Technical 1st Early Hemi
Discussion in 'The Hokey Ass Message Board' started by 57 Fargo, Oct 6, 2023.
  1. 57 Fargo
    57 Fargo
    An ad popped up on Kijiji a few weeks ago for a 354 Hemi block about five hours away, I bought it for $100 from a woman selling it for her dad. Turns out she was headed to my area for thanksgiving so she brought it for me and I got it home today.
    Upon decoding the number on it it turns out to be a 341 Desoto block, the cam and lifters are still in it. Oh well I’ve spent $100 on stupider stuff and I can say I have an early Hemi…sort of…
  2. Bandit Billy
    Bandit Billy
    Cam is a big part of the build. Regrind. Not a lot of other options for the Desoto.
    Deuces, 427 sleeper and 57 Fargo like this.
  3. Hemi Joel
    Hemi Joel
    from Minnesota
    Dual quads from an Adventurer will fit. I don't think I'd use it as the basis for a build, though. Too many hard to find parts are needed. Unless you had a complete 341 with a bad block to use along with it to make one good engine.
  4. 57 Fargo
    57 Fargo
    Yup, maybe I’ll find a use for it or find someone who does.
    427 sleeper and Bandit Billy like this.
  5. 57 Fargo
    57 Fargo
    My thoughts exactly. Desoto parts are hard to come by here, it’s a ‘57 295 horse four barrel engine. If I had the whole thing I’d build it. It did come with one piston and rod and exhaust manifolds.
    427 sleeper and VANDENPLAS like this.
  6. Bandit Billy
    Bandit Billy
    I gotta guy that can regrind that. Just sayin
    427 sleeper likes this.
  7. 57 Fargo
    57 Fargo
    Does he buy cores?
  8. dart4forte
    dart4forte
    from Mesa, AZ
    Nothing wrong with Desoto hemis
  9. 57 Fargo
    57 Fargo
    I’ve always wanted a desoto, unfortunately not much here to start with
  10. 73RR
    73RR
    Actually, you have a decent start. Do you have the main caps? Those would be important.
    I'd suggest keeping the cam with the block so that if you decide to sell it the cam might be the kicker.
    The 330 and 341 are stout performers with a decent cam profile and 10:1 cr.
  11. 73RR
    73RR
    One of the 'problems' that most independent grinders face is that the rough cast area between lobes will limit lift and duration unless it is also ground down. I set up a machine just for this operation.
    The fat core is common on all Dodge and DeSoto cams.
  12. 57 Fargo
    57 Fargo
    Yes the main caps are with it. I feel like the heads are the biggest challenge to find
  13. Start looking,,,,you will be surprised how many parts are around for the DeSoto engine .
    The cam is the important thing,,,,,you need a core at least to be able to do a regrind .
    Read up in these engines,,,,,,the low deck part’s mostly interchange with each other . The high deck heads will fit the low deck .
    The high deck parts are mostly only for the high deck .
    The high deck cranks are all the same ,,,,, difference in cu in was the bore .
    The high deck rods are the same,,,,, the heads are the same .
    These engines run very well when hopped up,,,,like Gary said .
    You need higher compression,,,,,,Ross can supply that easily !
    Stock compression can be supplied by Egge or other sources ,,,whichever you choose .
    Hotheads has an enormous supply of parts for these engines .
    I think they even have a new intake for the high deck,,,,,,it has a removable top .
    It’s not listed on the web site,,,,you have to call them .
    I have seen many parts for sale for the 330,,,,,pretty much identical stuff to your application .
    I’m fairly certain they even have the same forging numbers ?
    Tommy
    Budget36 likes this.
  14. 1biggun
    1biggun
    Id get it tanked and what ever to see if its any good as far as cracks or other issues before spending another dime .
    It possibly got robbed of almost all of it parts for a reason .
    keep a eye on market place and craigs list they pop up from time to time I saw one in WI not to long ago that was pretty complete .
  15. 57 Fargo
    57 Fargo
    @Desoto291Hemi Tommi, it’s the shipping that’ll kill me for parts, I will likely hot tank it and give it a good look and add it to my collection and see if I stumble across parts for it
    VANDENPLAS likes this.
  16. 73RR
    73RR
    I try to not focus on the actual freight costs anymore, rather, what will 'it' cost when 'it' is at my door.
    Sometimes freight costs can be a bargaining tool.
    Desoto291Hemi likes this.
  17. 57 Fargo
    57 Fargo
    This is true, I have a 331 waiting for me that will get built first. Like I said I’ll probably clean this up and put it away and see what happens.
  18. bostonhemi
    bostonhemi
    The cam alone is worth more than that
  19. 57 Fargo
    57 Fargo
    I have zero buyer’s remorse. I will eventually track down parts to build it.
  20. 73RR
    73RR
    Close but.....no. Those rods are for a 276-291.\....well gotta edit this.
    The c to c is 276-291 but the big end bore is for the 330-341
    I'll guess that they are still 'new' because they were made for some ******* setup.
    Frakenrod. Who knows, they might work in something....
    Desoto291Hemi and 57 Fargo like this.
  21. 57 Fargo
    57 Fargo
    I have a line on some parts. I did see those rods but quickly determined they were not what I was looking for
    HemiDeuce likes this.
  22. Dang! Shows what I know about early Desoto hemis...less than not much!
    73RR likes this.
  23. 57 Fargo
    57 Fargo
    Oh I’m far from knowing anything about them so I did some research! I appreciate the thought!
    anothercarguy likes this.
  24. DeSoto all take a .924 pin ,,,,the low deck are 2.188 I.d.bore,,,the high deck are 2.3755 I.d. .
    Those rods in the sale add are the length of a short deck DeSoto,,,,,but take a pin and I.d. Of a Chrysler 331,354 .
    I’m not sure what they are for .
    Tommy
    57 Fargo likes this.
  25. 57 Fargo
    57 Fargo
    All I knew Tommy was they didn’t match the dimensions I found online for 341 rods!:)
  26. scotts52
    scotts52
    Try pirateship.com I just compared a quote to ship a seat. $600 for FedEx as a walk in customer. $488 FedEx with an account. $287 pirateship
    What a difference
  27. SS327
    SS327
    I have been looking for an affordable hemi for about 40 years. Never even ran across one. However in that time I have found at 3different times and locations a single hemi head laying in the street like they fell off the back of a junk truck. One was broken in 1/2, one had the deck surface tore up really bad from sliding along the highway and one had a corner missing.
