Technical 34 brakes
Discussion in 'Traditional Hot Rods' started by Doug Black, Sep 24, 2023.
  1. Doug Black
    Doug Black
    from brownsburg
    I want to add a duel mc to my stock 34 pedals. It has juice brakes already but was never finished. I don’t want to cut up the frame. How can I do this without spending $600 on a conversion kit? Any pictures and info would be great.
  2. Does Dennis Lacy (search archives) have anything?
    Charlie Stephens
  3. Johnny Gee
    Johnny Gee
    from Downey, Ca
    How about a pic of your 34 with current master in it.
    Outback likes this.
  4. Doug Black
    Doug Black
    from brownsburg
    I don’t have a master cylinder or pedals. I only have brake lines. I want to use stock pedals and a dual master cylinder.
  5. 51504bat
    51504bat
  6. Johnny Gee
    Johnny Gee
    from Downey, Ca
  7. Doug Black
    Doug Black
    from brownsburg
    sko_ford likes this.
  8. 4ever18
    4ever18
    IMG_0850.jpeg A few years ago, I scored a “garage find” ‘33 3 window coupe. The car has always been well cared for and loved, even when parked for several years. I’m the fourth owner of the car. Either the original owner or the second owner is responsible for the conversion of my car to hydraulic brakes.
    Their master cylinder actuator & mount is simple and works well. The original pedals & the mechanical brakes “equalizer” ***embly work as originally designed. The master cylinder is mounted on the p***enger side of the X member, facing backwards. The mechanical brake equalizer ***embly is used to push the master cylinder rod . It works well and nothing was hacked. If this solution interests you, I can snap a few photos. It’s incredibly simple.
    jaracer, RICH B and flynbrian48 like this.
  9. Doug Black
    Doug Black
    from brownsburg
    Yes, that would be great. I would like to see how your setup works.
  10. dirt t
    dirt t
  11. 4ever18
    4ever18
    A simple piece of flat steel strap, bolted to the rear X member legs serves as a mounting bracket for the stock mechanical brakes equalizer shaft. Another simple bracket is bolted to the p***enger side X member leg to serve as the mounting bracket for the master cylinder.
  12. Doug Black
    Doug Black
    from brownsburg
    Thank you sir. Definitely going to look at this option. Appreciate the pictures.
    4ever18 likes this.
