Technical Help with unknown manufacture of roller rocker ID 454.
Discussion in 'The Hokey Ass Message Board' started by wheeltramp brian, Oct 4, 2023.
  1. wheeltramp brian
    wheeltramp brian
    I've got a customer's car here. That is off-topic by 1 year and has a 454 big block with the full roller top end. One of the rocker arm pivot trunions broke And I'm trying to figure out what brand these are And have not been able to come up with anything. These are full roller rockers and 1.7 ratio with seven sixteenth studs. There are no part numbers or manufacturer stamps on them. And what I find is odd 20231004_092512.jpg 20231004_093200.jpg 20231004_095444.jpg Is that they have a guide for the valve tip which I have not seen and no guide plates. Any help would be appreciated, thank you.
  2. 34Phil
    34Phil
  3. JD Miller
    JD Miller
  4. wheeltramp brian
    wheeltramp brian
    I can find the correct ratio and full roller rocker arm. But not self aligning like this one. If I go to the regular type whole roller rocker arm. Then I have to run guide plates which is in a big deal. But I just figured. I'd try and see if I could buy one rocker arm.
  5. saltracer219
    saltracer219
    I have never seen a Big Block Chev that doesn't use guide plates! They came stock with guide plates and as you can see the canted valve angle thrusts the rocker sideways so there is no way that self aligning guide tip on that rocker is going to last. If you want a reliable valve train you will need to install the proper guide plates and the correct non self aligning rockers!
    427 sleeper, INVISIBLEKID and Oneball like this.
  6. wheeltramp brian
    wheeltramp brian
    I figure that's what I'm going to do. As for some reason, these don't exist on the internet anywhere And I also called a couple rocker arm companys and they don't know what to say about it and never heard of self aligning big block rockers.. And I want to get the job done by the weekend.
    INVISIBLEKID likes this.
  7. Oneball
    Oneball
  8. wheeltramp brian
    wheeltramp brian
    Yup, I agree it's just some junk. I'm gonna order guide plates and rockers right now.
    The pushrods are already chromaly steel so I don't need to get those
  9. wheeltramp brian
    wheeltramp brian
    I ordered A good set of roller rockers and guide plates. The push rods are already chrome molly steel.thanks all
    saltracer219 likes this.
  10. saltracer219
    saltracer219
    Just make sure that the pushrods are hardened for guide plates, just because they are supposed to be chrome moly does not necessairly mean that they are hardened.
  11. wheeltramp brian
    wheeltramp brian
    I looked up the part number that was printed on them and says that they were hardened chromoly and made for guide plates.
  12. squirrel
    Also make sure they're the right size :) but you know that.
  13. wheeltramp brian
    wheeltramp brian
    Yup, I double checked.
  14. Mike VV
    Mike VV
    from SoCal
    A thought...
    Think stainless rockers from a reputable place.
    I ran MANY (almost 50,000) miles with Crower Stainless rockers in my small Chevy with zero problems.
    Mike
  15. Flatrod17
    Flatrod17
    Take a 3 corner or any file to the push rod, if it cuts it, it's a soft push rod and the guide plates will eat them up. If it just skates then it's hard and good to go. Been down the road with moly push rods, ate them all if not hard.
    bobss396 likes this.
  16. wheeltramp brian
    wheeltramp brian
    Though I did look up the part number printed on it and it says they were hardened. I did your test and it passed.
    Bob Lowry likes this.
  17. squirrel
    Some of the big block pushrods have a pressed end that's about an inch long, that goes into the guide plate. Others don't.
    bobss396 and saltracer219 like this.
  18. There is a lot to be said about spending your money ONCE. I at least sleep better at night with name-brand valve train parts.
    I ran GM parts counter stamped rockers on my big block that saw 6500 RPMs when I was racing stock cars.
    Deuces likes this.
  19. wheeltramp brian
    wheeltramp brian
    You're right about spending your money once for sure. This guy that bought the motor has no idea what was inside he was just awestruck when they told him it was 600 horsepower. Not that it's a slow car, but I've got a customer with a 327. That would whip this thing anytime and have driven both cars.
  20. wheeltramp brian
    wheeltramp brian
    Just to finish this thread off. I got it all back together and it's running great. 20231005_104315.jpg 20231005_112237.jpg
    Deuces, saltflats, Oneball and 3 others like this.
  21. Doublepumper
    Doublepumper
    from WA-OR, USA
    Maybe a bracket goes there? 20231005_112237.jpg :)
    Deuces likes this.
  22. wheeltramp brian
    wheeltramp brian
    Nope, nothing goes there. Just loose bolts that were leaking coolant. The lock washers were too big around so I put some small flat washers underneath them.
    Doublepumper likes this.
  23. Oneball
    Oneball
    Where’s the shocks? Is that a brake line going through the shock mount??
  24. I am going to guess that's an air line for bags.
  25. Oneball
    Oneball
    Ah! Hadn’t thought of that.
  26. wheeltramp brian
    wheeltramp brian
