Unusual engine photos
Discussion in 'Off Topic Hot Rods & Customs' started by William Thompson, Sep 28, 2018.
  1. j hansen
    j hansen
  2. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    Yup
    I had a set for a small block Ford. The Mopar was probably rarer. Weber DOCE carbs bolted straight to the head ports. I even had a super rare 4V intake.
    Deuces, lurker mick and j hansen like this.
  3. jimmy six
    jimmy six
    Mcculloch Supercharged Ford Y-Block in 50 Ford Coupe. IMG_6041.jpeg IMG_6042.jpeg IMG_6045.jpeg
  4. j hansen
    j hansen
    Harry Miller`s V16
    Skärmavbild 2023-10-06 kl. 05.06.36.png Skärmavbild 2023-10-06 kl. 05.06.58.png Skärmavbild 2023-10-06 kl. 05.06.13.png
    Okie Pete, Thor1, tractorguy and 11 others like this.
  5. Okie Pete, Thor1, LAROKE and 7 others like this.
  6. mpbdlc
    mpbdlc
    Deuces and j hansen like this.
  7. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    And with straight cut spur gears, quiet too.
  8. j hansen
    j hansen
    Sad that he`s not rew it!!
    Okie Pete, tractorguy, greg32 and 4 others like this.
  9. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    WOW! What a fantastic video and a great restoration. Thanks for posting it.
    I gotta say that modern Holley looks a little out of place. But it seemed to idle well sobe it.
    j hansen likes this.
  10. Deuces
    Deuces
    That carb could use some tuning.... It's hunting all over the place...
  11. Verhuel tuned turbo flopper...
    Okie Pete, Thor1, tractorguy and 3 others like this.
  12. stude54ht
    stude54ht
    from Spokane WA
  13. Ned Ludd
    Ned Ludd
    warbird1 likes this.
  14. stude54ht
    stude54ht
    from Spokane WA
  15. saltflats
    saltflats
    from Missouri
    Having worked on the 6 cylinders could only imagine what that would be like to work on.
  16. j hansen
    j hansen
  17. Robert Evans
    Robert Evans
  18. saltflats
    saltflats
    from Missouri
    Anyone have a clue what these engines are?
    motoklas, jimmy six, Ned Ludd and 2 others like this.
  19. Moriarity
    Moriarity
    SUPER MODERATOR
    I used a google image search and found,
    Armstrong Siddeley Star Sapphire motor ***embly and inspection, Bristol, 1959. The Sapphire, introduced in 1953 is regarded as the most handsome of all the company?s varied saloon cars. It had a 125 bhp , 3.4 Litre six cylinder engine and cost in its first year ú1728. Unfortunately the market was against Armstrong Siddeley and by 1960 they gave up car production to concentrate on aircraft engines
    motoklas, jimmy six, Ned Ludd and 4 others like this.
  20. saltflats
    saltflats
    from Missouri
  21. seb fontana
    seb fontana
    from ct
    I would guess at more hp than 125 from 207 cu. in. with dual carbs, cross flow head and nice exhaust manifolds.:( Maybe low comp ratio due to junk gas, another guess.
  22. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    Probably correct. The average octane rating back then was around 79.
  23. Okie Pete
    Okie Pete
    IMG_7570.jpeg Hay Santa could You leave one of these under my tree ? Drop one off at Saltflats place also .
    saltflats likes this.
  24. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    It is a beautiful crossflow headed inliner. I wonder if, since British cars were taxed by how much power the engine had, if they "hedged their bets" as far as how much power was claimed? As an example, Anglas were rated at either 8 HP or 10 HP.
    seb fontana likes this.
  25. j hansen
    j hansen
  26. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    Thank you for that ad. I read they claimed 150 HP in the ad.
    Does anyone else think, with a 3" taper chop, that car would make a *****in' custom? It already has full fade fenders and suicide doors. Not to mention that six-banger.
    Anthony?
  27. Ned Ludd
    Ned Ludd
    That was the British "fiscal horsepower", which was used for tax purposes only. The formula was [bore in millimetres]² x [number of cylinders] / 1613. That would have made the Sapphire a 30HP car.
    The specific output of 40-odd bhp/litre was a bit on the low end for the time, but not remarkably so. It probably featured a cam profile aimed at bottom-end power and smoothness rather than high specific output.
    motoklas and down-the-road like this.
