gary likes this.
  29. Lloyd's paint & glass
    I prefer face to face when I spend this much money lol
    X-cpe and bobss396 like this.
